Manker E01 troubleshooting
6 posts / 0 new
sbslider
Last seen: 23 hours 16 min ago
I received a Manker E01 open box item today, and it is immediately obvious why the item had been returned previously. The light works properly only in a very small rotation angle of the head, maybe 5-10 degrees. Any more tightening and the light shuts off or skips modes. When I first started looking at the light, i thought maybe the contact surfaces were dirty. I had another new light recently that just needed some cleaning and has worked flawlessly since. So I started to clean the positive contact on the PWA, and realized I was backing out the driver and emitter with my q-tip. Obviously this needs some work.
I also noticed that the body to head connection threading seems rather sparse. By that I mean in less than two body rotations I go from two separate pieces to light on, then 10 degrees more and the light does not work properly.
Of course I can just return the light (amazon), but if it seems like there is a simple way to fix it I would prefer to keep it. Advice on how to do so welcome.
sbslider
So with some cleaning and tightening the driver board assembly into the bezel (not sure I got these terms right) the light is much better, but still in need of improvement. When I disconnect after low, it often jumps modes and so I don’t end up on medium next.
I am assuming that the battery positive contact makes contact with the board first, then tightening the body to the bezel brings the battery negative to the board via the body tube. I am considering trying to smooth out the body tube via emery paper or even denim jeans to improve the mate and unmate by smoothing a bit.
thoughts?
thanks!
Streamer
Streamer's picture
Last seen: 4 days 11 hours ago
Is there any sloppiness/wobbling side to side in the threads that mate head to body? This can cause poor/intermittent switching response. If there is, a wrap of teflon tape around the male threads has fixed this issue for me numerous times.
hank
hank's picture
Last seen: 10 hours 36 min ago
I recall in the original thread about these, I mentioned that the two I bought had this intermittent misfeature — loose head, loose parts, dirty threads.
Once I cycled the lights through a great many twist-on-offs, most of the problem went away. I blame rough parts and poor electrical connection.
Add some conductive lubricant after you wear the rough spots off the metal.
sbslider
Thanks Hank and Streamer for the feedback! It definitely has a wobbly side to side in the threads, I can turn the light off and on just by putting pressure on the head. I will try teflon tape when I get home tonight. I will first try to remove all the silicone grease I applied to the threads.
As far as conductive lubricant goes, I applied some silicone grease, that did not seem to help a bunch. It mostly seems once I got the electronics fully seated in the head (or bezel?) that turning on got much better. But it still seems to skip often when I turn it off. I am thinking the eliminating the side to side rock with teflon tape with help that, and the tape will also serve as a lubrincant. Not sure why the lubricant here would need to be conductive, as I am pretty sure the current flows through the bare aluminum at the end of the body.
sbslider
Yes, the teflon tape has improved the use even more. I suspect between just using the light and the teflon tape I have it about as good as it gets. I can operate it with one hand now, its not perfect but for $9 I think it is a keeper. I do like the light color, my first nichia emitter.
