Any day now I should receive a pair of cheapo e-bay 10440's that I plan to try in my A3. Looking around it sounds as though the 2 chargers I have may be a little to strong for these. I have the WP2 II and a cheap DX http://www.dealextreme.com/p/18650-digital-battery-charger-3499
From what I understand the 500ma on the WP2 will be too much but I have no idea what the DX unit charges at?.
Which one of these chargers would you recommend I use on the 10440's.
I use a cheapo DX (2) 18650 charger that came with a cheapo dive light I bought. I've never had any problems. I measure the charge afterward. I don't use the 10400 all that much. I only have them for the A3 and even so I usually use Eneloops as the low is too high with the 10400 and on high it gets hot fast.
Well, I don't have a WPAII but it has a selector switch to choose between 500 and 1000mAh charge rates. I have the Trustfire TR001 which also charges at 500mAh. So far, I've had no issues charging them at that current. They don't get hot or even warm. Also, the Tr001 backs down on the current when the cells are near full charge. Not bad for $8.50.
It was my understanding that once you start charging 10440's much above 300mAh then you start to shorten their lives significantly. Obviously you wouldn't notice the effect right off.
No its not difficult. But the only truly inexpensive way is to build one that charges cells all at a low rate (i.e. 300mAh) and unfortunately most people want a fast rate for 18650's.
There are some very inexpensive single cell wallplug type chargers at DealExtreme that charge at 300mAh. I use one just like that for my 10440's and occasionally use it for my 14500's as well if I just need to charge a single cell.
Just noticed the back on the DX charger indicates 600ma and if I remember corrrectly testing performed on CPF indicated that when 2 batteries were being charged together each would receive 300ma. I might just try going that route for the first couple of charges then if all is well will switch over to the xtar.
I have a Trustfire TR003P4 that says it will charge 10430, 10440, 14500, 16340, 17670, 18500, 18650. All I have is 18650's and 14500's and it seems to work well for both. the 18650's will get warm if they have been discharged pretty low but the 14500's barely ever get warm. Charger says 500mA x4 (4 slots) I mix 14500's and 18650's with no problems. Not the fastest charger but it appears to not be hard on batteries. I bought it after reading a review by old4570 https://budgetlightforum.com/t/-/3250
[I charge my 10440 cells on my WF-139 and they never get warm and always stop at 4.19v.] How do you insure the voltage? Can you measure at the battery terminals with a voldtmeter?
10440's. i have no problems with charging with WF-188.
the charger terminates at voltages < 4.200V unless i repeatedly put them back in the tray. the grey Ultrafire would reach the 4.200V (up to 4.220V) after 1-3 repeated chargings, the blue Ultrafire require more of these and also dont seem to hold the charge as well as the grey Ultrafire.
