Lumintop SD26, EDC25; Nitecore NU30 - really nice price (CLOSED)
167 posts / 0 new
tatasal
Last seen: 33 min 36 sec ago
Edit: April 2 – This activity is Closed.
Video review of the EDC25 by vestureofblood: http://budgetlightforum.com/node/53407
Review by zeremifico: http://budgetlightforum.com/node/53431
EDIT: Mar 14: Code for NU30 available via request by posting here
EDIT: FEB. 17: Code for both lights now available, Guaranteed, lowest price, just post here and ask
EDIT: FEB. 16: SD26 code is available; EDC25 to sent when available (due to system glitch)
BOTH CODES WILL BE SENT TO ALL POSTERS IN THIS THREAD THAT ASK FOR CODE AS IT BECOMES AVAILABLE
SD26: http://www.lumintop.com/sd26.html
Main Features:
● Utilizes CREE XP-L HD LED, boasts max 1000Lm output, 10600cd peak beam intensity and 205m far throw distance
● Intelligent Li-ion battery charging circuit, integrated micro USB charging port is water, dust and impact resistant
● Advanced temperature regulation system allows for adjusting output performance according to body temperature
● Lock-out: at Moonlight mode, long press for 8s, the light turns off and flashes indicating lock-out, cut off the power to unlock
● Waterproof in accordance with IPX-8 ( submersible to 2 meters )
● Runs on 1 × 26650 battery or 1 × 18650 with adaptor ( NOT included )
● High strength aerospace aluminum alloy construction with anti-scratching type HAIII military grade hard-anodized finish
● Double-side AR coated tempered lens resists impact and thermal shock, maximizes light transmission up to 99pct
● Reverse polarity protection / memory function / anti-rolling design / dual spring-loaded impact absorption mechanism / tail stand
Output and Runtime:
Turbo: 1000 – 600Lm, 1.66 – 3.33h
High: 530Lm, 4.5h
Mid: 170Lm, 18h
Low: 45Lm, 60h
Moonlight: 1Lm, 45 days
Strobe / SOS / Aviation Signal: 1000Lm
EDC25: http://www.lumintop.com/lumintop-edc25.html
Main Features:
● Uses Cree XP-L V5 LED with a lifespan of 50000 hours, max 1000 Lumens
● Hidden Micro USB charging port, red and green indicators display charging process
● Easily change between Tactical and Outdoor settings
● 6 variable modes: Low – Mid – High – Turbo – Strobe – Moonlight
● Tactical tail switch with momentary-on function
● Side switch to select outputs under Outdoor mode, only capable of mode changing under Tactical mode
● Low-voltage indicator is built into side switch, it flicker faster with lower power
● Automatically changes to LOW mode when remaining battery is too low, and gear cannot be changed
● Digitally regulated output maintains non-flickering constant brightness
● Optimized ultra-precise reflector offers 205m far reaching beam
● Double-side AR coated tempered window resists impact and thermal shock, maximizes light transmission up to 99pct
● Powered by 1 × 18650 or 2 x CR123A battery ( not included )
● Memory function / reverse polarity protection / stainless steel clip / anti-rolling and anti-skidding design
Note: flashlight can not be charged when using CR123A batteries
Edited by: tatasal on 04/01/2017 - 21:59
Bruno28
Last seen: 1 hour 20 min ago
Interested in the SD26
sandanbob
Last seen: 3 hours 37 min ago
Put me on the “interested” list, please.
Tom_182
Last seen: 10 hours 25 min ago
Interested…
eric800
Last seen: 1 week 3 days ago
interested in both.
kotobuki
Last seen: 2 hours 36 min ago
Interested in both.
jurasik1
Last seen: 4 hours 28 min ago
Interested SD26 Smile
Sukoi
Last seen: 3 days 5 hours ago
interested in both, thanks
Remster
Last seen: 7 months 2 days ago
Interested in both. Smile
tzmxxhh
Last seen: 5 days 5 hours ago
Lexel
Lexel's picture
Last seen: 39 min 29 sec ago
are there NW or XPL HI versions availiable or is it easy to modify?
tatasal
Hopefully later today l will receive the codes. Beer
LightRider
LightRider's picture
Last seen: 1 month 4 weeks ago
I would like to see your price for the sd26:)
carmantl
Last seen: 12 hours 16 min ago
Interested in both, price depending, thanks!
Tumbleweed48
Last seen: 1 hour 14 min ago
I would also like to see the price for the SD26 please.
tatasal
Mail s will be sent most probably today…
korpzgrinda
korpzgrinda's picture
Last seen: 20 hours 34 min ago
Location: Eastern Woodlands in the Wilderness of North America
details when available please
Dirt
Last seen: 1 hour 9 min ago
Sd26 please!
tatasal
Code for the SD26 to be sent out first….
EDC25 code cannot be generated at the moment due to system glitch.
Muto
Last seen: 4 hours 18 min ago
Interested in both, price depending. Thanks!
Call ‘Em as You See ‘Em
Beware of the Great Grifter
tatasal
Mail sent, and to all those listed above your post. Beer
syracuse
syracuse's picture
Last seen: 6 hours 11 min ago
I’m interested in SD26.
tatasal
Mail
DEL
DEL's picture
Last seen: 27 sec ago
That SD26 looks very tempting.
Thanks tatasal!
tatasal
Thanks tatasal!
Mail
LightRider
Ordered. Thanks! Price is amazing!
tatasal
Thumbs Up
p31
interested sd26
Boaz
Boaz's picture
Last seen: 10 min 53 sec ago
Interested in both… thanks for this
LightRider
I’ll give you props again. Great price on sd26! Beer
tatasal
Thumbs Up
Code for both lights now available. Just post to request for it.
