Manker U11 Flashlight REVIEW (18650,XP-L,1050Lm,NW or CW)
6 posts / 0 new
FlashLion
FlashLion's picture
Last seen: 2 years 6 months ago
*Happy holidays to all*
I am testing and sharing my impressions and thoughts of the very intriguing looking flashlight,the Manker U11.
The manufacturer Manker is on the market from not so long ago,but it tries to add some fresh ideas to this market releasing products with distinctive design and user interface.
The U11 flashlight can be powered by single 18650 battery or two CR123A batteries.
Made of hard Aluminum allow with beautiful matte black finish.
The review sample was provided by TMART.com for test and review.
The status indicating blue light under the switch not by accident called by Manker-Breathing.
This is how it looks in the normal charged status.When the battery is empty the U11's indicator breaths with a different frequency,also different while it is connected for charging.
Check out the TMART's website for actual price and availability-
http://www.tmart.com/MANKER-U11-XP-L...k_p352139.html
http://www.tmart.com/MANKER-U11-XP-L...k_p352140.html
You can use theCoupon code U11
Price with the code: $33.99
On first look,Manker U11 has catching the eye design with several deep grooves and partly knurled surface.
Looking at the comparison pictures,the U11 is compact for a 18650 flashlight.
Anodizing and machining are done on very high level with just one or two imperfections.
The overall design is very smooth with round edges,making the flashlight very comfortable in the hand.
Beautiful black matte finish.No glossy finish here. The designers and engineers working on the Manker line flashlights definitely have a talent and know how to implement their ideas.
Size comparison :
18650 battery, Manker U11, Olight S30, Fenix RC11, Nitecore HC30, Thorfire VG15
The knurling is done just on the zones where it is needed.No extra knurling for appearance.
After holding the U11 in my hand,I can confirm that the grip is comfortable and stable in the same time.
The design allows stable tail-standing and good anti-roll options,as well.
The U11 fits perfectly in the hand as the side switch is easy to find in the dark by touch.
The switch is positioned just on the right place for the thumb,allowing comfortable operation.
In my medium size thin hand.
The package-very sturdy cardboard box.
Neutral White LED on my sample.
Main specifications.
Sturdy carton box with a thick white plastic foam for great shock protection while transporting the package.
In the set-Instruction Sheet,good lanyard with the Manker name,one spare O-ring,thick pocket clip and unlike other flashlights with standard micro USB charging port,
the U11 has a short cable included.
Cree XP-L LED. Very clear glass lens with great anti-reflective coating.
Deep aluminum reflector with textured reflective finish.
Stainless steel bezel which does not seem to have the purpose to protect the front of the flashlight.
It is almost on the same level with the aluminum body.
Great square-cut threads,anodized-without any reason for critique on my sample.
Dual spring at the tail cap-ensures optimal current flow,better contact with the battery.
Thanks to the anodizing of the tail threads,unscrewing the tail cap a little allows to disconnect the battery from the driver and prevent any accidental activation.
Inside the battery tube-a spring on the positive contact point too.
The tube is well sized and takes long protected batteries without problems with tightening the tail cap.
Because of the electronic way of activating the light,the U11's driver electronics take some current in the Off/Standby state.
I am pleased to report that it is just 0.15microAmps. However if you leave the blue location indicator under the switch On,
this will draw 3.5mA from the battery,which is even higher than Moonlight mode consumption.
As a problem,I can point out the silicon cap of the charging port.Its thinner end that is used for easy opening the charging port section is easy to bend away from the body.While adjusting the hand grip,
I found the thin end of the cap quite often to catch my hand and most likely carrying the flashlight in a pocket or a backpack will lead to unintended bending.
The cover itself is well made-reasonably well sealing the charging port.
Though,I can not test it for waterproofing level and can't share opinion after long period of use,for now.
620mA charging current.
User Interface
Manker is offering impressive amount of modes for a low priced flashlight and even compared to most of the produced flashlights,at all.
Manker gives you the choice to select preferable brightness for Low,Mid,High and Turbo mode,as the choice is between three different levels for each mode.
The UI ideas are well implemented,allowing quick and easy basic operation with advanced features for people interested to play a little more with their flashlight options and to reach better customization
I am glad to report that the UI works as specified.Great response from the driver and the switch.
This is one of the most refined interfaces I have tested and find it easy and quick to operate.
I love the option for quick access to the lowest mode. It is great to found it available in the Manker U11 too.
I have only one reserve of the UI and more specifically the mode spacing. The lowest Moonlight mode is extremely low,without doubt.
The Mid,High and Turbo modes are well selected too. As mentioned earlier,we can choose one of three brightness levels for each mode,except Moonlight mode.
This definitely leaves gap between Moonlight and Low mode as I found the Low mode quite bright after using the extremely low Moonlight mode.
A 1 lumen or even 3 lumen option could make the spacing a little better for Low brightness preferring users.
Here is how to operate the modes.
Briefly press the switch-this will activate Moonlight mode.
To change the mode-click the switch again briefly.Every click will switch to the next mode.
Mode sequence Moonlight-Low-Mid-High-Turbo
If you prefer to activate directly the last used mode-press and hold the switch for a second from Off state.
To turn the light Off-press and hold the switch for a second.
To save you some reading here is a photo of the instruction sheet illustrating the mode selecting chain.
Link to a higher resolution image- https://www.flickr.com/gp/101497681@N02/G1436g
Manker U11 gives you the option to use two menus-General mode and Pro mode.
