Fasttech TanLu TL-20G Gift set Review. Nitecore EC4 copy.
Disclosure.
I received this light from Fasttech for half price to do this review. A full refund was offered by by Fasttech after the review was completed but this was declined.
Link to the review light.
https://www.fasttech.com/p/6040700
The review.
This light created quite a bit of interest in the Fasttech thread when it was announced as it appeared to be a copy of the popular Nitcore EC4 light. As the light was in my budget I requested if I could do a review for them which was accepted.
The light was ordered on the 31.10.16, dispatched on the 23.11.16 and received on the 2.12.16.
The gift set includes a holster, Two x 3300 mAh batteries and charger all packaged in a green plastic container.
All included paperwork was in Chinese which I cannot translate. The two batteries were shipoped in the light.
The light looks quite attractive and well made from initial inspection. It only has a single electronic switch.
The holster itself is made from what appears to be some sort of imitation leather of a very thin nature. The belt strap itself may not take much abuse as its the same thin material with single seams. The retaining strap was sewn on slightly crooked which did not allow the strap to sit squarely over the head of the light. The strap has a press stud on it which appears quite sturdy but I do sense it may rip the male part from the holster when unclipping the strap.
The batteries had Kapton tape on the negative ends to prevent the light accidentally turning on during shipping.
The batteries themselves were the usual cheap Chinese batteries. The negative ends had dents in them as standard.
On discharge testing the batteries one had a capacity of 203mAh at a 2 amp discharge rate using a ICharger 208B. The second battery tested at 1199 mAh at 1 amp discharge.
The battery charger was your usual $2.00 item that is shipped with lots of cheap lights. They charge the batteries in parallel at a very slow rate. Termination voltage was 4.268.
The tailcap itself. The batteries are run in parallel. The middle thread picked up in the housing at one stage until some penetrating oil was squirted in which allowed the threads to free up and the tailcap to be removed.
The tailcap seal looked quite good.
To follow along with the dodgy thread was the anodising internally. You can decide whether you like the quality or not.
The positive contacts for the batteries inside the light appeared to be made from steel. The only batteries I had that would work in this light were the ones that came with it, The plastic is raised around the positive contacts only allowing batteries with the smallest in diameter button tops to make contact.
The light itself was not disassembled.
The led was well centred. The tint from the XML2 led was very cool. The bezel could be unscrewed and the plain glass lens and oring removed but no amount of persuasion would remove the reflector which looked quite respectable. It is possible that the housing has been crimped not allowing the reflector to come out. Could be wrong on that though.
The closest light I had to this light reflector size is the BLF Starrylight SA22. This has the 3C tint led.
Next is the TanLu TL-20G. High measures .75 amp. Modes run as the following. switch on, high, med, flashy and next click from the electronic switch is off. I have no idea why they build lights with this type of setup.
This is the Nitecore EC4S which has the XHP35 led and was taken with slightly flat batteries so this picture is only the second highest mode. This light was kindly lent to me by lostheplot to compare with TantLu.
And finally a Convoy C8 which has a much larger reflector.
The next few pictures are of the review light and Nitecore EC4S.
The TanLu left and Nitcore right. The difference in the switches can be seen here.
The EC4S has the two batteries in series.
This light would have to be one of the most anticipated lights this year that I thought would be a good thing. Unfortunately the exact opposite is the case.
I would not recommend this light to anyone. It is badly let down by the substandard quality of the light in nearly all respects which follows on to the batteries, charger and holster.
Finally I would like to thank Fasttech for supplying the light at a reduced rate for the review.
Thanks for the review, I think I’ll take a pass on this one.
Thank you. “What not to buy” reviews are among the most useful for me.
Bummer, I was hoping it would be a decent copy. I really like the EC4 design with side by side cells.
Thanks for the work on reviewing this light, and what a worthless light it is, but that needs to be revealed on BLF too! Perhaps a plus is that the reflector throws a decent beam.
Bought the light by itself and the best part of it was/is the case it comes in.
Totally disappointed in this flashlight.
Really thought about blasting it with shotgun. may still happen.
As you said, very few batteries will fit, you need a button top, un protected short battery.
The threads are the worst part, A Wood Screw comes to mind as far as the pitch and attention to detail.
Couldn’t bring myself to waste the time on a review as Full price was paid.
Sometimes you eff the Bear and sometimes the Bear effs you.
The Bear won big time.
I received this light last week. Its a useless flashlight. I might do something with it later but the quality is really bad. Plastic reflector and such.
Thanks for the review.
This light seems quite disappointing. I was contemplating this light for my dad, the shape would be good for his arthritic hands and the low output wouldn’t bother him but that mode selection would annoy even him.
Ec4 is having a good deal at banggood(40:money_mouth_face:
No reason to buy this
In my opinion, ec4 is one of the best flashlight
Plenty of negatives and no positives from other members pretty much says it all. Thanks for chiming in.
Yep, I have one too. The anodizing on my copy was better than yours but everything else was about the same. The glass lens was the worst part on mine. It felt overly brittle, had chips around the outside, and wasn’t even a perfect circle.
I ordered just the light to gut and use as an XHP50 bike light, from FT over a week ago, and the shipping said it had failed China customs and had bounced back to Beijing…
I told FT about it, and they offered a refund, but not until they received it back.
So I’m down $20, I haven’t got it, and FT show no sign of refunding me, unless the package magically makes it’s way back to them…
:neutral_face:
For sure.
agnelucio,
Any idea why it failed customs? I’ve ordered a lot of stuff from FT, never had issues, but I’ve got vape gear on the way from them.
+1 :+1:
Wow. Absolute junk……
Why would it fail customs ? For what reason ? Why would a flashlight raise suspicion ?
Yes it is a common sentiment from quite a few of us here unfortunately. It looked so promising.
Yep, me too.
“‘The road of excess leads to the palace of wisdom…You never know what is enough until you know what is more than enough.’” - William Blake
Hi MRsDNF,
Once you make a review, you have to contact me via PM for reimbursement. I have refunded you the full payment back to your account. Thank you.
Noel
