titanium alloy flashlight
12 posts / 0 new
LuckySun
LuckySun's picture
Last seen: 2 weeks 1 day ago
Hello guys
Our Manufacturer would like to produce a titanium alloy flashlight,
would you please give us some suggestions?
like Opinions on battery(one 18650 or 2 cr123A is OK?),LED, driver and so on….
thanks you so much…
LuckySun Manufacturer
AlexGT
AlexGT's picture
Last seen: 1 hour 4 min ago
18350 with 18650 support xpl hi thrower with infinite brightness adjustment via ring.
tekwyzrd
tekwyzrd's picture
Last seen: 4 hours 31 min ago
Titanium battery compartment with a copper head. Compartmentalized tube could serve as reverse polarity protection and help isolate the lithium cells from the heat while the copper head would tranfer heat outward much more effectively than a ti alloy. Deep thin (but not too thin to resist bending) fins on the head to maximize surface area. Side switch with lighted battery state indicator and tail lockout. Programmable driver with user-selectable number of modes and ramping set levels for modes. Second switch for temporary turbo mode and signalling. Main and secondary side switches. When on depressing second switch puts light in turbo mode as long as it is held and when released returns to previous level. When off second switch illuminates to ramp set level as long as held for signalling.
tekwyzrd
tekwyzrd's picture
Or, for setting modes, user would enter programming mode, and after a flash quickly press the button to set the number of modes. Light flashes twice. Press button once. Light flashes. User presses button once, waits one second, then presses button six times to set first mode to 5%. Light flashes. User presses button twice for mode 2. Light flashes. User presses button three times, waits, and presses button six times setting second level to 25%. 1 press = 0.
LuckySun
LuckySun's picture
thanks all the suggestions. by the way do you prefer PWM or PFM? if it is PWM, what the frequency you require? thanks again
LuckySun
LuckySun's picture
tekwyzrd
tekwyzrd's picture
Prefer constant current but pwm at frequencies above typical audio range would work (around 20k). Just giving some ideas I’d like to see implemented. Still need to put myself through a refresher course on circuit theory and design but if someone else could build a light with those fearures sooner I’d buy it.
Bort
Bort's picture
Last seen: 2 hours 33 min ago
Go with the most common form factors, 18650 or AA NiMH.
The Journal of Alternative Facts TM
"It is critical that there is a credible academic source for the growing and important discipline of alternative facts. This field of study will just keep winning, and we knew that all the best people would want to be on board. There is a real risk in the world today that people might be getting their information about science from actual scientists"
-X3-
-X3-'s picture
Last seen: 4 hours 55 sec ago
If you want to keep it affordable, an AA form factor is the best choice.
The problem with AA lights is more about the driver, which has to be efficient in boost mode for Ni-Mh and handle 14500 Li-ion voltage at the same time…
"Hey -X3-, do you have a flashlight ?"   "-X3-, can I borrow one of your flashlights ?"
My Flashlight public album (mods, emitter swaps, eye candy)
My reviews channel (French language, Olight, Thorfire : 30+ lights tested)
My personal channel (including Olight SR mini, S1, S2, S1A and S-mini disassembly)
M4DM4X blog, saves you $$$
nqcken
Last seen: 1 week 1 day ago
I am really digging the ti body and cu head!
hIKARInoob
hIKARInoob's picture
Last seen: 7 min 27 sec ago
TC4 alloy please, and 18650 size. Copper head would make it super awesome! Thank you very much for asking Wink
derfyled
derfyled's picture
Last seen: 9 hours 28 min ago
A titanium double AA side-by-side, small as possible, NW or high CRI, a good clip and a slot to install a tritium vial and you got my money !
