Cree XHP50.2
106 posts / 0 new
djozz
djozz's picture
Last seen: 9 hours 57 min ago
Cree XHP50.2
Here’s the next led in the series that Cree is upgrading to a worse beam profile. Ok, I’m being pessimistic, the press release even says:
“In addition to light output and efficacy enhancements, the XHP50.2 LED provides improvements to optical uniformity through secondary optics, enabling spot and portable lighting manufacturers to deliver better lighting experiences.”
Let’s be optimistic then: if we are extremely lucky, the black cross between the led dies is reduced, reducing the donut-hole caused by smooth reflectors.
At least the output is 7% higher and efficiency 10% better, the Vf is a bit lower and the voltage-drop when heating up is lower.
link to djozz tests
“I used to think that top environmental problems were biodiversity loss, ecosystem collapse and climate change. I thought that thirty years of good science could address these problems. I was wrong. The top environmental problems are selfishness, greed and apathy, and to deal with these we need a cultural and spiritual transformation. And we scientists don’t know how to do that.”   (Gus Speth)
Edited by: djozz on 12/15/2016 - 10:19
MILSPEC
Thanks for sharing, djozz. I need to come up with a way of clearly understanding all these emitters in detail, there are so many these days.
LightRider
LightRider's picture
Last seen: 2 months 3 days ago
Will it still display the donut hole?
LightRider
Oh boy! I just hit 1000 posts. Facepalm
Not quite ready for a giveaway, but I will get around to it eventually:)
djozz
djozz's picture
With the rough phosfor, it may have a less clear cross in between the leds, so who knows the donut hole will be less pronounced
link to djozz tests
Texas_Ace
Texas_Ace's picture
Last seen: 2 hours 4 min ago
Hmm, I guess that just leaves the XHP70 to be updated then.
Know guns, know peace, know safety. No guns, no peace, no safety.
The ultimate result of shielding men from the effects of folly is to fill the world with fools. --Herbert Spencer , English Philosopher (1820-1903)
Texas Avenger Driver Series
My LED Test series - XP-L2 V5  - Nichia 219C 90+ CRILatticebright "XM-L"XHP35 & PWM efficiency - XHP50 - XP-L V5 - XM-L2 U2 - XP-G3 S5  - XP-L HI V2 - Oslon Square & direct comparison to Djozz tests - Nichia 319A - Nichia 219B 9080 CRI - Nichia 219C D320 - Nichia 229AT - XHP70.2 P2 - XHP50.2 J4 - Samsung LH351D
Easy comparison tool for all my LED tests
hIKARInoob
hIKARInoob's picture
Last seen: 4 hours 37 min ago
I kinda feel that either you go with the larger more powerful XHP70, or the smaller XHP35 or XPL. XHP50 doesn’t seem too popular…
Pok
Pok's picture
Last seen: 18 hours 56 min ago
For New Thrower!!!
XHP50.2 Hi Wink
XHP70.2 Hi Wink
-X3-
-X3-'s picture
Last seen: 14 hours 58 min ago
Which is weird, because it can be used to upgrade an XML2 light with the 5*5mm dimensions…
Just find a way to push 6V through it, and you’re good.
BTW I’ve still to find a good high CRI XHP50 in the 4000Kish
"Hey -X3-, do you have a flashlight ?"   "-X3-, can I borrow one of your flashlights ?"
My Flashlight public album (mods, emitter swaps, eye candy)
My reviews channel (French language, Olight, Thorfire, Sofirn, Lumintop : 60+ lights tested)
My personal channel (including Olight SR mini, S1, S2, S1A and S-mini disassembly)
M4DM4X blog, saves you $$$
Enderman
Enderman's picture
Last seen: 8 min 56 sec ago
I would definitely like something with even more lumens than an XHP70 Smile
The CBT140 from luminus is too inefficient.
hIKARInoob
No doubt it’s discussed somewhere, but I want to see HI versions of XHP70 and 50.
djozz
djozz's picture
I’m not sure how well a dome-less emitter goes together with the new type of rough phosfor, you may not have the same die luminance (=throw) upgrade that the XP-L Hi has over the XP-L.
link to djozz tests
pilotdog68
pilotdog68's picture
Last seen: 1 hour 39 min ago
looks like the phosphor is a continuous blanket completely covering the quad die. I would expect no black cross, but probably back to the evil tint shift we had just started to get away from.
djozz
djozz's picture
I more expect the same as the Nichia 144A, with the cross reduced, and yellow:
link to djozz tests
hIKARInoob
Mount it on a gun: you have illumination AND a crosshair.
pilotdog68
hmm good pic Djozz, guess I’ll have to wait and see.
Jerommel
Jerommel's picture
Last seen: 1 month 5 days ago
It seems the all of the 5050 footprint LEDs have gone out of fashion.
..waiting for parts..
Still looking for 5” parabolic reflector (for recoil light)
LightRider
Made me chuckle Big Smile
Edit: Maybe they come with windage and elevation adjustments?
The_Driver
The_Driver's picture
Last seen: 5 hours 26 min ago
Not quite, there is the new Luminus SST-40, essentially a clone of the XM-L2.
Texas_Ace
Texas_Ace's picture
Interesting datasheet, anyone tried them out or seen them for sale?
will34
will34's picture
Last seen: 4 hours 12 min ago
This looks interesting… I hope they are not only optimized for optics use.
The new Olight s10R III uses it, efficiency is about the same or maybe a tad higher than the XM-L2 judging by the amp draw but there is massive tint shift betweeen hotspot and spill. (Very cool tint at the edge)
hIKARInoob
Use tintshift for elevation adjustment.
Rufusbduck
Rufusbduck's picture
Last seen: 8 months 3 weeks ago
I’d rather see them produce a 6V only version using the same process as the MTG-2 or XPG-3 foregoing the 12V option in favor of a clean beam. I for one appreciate the XM footprint since I mostly work with small to medium size hosts.
Scott
everydaysurvivalgear
everydaysurvivalgear's picture
Last seen: 4 hours 19 min ago
Thanks mate!
I think this is better for general use. Dedoming will be no good any more.
Texas_Ace
Texas_Ace's picture
The normal XHP50 could be dedomed easily? Last I heard all the XHP series was a royal pain to dedome and thats why most sliced the done.
The_Driver
Slicing seems to work nicely though Wink
texas shooter
Last seen: 4 hours 7 min ago
Any one else notice the OP dome.
pommie
Last seen: 2 hours 8 min ago
And that the dome seems to have phosphor mixed into it.
Cheers David
Nothing to see here folks, move along...
Texas_Ace
Texas_Ace's picture
Anybody seen these for sale yet? I have a light ready for one of these, just waiting for them to come to market. I want to test it and see how it compares to the old XHP50 and XHP70.
Wieselflinkpro
Last seen: 8 hours 17 min ago
Yes on Kaidomain.com.
Texas_Ace
Texas_Ace's picture
Thanks for the heads up!
Wow, they are more expensive then I had hoped / figured they would be.
At least they have some good tints, too bad they are not high CRI as well. I have a sale pending, I might grab one after that although not sure I will want to risk it by running a test on it since I have a light I want to use it in.
