LUCKYSUN titanium alloy flashlight
18 posts / 0 new
LuckySun
LuckySun's picture
Last seen: 2 weeks 1 day ago
Hello guys
Our Manufacturer would like to produce a titanium alloy flashlight,
would you please give us some suggestions?
like Opinions on battery(one 18650 or 2 cr123A is OK?),LED, driver and so on….
thanks you so much…
LuckySun Manufacturer
blueb8llz
Last seen: 3 hours 37 min ago
I suggest one Similiar size to the d80 but with a easier to press switch. The d80 was very stiff. A xpl hi emitter.
Do you guys still make the d80? Where can I purchase for cheap?
LuckySun
LuckySun's picture
blueb8llz wrote:
I suggest one Similiar size to the d80 but with a easier to press switch. The d80 was very stiff. A xpl hi emitter. Do you guys still make the d80? Where can I purchase for cheap?
titanium alloy flashlight Similiar size to the d80? that may need much ti material.
If you still need old version d80 flashlgiht, you can buy it at amazon like the follow link
https://www.amazon.com/dp/B018BX8590
any question, please feel free to contract me.
thanks
bikenber73
bikenber73's picture
Last seen: 8 hours 52 min ago
I vote for a 16340/cr123 twisty. XPL-HI or XPG3. AR lense. Titanium is expensive. Sell more at a lower price point.
djozz
djozz's picture
Last seen: 1 hour 57 min ago
I like a lot of light output and I like titanium. But titanium is not good for heat-shedding, so I suggest a titanium flashlight with a middle-section of a different metal, like this Astrolux:
In the Astrolux the middle-section is made of copper, but I think copper is too heavy, so I suggest a (black anodised?) aluminium middle-section. This will work (almost) just as well, looks good is cheaper to make and is more lightweight.
I suggest a flashlight with a different shape as the Astrolux X6, I would prefer a flashlight with a smaller head and smaller reflector, tube shaped, or tube-shape with a slightly wider head.
LSX
LSX's picture
Last seen: 4 days 18 hours ago
I agree with blueb8llz one the size of the D80 would be great!! But with a smoother transition between the head and body.
There are a ton of 16340/18350 Ti lights already out there… SWM V10R Ti / M25C Ti, Niteye Eye10 TiC, Eagtac D25C Ti, BLF Ti, Jetbeam TCE-1 / TCR20, Olight S1 Ti, Manker Timeback… the list goes on. I feel you would have to do something extremely special to make it stand out in that company and I just can’t see it happening.
My biggest suggestion would be to keep it simple. Don’t go over the top with cutouts everywhere, lines, different textures etc..
hIKARInoob
hIKARInoob's picture
Last seen: 9 min 44 sec ago
TC4 alloy please, and 18650 size. Copper head would make it super awesome! Thank you very much for asking Wink
Bc412
Last seen: 11 hours 49 min ago
Do a single 16340 with an extension tube for 18650 so you can purchase separately to keep initial cost down.
And a good pocket clip!
I’d also love to see an optic rather than a reflector. Something with good low modes for up close work
LuckySun
LuckySun's picture
djozz wrote:
I like a lot of light output and I like titanium. But titanium is not good for heat-shedding, so I suggest a titanium flashlight with a middle-section of a different metal, like this Astrolux: !http://img1.banggood.com/thumb/view/oaupload/banggood/images/D3/F4/18b43...! In the Astrolux the middle-section is made of copper, but I think copper is too heavy, so I suggest a (black anodised?) aluminium middle-section. This will work (almost) just as well, looks good is cheaper to make and is more lightweight. I suggest a flashlight with a different shape as the Astrolux X6, I would prefer a flashlight with a smaller head and smaller reflector, tube shaped, or tube-shape with a slightly wider head.
thanks djozz, do you prefer PWM or PFM? if it is PWM, what the frequency you require? thanks for your suggestion.
djozz
djozz's picture
I prefer PWM over PFM because at the lower modes the lowered frequency of PFM could become visible and audible. The PWM frequency should preferably be over 10kHz, but I understand that some type of drivers become inefficient at that high frequency. I think that most people prefer efficiency over high frequency. But the PWM frequency should certainly not be lower than 4kHz!!
