Does it exist: Tiny hotplate for LED/MCPCB reflowing?
74 posts / 0 new
sac02
sac02's picture
I’m a noob and have only reflowed a handful of LEDs onto MCPCBs in my life. I’m using my helping hands to hold the MCPCB, and my 250W soldering gun held to the bottom of the MCPCB to heat it. It is awkward because the helping hands are not the firmest method to hold the MCPCB – they flex if I try to put pressure on the gun pushing up against the MCPCB, or push down on the LED to seat it.
The stovetop method seems awkward, plus my stove is crappy and hard to control temperture.
I’d like something a little more elegant/ergonomic.
I was thinking of a small hot plate – more like the kind meant for heating beakers in science labs, not heating skillets in a small apartment. Something I could easily store, and find room for on my workbench.
More like this:
And not this:
Unfortunately after rudimentary googling, the “scientific” hot plates are hundreds of dollars !!! , and the “small appartment” hot plates are more budget friendly (~$20).
Any thoughts or ideas?
joerch
something like this?
https://www.amazon.com/Ovente-Portable-Infrared-Stainless-BGI201S/dp/B01...
or search for camping hot plates
Jerommel
Jerommel's picture
Last seen: 6 hours 41 min ago
Those “lab” things are obviously way overpriced.
Soldering guns also suck.
So you should get a normal soldering iron and a “thing” where you can stick the soldering bit in so it gets hot enough to reflow LEDs.
Basically a small block of aluminium with a hole in it.
And i need something like that too.
The ‘helping hand’ (or 3rd hand) works, but it would be nice to have something that is level by itself.
I haven’t found the perfect solution yet, but i am also looking for it.
>1 Kilowatt kitchen appliances aren’t it.
..waiting for parts..
Still looking for 5” parabolic reflector (for recoil light)
sac02
sac02's picture
I do have a temp controlled soldering station, and I could easily drill a hole in a 25×25×15mm scrap of Aluminum I have laying around.
Do you think that would work? I’m thinking I’d have to really crank up the temp on the soldering station and it would kill my tips and possibly heating element quickly.
I really like that concept though!
vinte77
Last seen: 7 hours 54 min ago
You could always use the helping hands paired with a hot air station. You can get them for like $30 on ebay. It can help with more than just reflowing LEDs.
sac02
sac02's picture
Hmm, I hadn’t even considered a hot air station. Will $30 get me a decent one, or one that I’m going to regret buying and wind up spending $100 more, a couple months from now?
Lights-Out
Lights-Out's picture
Last seen: 3 hours 36 min ago
A mini frying pan and torch gun lol
LightRider
LightRider's picture
Last seen: 4 months 3 days ago
A cylindrical heating cartridge pressed into a hole in a small block of aluminum would work. I used the ceramic heating cartridge from an old 100watt soldering iron. I drilled a half inch hole into the side of a 3” diameter by 2” thick piece of aluminum. I also have a temperature controller but haven’t used that part yet.
If I were to do it again I would use 3” by 1” and a 200watt heater cartridge. As it is now it takes about 20mins to heat up and 1.5 hours to cool if not heatsinked or cooled with a pan or something else to pull away the heat.
It’s not ideal but it works well
vinte77
I bought one for $30 off of eBay recently and it works well. I think other board
members have bought similar ones and not many complaints.
LightRider
CRX
CRX's picture
Last seen: 2 weeks 5 days ago
I’ve only ever used long nose pliars and a jet flame lighter Blushing
Jerommel
Jerommel's picture
I’m sure it will.
The block shouldn’t be large though, or ti will take ages to heat, of it will radiate and air-cool too much.
When you have a good heat conduction between soldering iron and the alu block, it will just heat it up until the thermostat ends it.
Usually those soldering stations are around 60 Watts, so i see no problem.
It may take a while to reach that 200°C though. (depending on size of alu block and ambient temp. and airflow, etc…)
djozz
djozz's picture
Last seen: 10 hours 4 min ago
Had to look up the post from three years ago… this is what I made back then. My reflow skills have improved a lot since then but I still use the exact same contraption, it works well;
http://budgetlightforum.com/comment/334252#comment-334252
link to djozz tests
“I used to think that top environmental problems were biodiversity loss, ecosystem collapse and climate change. I thought that thirty years of good science could address these problems. I was wrong. The top environmental problems are selfishness, greed and apathy, and to deal with these we need a cultural and spiritual transformation. And we scientists don’t know how to do that.”   (Gus Speth)
Jerommel
Jerommel's picture
Yeah, that’s the idea. Thumbs Up
And with an only 30 Watts soldering iron?
But in that topic someone suggested this:
https://www.fasttech.com/products/0/10002875/1214600-150w-temperature-co...
I’m not sure what the mains voltage is in AU,but it has a AU plug.
