Thermal paste
79 posts / 0 new
dealgrabber2002
Last seen: 1 hour 1 min ago
Thermal paste
What kind of thermal paste do you use? I recently bought artic silver 5, after read raving reviews about it. But it takes too long to cure. I let it set for 24 hrs. and it still not cured.
robo819
robo819's picture
Last seen: 2 days 11 hours ago
The artic silver 5 does not get hard if that is what you are asking…..you will have to use a thermal adhesive of some sort if you want the stuff to harden.
Click any link to see MY REVIEWS:
Maxtoch M24 Sniper / Maxtoch 2X Shooter (2016 factory dedomed) , 2X - XHP 70.2 / Maxtoch Xsword / M1 Archer *** ### ThruNite // Archer 2A V3 / Ti4T / TN4A HI / TH10 / TH20 / C2 Mini / TC12 V2 / T01 /  , neutron 2C V3 , TC20 / Catapult V6 / TC15 / TC15 CE *** ###  Olight // H2R Nova , S10R III / S30R III / H1 Nova / H1 R Nova / X7 Marauder , PL Mini ,  M2R warrior //// Orca T11 / Nitecore EC20 / BLF A6 / Custom Convoy C8 / Lixada Triple 3800LM / Lixada 1000LM / LuxStone X30 / Manker E02 / Manker E14 II /  ### Thorfire /// PF03PF04 , Upgraded PF04 , C8 , S-50 ,  VG-10 , VG25 , C8s , BL30 , TK4A  , S1 , VG15 S  , TK 18 //// ##WowTac// A4 , A1 (original) , A2 headlamp , A3 //// Acebeam L16 /// Massdrop (Lumintop) Brass EDC
Benjy
Last seen: 2 years 4 months ago
If you want glue I can recommend the Stars 922 thermal glue.
I use it to glue COB LEDs to aluminium heatsinks and it works like a charm: cures after a day and is relativley easy to remove if you made an error.
I could not even guess the thermal conductivity, but in my logic the thin layer does not even matter in thermal transfer.
dealgrabber2002
RotorHead64
RotorHead64's picture
dealgrabber2002 wrote:
http://www.ebay.com/itm/261967811200 What about this one?
That stuff would be fine for low amp draw but if your going to be pushing over one amp you'll probably be better off getting the arctic Silver thermal adhesive. it's a 2-part epoxy. it will set in about 10-15 min depending on temp. 75% cure in probably 6 hrs.
Enderman
Enderman's picture
Last seen: 23 sec ago
I use MX-4, but in the future I might switch to coollaboratory liquid ultra because liquid metal performs a lot better than regular thermal pastes.
Also, thermal paste like AS5 or MX-4 is not supposed to cure. Dried up thermal paste = bad performance.
Lightbringer
Lightbringer's picture
Last seen: 3 hours 41 min ago
Ain’t supposta. I use AS5 all the time. Needs a few hot/cold cycles to really get into its groove (burning off volatiles), but after that, it’s supposta stay fluid.
If you want something to “cure”, use a 2-part epoxy/adhesive, but consider that permanent. As in you’ll have to dremel off the part and leftover epoxy to get it off.
Fujik is good for when you need something rubbery to “stick” a star to a pill, ferinstance. But it isn’t as effective as AS5.
Great middle-ground between performance and permanence.
Eg, I need to mount small resistors between taillamp assy and car body to fix so-called “hyperflash” after replacing hotwire bulbs with LEDs. No way am I going to epoxy it into place, and AS5 would let it just slide off after a while. Fujik will keep it in-place but only semi-permanently.
So which you use (goop/epoxy/caulk) depends on your application.
dealgrabber2002
Darn. Lol. Bought the wrong stuff
Rufusbduck
Rufusbduck's picture
Last seen: 10 months 2 weeks ago
Some people use AS-5 or other paste under and adhesive at the edge. This gives a high performance thermal bond that is fixed yet easier to remove than adhesive alone.
Scott
Lexel
Lexel's picture
Last seen: 21 min 48 sec ago
+1 for that
I used Arctic silver 5 in the middle of my Convoy S2+ and Eagle Eye X2R and arctic silver 2 component on the edges
Liquid metal is not good on aluminum as it corrodes it
In the next days I get special solder that is advertized that it can be soldered on aluminum, that should be the best heat transfer possible
Soldered star to brass pill shows how good it is as it gets a lot harder to solder the wires back on the star
Lightbringer
That’s fine. Just send me your leftover AS5. I’ll give it a good home. Big Smile
Lopan
Last seen: 1 hour 24 min ago
Lexel wrote:
In the next days I get special solder that is advertized that it can be soldered on aluminum, that should be the best heat transfer possible Soldered star to brass pill shows how good it is as it gets a lot harder to solder the wires back on the star
Are you talking about Stannol ALUSOL? I’m really interessted in the results.
Rufusbduck
SRA soldering products has this Al26-181-75 aluminum to aluminum, aluminum-copper soldering paste. Melts at 217C(423F)
Scott
fenno
Last seen: 1 year 3 months ago
The best thermal paste at the moment is “thermal grizzly” and not Arctic Silver 5! Facepalm
Lightbringer
Kinda spendy, though, for marginal benefit (a couple of °C).