LuckySun
LuckySun's picture
djozz wrote:
BLFD80 wrote:
djozz wrote:
I like a lot of light output and I like titanium. But titanium is not good for heat-shedding, so I suggest a titanium flashlight with a middle-section of a different metal, like this Astrolux: !{width:15%}http://img1.banggood.com/thumb/view/oaupload/banggood/images/D3/F4/18b43...! In the Astrolux the middle-section is made of copper, but I think copper is too heavy, so I suggest a (black anodised?) aluminium middle-section. This will work (almost) just as well, looks good is cheaper to make and is more lightweight. I suggest a flashlight with a different shape as the Astrolux X6, I would prefer a flashlight with a smaller head and smaller reflector, tube shaped, or tube-shape with a slightly wider head.
dear djozz,  what LED(or battery) maybe better if we make ti flashlight, XHP35, OR XHP35 HI? ORXPL HI? and the battery? thanks for all your suggestions,
djozz
djozz's picture
BLFD80 wrote:
djozz wrote:
BLFD80 wrote:
djozz wrote:
I like a lot of light output and I like titanium. But titanium is not good for heat-shedding, so I suggest a titanium flashlight with a middle-section of a different metal, like this Astrolux: In the Astrolux the middle-section is made of copper, but I think copper is too heavy, so I suggest a (black anodised?) aluminium middle-section. This will work (almost) just as well, looks good is cheaper to make and is more lightweight. I suggest a flashlight with a different shape as the Astrolux X6, I would prefer a flashlight with a smaller head and smaller reflector, tube shaped, or tube-shape with a slightly wider head.
Hi BLFD80, I can not really answer that question, if you ask 20 people here on BLF what led and battery this light should have, you will get 20 different answers.
I can only give my personal opinion, and many will disagree with me. My personal favourite titanium flashlight would be 18650 battery powered with a XP-L Hi led (XHP35 could only be interesting when driven to 2000 lumen output, but a small 18650 light will not handle the 25W of heat that it produces, even for a very short time), the battery tube slim tube-style with slightly enlarged head (say 30mm diameter) and a widened ring (also 30mm) near the tailcap machined as one piece with the battery tube (‘tactical ring’ for grip).
LuckySun
LuckySun's picture
djozz wrote:
Hi BLFD80, I can not really answer that question, if you ask 20 people here on BLF what led and battery this light should have, you will get 20 different answers. I can only give my personal opinion, and many will disagree with me. My personal favourite titanium flashlight would be 18650 battery powered with a XP-L Hi led (XHP35 could only be interesting when driven to 2000 lumen output, but a small 18650 light will not handle the 25W of heat that it produces, even for a very short time), the battery tube slim tube-style with slightly enlarged head (say 30mm diameter) and a widened ring (also 30mm) near the tailcap machined as one piece with the battery tube ('tactical ring' for grip).
thanks djozz and other BLF guys, i will tell all the informations to our factory Engineers, we will let you know the progerss of the new flashlight.
BazzH
Last seen: 1 day 4 hours ago
AFAIC: 18650, PWM, Just moon-low-med-huig, no strobe, no bells and whistles, not even hidden. Metal clicky at tail, tail standing, room for 1,5×6 trits. LED: 5500K Cree or Nichia. Not concerned with high CRI. Price below €50.
vwpieces
vwpieces's picture
Last seen: 3 days 10 hours ago
Agree.
itsonlyme
How about posting a few renderings here when your engineers have created some designs?
teacher
teacher's picture
Last seen: 9 hours 39 min ago
1 × 18650
      You never know how a horse will pull until you hook him up to a heavy load. / Paul "Bear" Bryant ~/~\~ "Slow is Smooth, Smooth is Fast"
       Texas Lumens Flashlights  <>   M4D M4X Deals : sign up - save $$$$    ||||   Confucius say -- Baaa-haaaaaa......   tongue-out
         Rudeness Level /\ mΩ /\ {width:70%} /\ LightWiki /\ LED Tint Chart /\ LED Tint Picture /\ Xlamp size chart /\ BatteryU                   Flashaholic? Need Professional Help???   wink   /\ TheOriginal /\ TAB /\ LightSearch /\ BatterySearch /\ 14500's /\ DiCal
nqcken
Last seen: 1 week 1 day ago
1×18650 ti with cu
