Voltage sag under load - Some figures
9 posts / 0 new
old4570
Last seen: 4 days 7 hours ago
I thought I would note some voltage sag figures ..  Used 4 batteries
Trustfire Flame 18650
Yezl 18650
Xtar 2200
Ultrafire BRC3600
I discharged at 1A - 500mA and 200mA to see battery voltage sag at various loads ..
Measurements were noted at 15 seconds , 30 seconds and 60 seconds ...
@ 1A the largest amount of battery sag noted was to 3.72v , that's almost half a volt [ 0.46v of sag ]
          Brand                 Starting Voltage             1A Discharge
Trustfire 4.21 3.81v-15sec, 3.78v-30sec, 3.75v-60sec
Yezl4.2 3.93v-15sec, 3.9v-30sec, 3.89v-60sec
BRC 36004.18 3.73v-15sec, 3.72v-30sec, 3.72v-60sec
Xtar4.19 3.9v-15sec, 3.9v-30sec, 3.87v-60sec
          Brand                 Starting Voltage             500mA Discharge
Trustfire 4.19 3.99v-15sec, 3.99v-30sec, 3.96v-60sec
Yezl4.19 4.05v-15sec, 4.02v-30sec, 4.02v-60sec
BRC 36004.19 3.87v-15sec, 3.87v-30sec, 3.87v-60sec
Xtar4.2 4.08v-15sec, 4.08v-30sec, 4.06v-60sec
          Brand                 Starting Voltage             200mA Discharge
Trustfire 4.19 4.11v-15sec, 4.11v-30sec, 4.11v-60sec
Yezl4.2 4.16v-15sec, 4.15v-30sec, 4.14v-60sec
BRC 36004.19 4.11v-15sec, 4.11v-30sec, 4.11v-60sec
Xtar4.19 4.14v-15sec, 4.14v-30sec, 4.14v-60sec
 Updated = Going the other way ...
 Time to charge the batteries ...
Ive gone with the BRC3600 [ since this is time consuming ]
1A charge rate :
Batt resting Voltage = 3.62v  [ after 1A discharge to 3v ]
Put on the charger , and after the charger reached 1A  the voltage reading from the charger was 4.06v , if its the battery voltage , then thats a 0.44v increase .
[ There must be some voltage overhead - higher charge voltage than batt voltage , but what is it ? = will have to test for this as time permits ] [ buy data logging MM ]
500mA Charge
Batt resting Voltage = 3.64v [ after 1A discharge to 3v ]
Put on the charger , after charge current reached 500mA , the voltage reading from the charger was some 3.96/7volts  , a 0.32v increase
200mA Charge
Batt resting Voltage = 3.66v
Put on the charger , after reaching 200mA , voltage reading was 3.85v , after 60 seconds 3.83v and after 90 seconds 3.82v  [ well that was different , voltage actually dropping under charge , one possible reason comes to mind , = the battery had been rested after discharge - takes a long time to charge @ 200mA - so wanted to do most of it while I slept - so it may have initially resisted charging [ more than usual ] , but as the current flowed into the battery the resistance dissipated and the voltage dropped ] = I could be wrong !  [ so related to storing a discharged battery for several hours - Like 10 ]
Charge VS Discharge
1A - Discharge =  - 0.46v  , Charge =   +0.44v
500mA - Discharge =   -0.32v , Charge =   +0.32v
200mA - Discharge =   -0.08v , Charge =   +0.16v
Hmmm , interesting .
 Always remember , the easiest thing in the world to do , is to expel hot air from your lungs and through some vocal chords ..
The resulting sound may , or may not be worth listening too ….
Edited by: old4570 on 11/01/2011 - 18:58
2100
Thanks, that's why the regulated lights would give higher current readings for some batteries.
viffer750
Last seen: 1 year 11 months ago
Sag depends on internal resistance of cells mostly. If the discharge current exactly 1A, and you measure the sag whitin 1-2sec, you  get the internal resistance. Sag= internal resistance.
I use 3-5 watt low value(2-5ohms) resistances for measuring internal resistance usualy. There are a couple of methods to calculate the internal resistance value, you have to use simply Kirchhoff and Ohm's law.
unique engrish language... Smile
old4570
Unfortunately I cheap'ed out on the Hobby charger , 1A Max Discharge ...
ATM Im looking at spending money on a data logging Multimeter ...  Maybe the last purchase for 2011 , Ive spent plenty in the last month or so .
JHBUDGETLIGHT
Last seen: 6 months 1 week ago
Thanks for providing the test results, very helpful information.  Would you happen to have 26650 batteries to compare?
-JH
Hikelite
Last seen: 8 months 6 days ago
-JH
Yeah, that would be nice.
old4570
No 26650 batteries [ in my collection ]  , though there have been some tempting lights lately for that battery .
old4570
1A charge rate :
500mA Charge
Charge VS Discharge
1A - Discharge = 0.46v  , Charge = 0.44v
500mA - Discharge = 0.32v , Charge = 0.32v
old4570
200mA Charge
Charge VS Discharge
200mA - Discharge = 0.08v , Charge = 0.16v