If you need the absolute best, by all means. But wow, I got sticker-shock the first time I priced TG.
BlindingL5s
Last seen: 1 month 3 days ago
I’ve had good results myself using Arctic Silver Ceramique 2.
scianiac
scianiac's picture
Last seen: 7 months 2 weeks ago
Normally I use MX-4 unless I need something for a super special applications, MX-4 has a great balance of performance and price. Also use a gallium alloy TIM when I can. If I recall pastes normally work better than epoxies given a good level of pressure. Pressure is often just as important as the TIM you use.
Co-owner/Engineer at STO Flashlights.
Enderman
Enderman's picture
Yup, I would highly recommend using a thermal paste + screws rather than a thermal epoxy.
Better performance, easier to swap out LEDs, and less damage.
Lexel
Lexel's picture
I will get tomorrow most likely my aluminum solder stuff
If it works like this I will solder stars to aluminum head
The flux residue has to be removed with water as it is corrosive
Enderman
Enderman's picture
Well, when trying to solder it to something that is intended to be a heatsink it will be really hard to get it to melt…
Make sure you have a 60W or more soldering iron and remove all drivers/o-rings/plastic from the light before you heat it up to 200C+
Since a flashlight is built like a heatsink, getting the head to 200C will probably make the rest of the body sit at over 100C.
The Miller
The Miller's picture
Long ago I tweaked my PCs
Water cooling and high end stuff
Arctic silver was the way to go
Then a completely overclocked PC with several water cooling loops and a real expensive video card was my pride and joy
It scored really high on several tests but alas it sprung a leak after half a year of operation.
While looking for what to build next I ordered a basic really cheap motherboard with onboard graphics that accepted my CPU.
It wasn’t long till I realised that despite much lower benchmark scores this setup did what I wanted and not feel slow.
So I waited a bit with ordering a new setup. I looked through my parts bin, and measured all components temps, stuck heatsinks on all that became hot.
Lol I had so much heatsinks just the silent fan of the power unit gave enough airflow to keep all cool.
Holy dang, this PC was silent and fast enough.
On top of that after half a year I received a letter from the energy company and got a refund twice asbhigh as the parts that I bought to get it going had cost me.
One of the things I bought with my order was a big syringe with cheap thermal paste
I did test it and compared to the Arctic silver it had my CPU 2°C higher at burnin tests.
But the stuff cost me FL2 (like €0,80 ~$1,10 ) for a huge amount where the Arctic stuff was ~$6,50 for a tiny amount.
I used it but it got lost during the move here, I ordered something similar for I think $1 or $2 on AliExpress and it works nice.
Enderman
Enderman's picture
Just fyi, heat is measured in watts not degrees, so 2C doesn’t really say how big the difference is.
2C drop on a 150W CPU is far more significant than 2C on a 50W CPU.
Also a big reason why you pay more for high quality thermal compound is so that it can last many years without drying, because when it dries then the performance drops.
Serp
Serp's picture
Last seen: 4 months 2 days ago
Enderman
Enderman's picture
Serp wrote:
HY710 http://www.banggood.com/20g-Silver-Thermal-Paste-Grease-Compound-Silicon...CPU-Heatsink-p-976846.html
The thermal conductivity of that stuff is absolute crap.
Buying good quality thermal compound like MX-4, NT-H1, IC-D will make a huge difference.
viffer750
Last seen: 2 years 10 months ago
That's true. In this price range the only useable paste is GD900. This stuff is almost as good as AC mx2- mx4.
unique engrish language... Smile
itsonlyme
Last seen: 5 months 3 days ago
How do thermal pads rate as a comparison? We use them for led modules/cob with an output up to 4000Lm.
We also use what looks to be a metallic type thermal pad which is extremely delicate and tears easily.
Enderman
Enderman's picture
Much worse.
Never use thermal pads if you can avoid it.
direct soldering > liquid metal > thermal paste > thermal epoxy > thermal pads > nothing(air) > insulator
Serp
Serp's picture
30g GD900 for $3.37 it is definitely a fake Smile
It is better to take in a blister from GD Official Store
https://gdbrand.ru.aliexpress.com/store/group/Blister-Packing/235415_254...
itsonlyme
Just to note, these thermal pads are used on lighting for shopping centres and are on constantly. 5 year warranty. Never had one fail yet.
May be worth a test and see how they do in a torch
itsonlyme
http://m.sg-thermal.com/Thermal-Pad/TCP5000_Premium_Thermal_Conductive_P...
Arctic silver 5 is 8.9 w/mk, the above is up to 50 w/mk or am I reading that wrong? Option to request a sample on the site. May be worth sending a sample to djozz
Enderman
Enderman's picture
Often in manufacturing it is simpler and cheaper to use thermal pads.
They do work, and usually it is fine because the cooling solution is more than what is necessary.
As long as the temps are within the rated operating range there is no reason to spend more money on higher thermal transfer.
In commercial applications you only spend what you need, the rest is profit.
For people who want the best cooling possible for their flashlight, then thermal paste is better Smile
