18650 battery
37 posts / 0 new
deye223
deye223's picture
Last seen: 2 months 2 days ago
18650 battery
gday all I recently bought 3 of these torch’s for around the house http://www.gearbest.com/led-flashlights/pp_604347.html?
and much to my suprize they came with cells but there the ultrafire 3000mah 18650 http://www.ebay.com/itm/10-x-Ultrafire-Blue-3000mAh-18650-Rechargeable-l...
are these worth using or should I just bin them ? .
cheers D
Speed4goal
Last seen: 9 hours 22 min ago
In the bin, cells arnt 3000mah or even close lucky if they are 500mah. And are a fire risk. You never know what your going to get. If lucky a very old worn out laptop pull. Sometimes its smaller 10440 cells inside with sand around it to make it weigh right. Sometimes even smaller batteries then that. Just look at some of the disassembly threads of ultrafire 18650s.
They kind of remind me of energizer c and d nihm cells. Its just a larger battery case with a smaller cell inside
2/9 Fox Co (2009-2015) Semper Fi 0311/0331 Rifleman/Machine Gunner
Blf has changed a lot since I've been here. Lots of snow flakes and easily offended over nothing. When the forum use to be great and people joked around and could take a joke. It's a forum it's not that serious. Let's make BLF great again!
atbglenn
atbglenn's picture
Last seen: 1 hour 31 min ago
I agree with Speed4goal. Ultrafire batteries are as bad as they come. I’d get rid of them and get some decent cells like Panasonic, Sanyo, Samsung, LG, or Sony’s. I like Efest when it comes to 10440’s, 14500’s, 18350’s, and 26650’s because none of the brands I mentioned make those sizes.
deye223
deye223's picture
I figured as much just thought I would ask …… it’s a good thing I have some Sanyo NCR18650GA 3.7V 3500mAh on the way then .
atbglenn
atbglenn's picture
Excellent battery. I have several flat tops I use in single cell flashlights.
allcool
Last seen: 10 hours 28 min ago
Well, not so fast…
I, like many of us, have gotten many batteries with extreme cheapy lights. And yes, most all of them were worthless.
I like to test them in one of my li500 out on the patio, just to make sure they are junk. I always keep an eye on the temp and if they start to get hot I abort the test and can the battery in an ammo box for future recycling.
A month ago won a $1.78 light on eBay. Came with charger, uf battery, holster, bike mount, and a ultrafire e6.
Tested its purple ultrafire “5000mah 4.2v” battery and to my surprise it was a 3000 mah good battery as per my lii500. Tested it 3 times and all results came out the same, 3000 mAH. Popped it in my high draw light and it pulled 6+amps…!!! something many of my laptop pulls won’t do in that light. Been using it ever since. I consider it one of my better batteries.
So, might want to test those cheapy batteries that comer with cheapy ebay lights. Not often, but once in a while you might get lucky…
jmo
Angler
Angler's picture
Last seen: 7 hours 14 min ago
allcool wrote:
Well, not so fast…
jmo
Even though it performs satisfactorily for you, it likely does not have any PTC (pressure valve) or CID (current interrupt device) to protect against high pressure and over temperature. It is not possible to know unless you dissect one or wait until it explodes. These are internal cell parts separate from any protection circuit added to a “protected” cell. They are often left off of low quality cells like this to cut manufacturing cost, this is how they can be sold more cheaply than reputable brands.
An example that you can observe yourself – take a look at the button top on your cell, do you see any vent holes?
allcool
Angler wrote:
allcool wrote:
Well, not so fast…
jmo
Interesting, did not know that. Do all (any ?) laptop pulls (sanyo, samsung, sony,etc,) have CID/PTC..?
deye223
deye223's picture
ok I just looked at the add for my SANYO cells and they say that Panasonic make them
if so why would someone tell me that the SANYO cells are better ?
atbglenn
atbglenn's picture
They are listed here as Panasonic/Sanyo cells. Are Sanyo cells better than Panasonic? I have no idea to be honest. All I can say is I’ve been using Panasonic cells for years without issues.
deye223
deye223's picture
ok ….. I wish I could get them at that price as their $12 on average here .
Speed4goal
Panasonic owns sanyo, each cell has its own name. Panasonic’s 3400 cell is the NCR only good for around 6 amps. But sags heavily after 4 amps. The sanyos 3400-3500 cell is the sanyo GA. 10 amp rated cell. Its developed by sanyo, sanyo never recovered from a major earthquake and Panasonic owns it now. Might not see to many new cells with a sanyo label on it. Essentially they are the same company now. All the high drains are comparable. Sanyo/lg/Samsung 10amps you couldn’t tell a difference in the 3 lights you have. And the 20+amp cells are all similar. 30q/HG2/VTC6/ etc
You won’t go wrong with Panasonic or sanyo cells. I recommebrd the sanyo cells since they are the same price as the Panasonic outdated NCR B cells. And said if you ever get more powerful lights that draw over 3 amps you already have cells now for it. Panasonic makes good cells all the big manufacters do. Sanyos plant was hit during a massive quake. And just never recovered fiancialy completely. Panasonic bought them out to get their battery formulas and technology. They let sanyo keep operating with its name for the time being but that may change in the future.