The first is the base mode sequence.The second adds additional features like battery voltage indication and the already mentioned option to select preferable brightness for Low,Mid,High,Turbo modes from three possible variants,for each mode. The three brightness variants are also defined and can't be freely adjusted.Yet they give us a chance for a little better customization of the mode spacing.
After setting the preferable brightness for each mode,while in Pro mode we use these outputs instead of the General mode ones.
Switch illumination can be activated only when the light is turned Off.
To turn it on you have to activate Strobe first with following turn off.
To be able to activate the switch indicator,you have o activate Strobe first which may be quite inconvenient.
Lumen measurements taken by me with not professionally calibrated integrating sphere:
(General mode outputs)
Turbo mode 1150Lm initial / 990Lm after 30sec
High mode 640Lm
Mid mode 290Lm
Low mode 143Lm
Moonlight mode is very hard to measure accurately.
Interesting to note is that my measurements confirm the described output values for all modes except Low mode which is two times brighter.
Below you can see RunTime graphs revealing the U11's performance on Turbo and High mode.
High mode maintains constant brightness of 530Lm(the UI was set to Pro mode with High mode set to the lowest brightness for this mode) for about 2h 35min.
Turbo mode has impressive initial brightness,though it does decrease quickly.
After small stepdown from 950Lm to 900Lm the output is constant(890Lm) for about 20 minutes. After that the discharge curve depends on the voltage supplied by the battery.
Manker U11 has Low Voltage protection which turns the light off when the battery is nearly empty.
You can still activate the light for short periods after that,but is recommended to replace the battery or to charge it.
Battery voltage after discharge test was 3.2V. Charging a 3400mAh battery directly in the flashlight takes about 8 hours.
Below is a comparison with other flashlights which do not feature programmed step down-ThruNite TC12 and Nitecore HC30.
(Note that according to the instruction sheet the U11 features additional hidden Turbo mode with constant current supply,
which may keep a little higher output,but I did not test it yet.)
This is a comparison of the regular Turbo mode vs hidden Turbo mode without step down.
The little bit higher output in the first 20 minutes results in 40 minutes less run time.
Beam profile
According to the provided specifications the light from the LED installed in my U11 sample is neutral white.
In my opinion,even without comparing it to other flashlights with different color temperature,the light is actually warm white or at least on the NW/WW border.
I see a lot of yellowish and orange light in the beam and depending of the way of use and the personal preferences,the warmer light could be an advantage or exactly the opposite.
It is hard to test for color rendition-in my eyes it is not quite good,especially for white objects.
Outdoors the warm white light could be more suitable than cool white light,which usually make the objects less colorful and realistic.
Yet,I have tested flashlights with much better NW light. This is my opinion,a result of my experience.
The beam has quite smooth profile with comfortable transition between hotspot-corona-spill.
Due to the textured reflector,the beam is more a flood light than thrower.Suitable for every day use occasional outdoor medium distance use.
1 meter distance, White wall
1/20sec
1 meter distance
1/250sec
3 meters distance
1/6sec
3 meters distance
1/50sec
Strong points:
Good build quality with great design and anodized matte finish;
Built-in charging circuit with safe termination voltage; Well sealed microUSB charging port;
Most common charging port-phone charger and cable can be used;
Very good beam profile; Extended UI with wide selection of modes; Convenient way to operate the UI with a single switch;
Compact for 18650 size flashlight. Comfortable switch/back illuminated;
Good performance of the electronics; Not just an average flashlight;
What could be weak points,according to preferences and way of use:
Moonlight mode is extremely low brightness and while many may prefer it for first in the mode sequence,sometimes it is not clear if the flashlight is already turned On or not.
I would prefer a hidden Moonlight mode or additional choice of brighter level for this mode.
The step from Moonlight mode to Low mode is huge-hard to the eyes-eaves desire for another mode in between;
The brightness of all modes but the Moonlight can be selected from three values;
Neutral white LED much warmer white than expected/needed; No direct access to Turbo mode;
Slow charging;
These are my test results and thoughts after using the U11 for some time.
Thanks for reading!
Thanks to TMART.com for providing the review sample and giving me the chance to test a flashlight from a new to me brand and share my results with you.
The review is quite extensive-typos and explanation corrections are possible.
Kusie
Kusie's picture
Last seen: 6 months 3 weeks ago
Thanks for the review, although the U11 has already been reviewed several times extensively in the past at BLF. But it seems that some of the complaints I heard about the tint of the “neutral white” 5.000 K version are true – whatever Manker decided to put inside the U11 NW, it´s definitely not a standard 5000K tint… I´ve swapped the cool white XP-L myself with an XP-L V6 3D and it has a nice neutral white, not the yellow/warm tint you show here.
K.
Streamer
Streamer's picture
Last seen: 1 month 3 days ago
I can concur with above observations on Manker NW tint. Mine looks exactly as the color coming across in the review…yellow. No way is it even close to what I consider NW to be. No problem really, and it looks great outdoors. But why not call it what it really is Manker? >>>>>>> WW
wle
wle's picture
Last seen: 1 hour 24 min ago
also needs direct turbo access
moonlight should be brighter
UI is clumsy at best
fuel gauge does not work right
it is well made though and cheap for the build quality and features
wle
    Daniel Behrman, "The Man Who Loved Bicycles".
-Greg Lemond.
Streamer
Streamer's picture
Turbo IS directly accessible but only through memory mode. Once preset, you can alternately bypass memorized turbo by short click to moon if need be.
wle
wle's picture
yes i know but having to plan in advance isn;t the same thing as direct access….
wle
-Greg Lemond.
