Test/review of Shockli 16340 700mAh (Yellow)
11 posts / 0 new
HKJ
HKJ's picture
Last seen: 16 min 13 sec ago
DSC_7533
Official specifications:
  • Nominal voltage: 3.7V
  • Nominal capacity: 700mAh
  • Maximum discharge current: 3A
  • Standard charge: 0.3A-0.75A
Shockli%2016340%20700mAh%20(Yellow)-info
A protected 16340, i.e. about same size as CR123 (It is longer due to the protection).
DSC_7531DSC_7532
DSC_7534DSC_7535
DSC_7536
DSC_7537
Shockli%2016340%20700mAh%20(Yellow)-Capacity
This cell looks good at low current (i.e. < 2A), but the cells are rather different at 3A and also very hard loaded.
Shockli%2016340%20700mAh%20(Yellow)-Temp-2.0
Shockli%2016340%20700mAh%20(Yellow)-Temp-3.0
As usual small cells do not get that hot.
Shockli%2016340%20700mAh%20(Yellow)-CapacityTimeHours
Shockli%2016340%20700mAh%20(Yellow)-Energy
Shockli%2016340%20700mAh%20(Yellow)-PowerLoadTime
Shockli%2016340%20700mAh%20(Yellow)-TripCurrent
Shockli%2016340%20700mAh%20(Yellow)-Charge
Conclusion
This cell has good capacity for its size, but it is not for high current. The protection makes this suitable for replacing CR123 batteries in some devices.
Notes and links
The battery was supplied by shockli.com for review.
CR123A and rechargeable substitutes
Comparison to other LiIon batteries
Edited by: HKJ on 02/02/2017 - 12:33
Splott-Light
Splott-Light's picture
Last seen: 1 month 4 days ago
@ HKJ,
Many Thanks for you hard work.
I always refer to your tests before buying.
Cheers,
S-L Smile
Ouchyfoot to a New Member: Welcome CJ. Now you have to learn about buying an inexpensive flashlight and modifying it until it either blows up, or starts small fires on the moon…………
Hugh Johnson:
I, too, once lived a tragic and empty life. Then I found [portable] light.
You forgot to mention clothes. I sold most of my clothes to fund my light collection. This is actually fine, since I only go out after dark, and most people can’t see me.
Finally, I got my priorities straight.
Henk4U2
Henk4U2's picture
Last seen: 16 sec ago
Splott-Light wrote:
@ HKJ,
+1
I always think long and hard before I say something really stupid.
HKJ
HKJ's picture
Splott-Light wrote:
@ HKJ,
Cheers,
S-L Smile
Thanks, but I will probably soon be reducing my publishing rate.
I am testing my last cell in queue at the current time, except I got a few batteries by the post today. I have not looked at them yet, but they will add a few weeks. I do also have a few weeks of already tested batteries, but not published yet.
Of course I hope the above comments may get a few more request in this thread: http://budgetlightforum.com/node/40323 Big Smile
MRsDNF
MRsDNF's picture
Last seen: 5 hours 41 min ago
Thanks HKJ. Thumbs Up
rockhound42
rockhound42's picture
Last seen: 1 month 1 week ago
Thanks HKJ, was just about to start searching for info on these. Beer
Barkuti
Barkuti's picture
Last seen: 2 hours 59 min ago
No idea with regards to the cost of these, but I guess not cheap.
By the way, HKJ, we have an open discussion about soldering batteries with low temperature solders. Came to my mind it could be useful to have experimental results with regards to the actual health/performance/health impact inflicted by the soldering procedure thermal stress.
Take a peek here if you wish: Soldering (batteries, etc) … with Sn42Bi58, Rose's Metal and other low melting solders
Maybe a little “before” and “after” test batch on a handful of cell formats/chemistries? Wouldn't need to be very thorough, a few cells and a few low/high rate discharge graphs can bring us pretty decent information.
And thanks for another review. Smile
Cheers Party
Sofirn C8T and C8F reviews of mine
PMme for a tip Wink thanks
HKJ
HKJ's picture
I saw the thread. I do not really like that low melting point, 100C is very close to the temperature of a hot battery (Maybe it could work as an automatic disconnect Big Smile )
If you are careful and fast you can solder batteries with normal solder, without any damage to the batteries.
Barkuti
Barkuti's picture
Et tu, HKJ?
I believe it's easy to cause some sort of unwanted damage to a cell with standard electronics solders.
Honestly, if a battery's innards get above 90ish °C, it may well be about time to shut it down.
Auto-quoting me here:
Quote:
Packs with vertical cells connected with Rose's Metal would be very safe, as the tabs underneath would readily detach at 98+°C in case of overheat emergency.
What about that stuff? Solder wire low melting point 124C 1m/1mm Bi55.5 Pb44.5 alloy good desoldering @valentinas33
Cheers Party
HKJ
HKJ's picture
Barkuti wrote:
Et tu, HKJ?
I believe it’s easy to cause some sort of unwanted damage to a cell with standard electronics solders.
Honestly, if a battery’s innards get above 90ish °C, it may well be about time to shut it down.
I did not say it was easy, but possible. The problem with testing this is how much do you heat the battery to get a good test.
During my test I sometimes heat the battery to above 80C on the surface, this is considerable hotter inside.
This means I already have some numbers showing how a battery that has been hot and delivered a lot of current will perform. My 10W power test is performed after the 20A/30A test and I have capacity and energy values in my logfiles.
VTC6 at 3A discharge: 2.94mAh 10.60Wh
VTC6 at 10W discharge: 2.85mAh 10.31Wh
Above is for the B cell where I measured 91C after the 30A discharge
If there is interest I can dig out the numbers for a few more cells, but ask in the other thread.
Stereodude
Where are these sold? I have a weapon light that uses CR123A (Olight PL-1 II Valkyrie) and am looking for a 16340 rechargeable for it with maximum runtime. These look to fit the bill.
I can’t find them for sale though.
