I am looking for a budget flashlight and I really like these two . I am just not sure if either of those will fit Fenix or Nitecore 2300Mah (only two I can find in India from a reliable source).
IF not then can you please suggest a 18650 flashlight close to 900 lumens for under $20 that will?
I don’t have any 2300 mAh cells, but I do have six Fenix ARB-L2P protected 3200 mAh 18650 cells, and they fit my three Convoy S2+ Red lights. Some combinations of light and cell are a little tight, so I have to rotate the cell until it drops smoothly into the tube without being forced.
Unfortunately, there’s always a little manufacturing variance in both lights and cells. I think the inside of the S2+ tube is very slightly oval in cross-section, and this type of protected cell is wider where the connection strip runs down the side, so the fit is best when the cell and tube are aligned.
@Lexel: you have to use the NaOH? You can’t just start off with the sandpaper?
I have been a bit apprehensive about buying Panasonic ones as I can only find them here on amazon and ebay but that one on KaiDomain looks decently priced (fenix and nitecore here are for $11 and $13). I suppose I will get that one and couple of S2+ for now _