Like Walmart and samsclub two different companies but both owned by walmart
bella-headlight
Last seen: 1 day 3 hours ago
To the OP I have 3 of these lights & for the money they are great little lights Thumbs Up
I tested the claimed 3000mah “crapfire” cells that came with them & got 600-800mah iirc & very high resistances & after charging voltage dropped like a stone Sad
They are very very poor cells.
I recycled mine.
Ian
deye223
deye223's picture
thanks all .
and thanks Speed4goal that sounds about right for these days so I will use what I have coming
and will get more for my c8 and 2 olight M3X and it looks like I will get another 2 or 3 c8 for
the money they are a great light + I ordered an OP reflector for around the house and yard .
cheers D
Angler
Angler's picture
allcool wrote:
Interesting, did not know that. Do all laptop pulls (sanyo, samsung, sony,etc,) have CID/PTC..?
Yes! Thumbs Up
deye223
deye223's picture
well this is getting interesting …….. I ran one of these cells down to 3 volts and then put it in
the charger and after 15mins it was at 74% so I thing this is one of them 3000mah cells that
hold 300mah haha .
EDIT charge rate is 1A
EDIT 2 it took 1 1/2 hours to charge so about 1100 to 1200 mah
deye223
deye223's picture
ok I was doing some research on batteries and because the ones I have coming are SANYO
NCR I found this …… the chemistry of the NCR is LiNiCoAlO2 so the question is can I charge
these on my XTAR SV2 Rocket charger as this is all that is listed Li-ion/IMR/INR/ICR not the
NCR cells .
cheers D
Speed4goal
NCR cells .
cheers D
Yes charge away. Any 3.6/3.7 lithium cell is fine. They charge up to 4.2 volt. Cells are rated by nominal voltage.
spinynorman
Last seen: 10 hours 44 min ago
I see one of the “tips” in the SV2 Rocket manual is to manually reduce the charge rate from 2A to 0.50A when the battery is “almost full”. I suppose this gives a more accurate termination point?
deye223
deye223's picture
hmmm now where is my manual
allcool
Angler wrote:
“An example that you can observe yourself – take a look at the button top on your cell, do you see any vent holes?”
Is this the vent holes you’re asking about..? There are 2 of them on opposite sides.
deye223
deye223's picture
spinynorman wrote:
I see one of the “tips” *+in the SV2 Rocket manual +*is to manually reduce the charge rate from 2A to 0.50A when the battery is “almost full”. I suppose this gives a more accurate termination point?
um I found it but it ain’t no good to me as it’s all in Chinese Angry
spinynorman
Reading the translation is half the fun of getting new Chinese product! The instructions don’t say you have to reduce the charge rate, it is automatic, but reducing it is a “tip”. Otherwise the instructions seem common to other charging practices. I’m pretty new to this and needed a faster charger for the 26650s in a couple of new lights I bought and I found the SV2 on sale. Cash
deye223
deye223's picture
I figured there was something going any was as it gets to 99% and then takes ages to finish
Pete7874
Pete7874's picture
Last seen: 9 hours 11 min ago
They’re all the same, made in the same factory. Sanyo has been a subsidiary of Panasonic since 2009. Sometimes they put Panasonic logo on the product and sometimes they put Sanyo logo, but it’s essentially the same product beneath the label.
Angler
Angler's picture
!{height:600px; width:400px}http://i958.photobucket.com/albums/ae68/allcool11/vent%20hole%20ultrafir...!
Thumbs Up Those are the ones! It doesn’t mean that the cell has internal protection, but a lack of them would indicate that it does not.
If you are using these in a light that draws 3 amps or more, you will certainly benefit from a better cell such as panasonic sanyo samsung sony lg.
Better meaning higher voltage under load, higher capacity, higher amp capability, lower internal resistance, resulting in more lumens.
deye223
deye223's picture
SANYO NCR18650GA 3.7V 3500mAh ……….?
ok my sanyo cells rolled up today and I must say they look very plane jane
now I know this don’t mean much but all the have is a white sticker on them
and one of them small square things that you read with your phone .
so does this sound right or are they knock offs .
cheers D
MRsDNF
MRsDNF's picture
Last seen: 4 hours 39 min ago
Where are you buying batteries from deye?
My current and or voltage measurements are only relevent to anything that I measure.
Budget light hobby proudly sponsored by my Mastercard and unknowingly paid for by a hard working wife.
djozz said "it came with chinese lettering that is chinese to me".
deye223
deye223's picture
MRsDNF
MRsDNF's picture
Can you post a picture?
deye223
deye223's picture
wish I could I have tried to use PB and another hosting sight and the pic will not display
EDIT it did take 3 hours and 15 minutes to charge them both today and they were within
2% of each other all the way to charged so I suppose they can’t be that bad .
and if you want a look here they are the same as these right down to the QR code
https://www.google.com.au/search?q=Sanyo+Li-ion+NCR18650GA+3.7V+3500mAh&...
