JAX X6 hunter with xph70. Ask for $60
Fet driver with gypydrv Rev.2, Noctigon MCPCB directly soldered to the pill, de-dome xph 70 (maybe 5000K), all spring bypassed
The reflector was bored to fit the xph70. Although the whole is a bit ugly.
USA only. USPS shipping included.
Here are some beam shots. I am sorry that I can not find a good dark place.
Pardon my newbie’ness but what’s difference of say stock vs. “Fet driver with gypydrv Rev.2, Noctigon MCPCB directly soldered to the pill, de-dome xph 70 (maybe 5000K), all spring bypassed” ???
And is it all yellow, dim and pencil thin zoom like those XML de-domes?
So it is a highly modified flashlight. Direct drive. Highly programmable modes. De-dome xph70 gives you both good throw and spread light. It should be well over 4000 lumens with good cells.
good cells? I only have King Kongs 26650s and green samsung? 26670s and trustfire ones are they good? Could I ask you the run times? also does it have low mode? Kinda tired of the 20 minute to 1 hour flashy high end lights. I don’t mind 500 lumens for 5+ hours, being realistic I mean.
King Kongs and samsungs are good enough. I did not test the run times. But these direct drivers are highly efficient.
I am using this driver: FET Driver - 22mm
These are the modes available. Programmable to fit your needs. Moonlight(ML) mode is very low.
Rev.2 User Selectable Groups:
100% Only
5% - 100% | Memory
5% - 100% | No Memory
30% - 100% | Memory
30% - 100% | No Memory
70% - 100% | Memory
70% - 100% | No Memory
ML - 30% - 100% | Memory
ML - 30% - 100% | No Memory
100% - 30% - ML | No Memory
ML - 5% - 15% - 50% - 70% - 100% | Memory
ML - 5% - 15% - 50% - 70% - 100% | No Memory
100% - 70% - 50% - 15% - 5% - ML | No Memory
Strobe Only
100% - Strobe | No Memory
Strobe - 100% | No Memory
100% - 1Hz Blink | No Memory
ML - 5% - 30% - 70% - 100% - Strobe - 1Hz Blink | No Memory
100% - 70% - 30% - 5% - ML - Strobe - 1Hz Blink | No Memory
5% - 30% - 100% - 1Hz Blink - 3Hz Blink - Strobe - Beacon | No Memory
