FS: 1100 Lumen XP-L HI Rebel Mag Thrower!
Using Cree factory dedomed XP-L HI emitters in combination with the longer Rebel reflector…
The result is 1100 lumens in a super tight hot spot and amazing throw… :sunglasses:
From Cree datasheet: “The XP-L High-Intensity LED is the first single-die LED to deliver over 100,000 cd in a 4-degree beam”
Video Demonstration:
That palm tree you see when I pan to the right is 200 yards away… :sunglasses:
Trusted seller?
You can read any one of my threads to see that I am a trusted seller. For example, in the case of my 2D sized 1000 lumen Maglite flashlight mod, please take a few minutes to read some of the buyer feedback that I have listed here: (to see that I am a trusted seller)
Buyer Feedback
Here’s a few pictures of the build…
Features:
* XP-L HI factory dedomed emitter on copper sink pad
* Custom heatsink
* Rebel reflector (longer)
* Multi-mode, user select 3 Amp driver (see below)
* Mag head turns for fine focus adjustment
* Super tight hot spot
* Long throw
Emitters:
The emitters are mounted onto a 10mm copper MCPCB…
Shown in the pictures, is 5000K… (my choice)
I have some 5000K XP-L HI emitters on hand, but when back in stock I can also get:
3000K 80+ CRI
4000K
5000K (neutral)
6500K (cool white)
Driver:
3 Amp (high mode) linear driver with low voltage protection…
Low voltage protection: At 2.9-3V the light will switch to an emergency low mode.
You’ll love the Guppydrv option for this driver which allows the choice of 22 different ’mode group’ settings for the ultimate in user customization. (see link below)
I like mode group 12 which gives me 4 brightness settings, plus strobe and beacon - with memory.
Here’s the driver I’m using: (also shows the mode groups for the Guppydrv option)
Perfect driver…
3D option:
Shown above is a cut down ‘Stubby’ single cell size using a Feilong 6000mAh 32650 Li-Ion cell.
I stock these here…
Another configuration that would be perfect for this driver is a 3D size using 3 X D sized NiMH cells…
Pricing and Options: (let me know your initial choice of the driver mode group and I can set it for you when I test your light)
3D Size XP-L HI Rebel Mag Build:
The complete XP-L HI Rebel Mag 3D will include:
* 3D Maglite host (let me know your color choice)
* Switch prep
* Rebel reflector
* Heatsink/driver/XP-L HI emitter installed and tested (let me know emitter choice)
* Assembled and ready for your NiMH cells
$144
* Shipping will be based on a handling fee plus postage. (send PM for total)
Stubby:
The complete XP-L HI Rebel Mag ‘Stubby’ will include:
* Maglite host (let me know your color choice)
* Switch prep
* Rebel reflector
* Host mod - ‘Stubby’
* Assembled and ready for your Li-Ion battery
$169
Options:
* 6000mAh 32650 cells - $24 each
* Charger: WF-188 or TrustFire TR-008 - $29 (availability)
* Fiber glass battery sleeve and tail cap mod if using a 26650 - $15
Hope you like it! :slight_smile:
Ooohhh, you dirty fella you…your sig is just horrible!!! :person_facepalming: It’s trying to take money from me :money_mouth_face: I’ve always wanted a good laser…
Please explain in layman’s terms how involved it would be to make one of your lasers operable? pictures would be ideal.
thanks
Ha ha! This flashlight build is almost like a laser… :slight_smile:
My laser kits have options as you read the threads. Complete minus diode…
I can recommend what kit for the diode you want, proper safety glasses, etc…
With a kit from me, and a diode from DTR, it’s just a matter of soldering your diode leads to my leads in the kit. (less than 5 minutes)
Diodes here…
Bump
Video added to the original post… :sunglasses:
Amazing. Very tempting!!!
Just let me know when your ready! :sunglasses:
