Recommend: Svelte, lightweight mule
Guys,
I get a lot of use out of mules and their broad and absolutely uniform beam patterns. Primarily because around the house, the things I light up are close (around a meter) and cluttered (did I mention my house?) So I’m looking for a recommendations I can research. I’d like these features:
  • Compact, easy to grip body
  • well-spaced out levels from (near)moon to 1K lumen (I wouldn’t be using the high end much or for long)
  • 18650 cell, natch (I have a bunch of these lying around)
  • switch position, not really sure/critical. I find mechanical tailcap switches faster and more sure to locate and activate but I do like some “intelligence” in the control scheme although I really don’t want a ton of levels or complex tap-tap or programming schemes to switch levels or modes
So what do you think? The Sunwayman T26C in the A&A weekly caught my eye but the opinion seems to be mixed. What else ought I be considering?
Thanks for your help!
Wilkey
Zabralight
They got multiple mule headlights
http://www.zebralight.com/H603w-18650-XHP35-Headlamp-Neutral-White_p_182.html
For normal lights they got XHP50 with frosted lens which is a good flooder but no mule
http://www.zebralight.com/SC600Fd-Mk-III-Plus-XHP50-Floody-Neutral-White-18650-Flashlight_p_188.html