It’s not ideal, but it’s cheap, stable and regulated.
mapache
mapache's picture
Last seen: 1 week 6 days ago
Au is 230v.
What is wrong with using the 2nd electric hot plate pictured in the OP or a 6” electric skillet like this?
keltex78
keltex78's picture
Last seen: 3 hours 43 min ago
I have always just balanced the PCB on the side of my soldering iron barrel and have gotten good results. No special anything needed.
Keepin’ the “B” in BLF
Don wrote:
It sounds like the XM LEDs won’t really be suitable for flashlight use. Pity…
keltex78
keltex78's picture
When I was a kid, my parents had an automotive vinyl seat repair kit that included a soldering iron type of tool with a flat paddle tip like pictured below. I’m curious if one of those would work for reflow.
dekozn
Last seen: 8 hours 33 min ago
could a copper bar be used instead of aluminium? Heat up the bar with a gasburner with the star on it. Or would the heat release unhealthy gasses from the copper?
ImA4Wheelr
Last seen: 6 hours 34 min ago
A hot air station is great if you plan on reflowing tiny components on pcb's.  If not, get one of these.  Often on sale for about $8.  Just put your star, solder paste, and led in a helping hand.  The heat from below and with in seconds, it is reflowed.  Very easy to control the level of heat by the distance you hold the gun from the base.  Plus you can remove the heat instantly with a flick of your hand.  Less stress on the LED/base and no disturbing the LED as the solder cools.  You'll never reflow by another method again.
sac02
sac02's picture
ImA4Wheeler, I already have one of those in my garage! It has two heat settings: 1. Hot as Frick, and 2. Auto-ignition of anything within 12 inches. Lol.
I had not even considered using it as hot air for reflow, but I’ll certainly give it a shot now that mention it.
hmihaylov
Last seen: 1 month 6 days ago
Jerommel wrote:
But in that topic someone suggested this: https://www.fasttech.com/products/0/10002875/1214600-150w-temperature-co... I’m not sure what the mains voltage is in AU,but it has a AU plug. It’s not ideal, but it’s cheap, stable and regulated.
This looks like a very good option. I have just now started to reflow leds (melted the dome of one in the process) and was using the tip of the (obviously too hot) soldering iron under the MCPCB to heat it up. As this is far from perfect I am looking for another solution.
May the Light illumine you Wink
Joshk
Last seen: 12 hours 24 min ago
I’ve always used my heat gun, it works great. I do a tail-stand with it. Then I hold the PCB with a pair of needle-nose pliers over it at about a 2.5” distance. It works fast too.
djozz
djozz's picture
A huge advantage of alumimium is that solder does not stick to it, and so the surface stays flat and clean much longer.
link to djozz tests
Lexel
Lexel's picture
Last seen: 8 hours 46 min ago
mrheosuper
Last seen: 1 day 18 hours ago
i use Alumium block and Heating Element from 3d printer, cost only 3-4$, 12V, 30W, work very well
Forgot my pen
mattlward
mattlward's picture
Last seen: 4 days 11 hours ago
This is what I use, less than 1 minute and it is done. I also use it to warm bullet moulds and melt pewter when I do not fire up the 100 pound lead pot.
Hot plate
EDC rotation:
Convoy S2+, 6*7135, XM-L2 3D, 10 degree TIR, PilotDog lighted tailcap.
Convoy S2+, H17F, XM-L2 4C, lighted tailcap
Zebralight SC52w-L2
Olight S1A
Olight S1R
sac02
sac02's picture
I just Googled that, I like it. Basically the same as the soldering iron in the Al block, but without the handle and such – looks like the most compact option for the workbench/toolbox so far.
I’m glad I asked this question, lots of good options I had not considered!
Gunga
Gunga's picture
Last seen: 13 hours 13 min ago
Those ones from Banggood look pretty cool. Do they work well? I just use a soldering iron but wouldn’t mind a more controlled device. Especially for triples and some other more difficult tasks.
djozz
djozz's picture
how hot do these 3D-printer hotplates get?
link to djozz tests
MILSPEC
Last seen: 1 month 1 day ago
Since we are all brainstorming here I just wanted to highlight another option, albeit not a very compact one:
https://www.youtube.com/watch?v=ckcHyMxqesM
https://www.youtube.com/watch?v=NCGzKDTFBSQ
I understand that this not the hot plate/skillet option, but with a reflow oven you woud have good control over the temperate profile, can reflow multiple boards/pcbs at once and even larger projects, and the costs would be reasonable if you have an older oven somewhere. Also, this can be a fun build project. IMO, this should also be a better reflow option for boards with both sides populated.
hank
hank's picture
Last seen: 5 days 10 hours ago
Oh, drat. The $60+ Gopher power supply promotion deal ends before they expect to restock.
Quote:
restock on 3rd April 2017
Price: US$42.22
Promotion Sale From March 19 to March 31.
