Is my torch dead?
14 posts / 0 new
AaLF
Last seen: 1 year 3 months ago
Is my torch dead?
My low use BLF SE 18650 torch wont switch on.
I opened the clicky end to re-charge battery. After charging – no response from torch. (battery works fine)
EyeballFryer
Last seen: 10 hours 36 min ago
I’d start with some simple troubleshooting tests:
- Did you insert the battery with the positive end facing the head?
- Maybe the head is loose? Try tightening the head?
- Try cleaning all of the metal contact points. Maybe there’s a piece of dirt that’s preventing the tail cap from properly tightening up and completing the circuit.
- Try bypassing the switch. Use a piece of metal like a paper clip or tweezers. If the flashlight lights up, the switch is the problem.
AaLF
OK. The metal clip as contact works.
But still no response from clicky cap.
vwpieces
vwpieces's picture
Last seen: 5 hours 2 min ago
Good, it’s not dead.
Check the retaining ring inside the “clicky cap”. Tighten it.
jycheang
Last seen: 3 weeks 20 hours ago
Try get another fresh 18650 to test on it.
I just “cooked” my driver >.<
AaLF
Now when contacting the cap ready to crew down at angle it works.
When aligned with thread & screwed down – no response.
AaLF
Still no light – officially. however when first holding cap to end ready to screw down the light comes on. But once I start crewing cap down contact is lost.
I got other lights but this one is my goto lite. What can i do?
RotorHead64
RotorHead64's picture
Last seen: 1 day 18 hours ago
Look inside the tailcap. Remove the brass ring with some Needle nose pliers. Remove the switch/spring/PCB assembly. Inspect the assembly. Check operation. Reassemble. Make sure the brass ring is good and tight. Make sure the tailcap is good and tight. Make sure the end of the battery tube that contacts the inside of the tail cap is clean bare metal. If it still doesn’t work get a new switch. 17mm omten 1288
Phlogiston
Last seen: 12 hours 26 min ago
Convoy sell ready-made 17mm Omten 1288 switch assemblies, should you need one.
EDIT: blast, I’ve just noticed that these are no longer available. Do you have a soldering iron? Omten 1288 switches are sold all over the place (Convoy sell 10 packs here for example).
AaLF
I don’t trust myself to pull it apart. Bummer.
Lexel
Lexel's picture
Last seen: 1 hour 12 min ago
Pull it apart there is nothing you could break
teacher
teacher's picture
Last seen: 1 hour 44 min ago
+1
Nothing to it ‘AaLF’, go for it. Wink
      You never know how a horse will pull until you hook him up to a heavy load. / Paul "Bear" Bryant ~/~\~ "Slow is Smooth, Smooth is Fast"
       Texas Lumens Flashlights  <>   M4D M4X Deals : sign up - save $$$$    ||||   Confucius say -- Baaa-haaaaaa......   tongue-out
         Rudeness Level /\ mΩ /\ {width:70%} /\ LightWiki /\ LED Tint Chart /\ LED Tint Picture /\ Xlamp size chart /\ BatteryU                   Flashaholic? Need Professional Help???   wink   /\ TheOriginal /\ TAB /\ LightSearch /\ BatterySearch /\ 14500's /\ DiCal
Dusty
Last seen: 21 hours 28 min ago
Bend a paper clip to fit around the retaining ring of the switch. If it works when screwed together, you need a slightly larger shim in the switch assy, or thicker retaining ring.
Brianbug
Lexel
Lexel's picture
If the retaining ring is too deep in the tail, you can bend some copper strand in round shape between the board and retaining ring
