What is your favorite method of converting flat top batteries to button top?
35 posts / 0 new
lightlight22
lightlight22's picture
Last seen: 3 weeks 2 days ago
Neo Magnets
26% (27 votes)
Solder Blob
55% (58 votes)
Soldering a spacer
9% (9 votes)
Re-shrink w/ protection circuit
2% (2 votes)
Other...
9% (9 votes)
Total votes: 105
Don't give up on your dreams,
Keep dreaming.
mrheosuper
Last seen: 1 day 21 hours ago
a spacer, of course, especially when need high current
Forgot my pen
Lexel
Lexel's picture
Last seen: 4 hours 39 min ago
soldering a brass button
Jerommel
Jerommel's picture
Last seen: 1 week 8 hours ago
Solder blob.
Gives the largest contact surface because it’s relatively soft.
Here are some fresh ones (not yet used):
2Q19
keltex78
keltex78's picture
Last seen: 9 hours 2 min ago
Keepin’ the “B” in BLF
Don wrote:
It sounds like the XM LEDs won’t really be suitable for flashlight use. Pity…
teacher
teacher's picture
Last seen: 1 hour 1 min ago
Jerommel wrote:
Solder blob.
Those both look great guys. Thumbs Up
Jerommel, those are the best & most exact “solder blobs” I have ever seen!! Nice work……. Thumbs Up
      You never know how a horse will pull until you hook him up to a heavy load. / Paul "Bear" Bryant ~/~\~ "Slow is Smooth, Smooth is Fast"
       Texas Lumens Flashlights  <>   M4D M4X Deals : sign up - save $$$$    ||||
         Rudeness Level /\ mΩ /\ {width:70%} /\ LightWiki /\ LED Tint Chart /\ LED Tint Picture /\ Xlamp size chart /\ BatteryU                   Flashaholic? Need Professional Help???   wink   /\ TheOriginal /\ TAB /\ LightSearch /\ BatterySearch /\ 14500's /\ DiCal
deye223
deye223's picture
Last seen: 11 months 3 days ago
Jerommel wrote:
Solder blob.
!http://i67.tinypic.com/2nu3lag.jpg!
very neat mate Thumbs Up
Firelight2
Firelight2's picture
Last seen: 37 min 2 sec ago
I haven’t tried turning flat tops to button tops, but if I did, I would use the same method I use for making buttons for positive contacts on drivers:
1. Take a piece of sheet copper and cut a small disk using metal scissors.
2. Place cell vertically in vise.
3. Apply solder paste to top of cell
4. Place copper disk on top of paste
5. Use a toothpick to hold disk in position so it doesn’t shift while applying soldering iron to top of disk. The instant the solder melts remove iron.
6. If necessary, apply a second disk on top of the first for a taller button.
7. If necessary use a handfile and possibly steel wool to file the top of the disk completely flat and to remove any sharp edges.
firedome
Last seen: 2 weeks 5 days ago
I’ve when using neo 5mmx1mm or 1.5mm magnets. No need to glue or washers or any kind of spacer. Just center and load the whole assembly up. Most lights that need button tops have a non-conductive ring that surrounds the magnet.
“We can easily forgive a child who is afraid of the dark; the real tragedy of life is when men are afraid of the light.
-Plato
stephenk
stephenk's picture
Last seen: 19 hours 6 min ago
I vote for buying button tops in the first place. Wink
Are there any instructional videos on how to add solder blobs without causing explosions for soldering non-experts?
Jerommel
Jerommel's picture
It helps when you have developed some soldering skills of course.
But the flattop surface (of course) needs to be clean and without oxidation.
Do not sand the nickel plating off.
Use a hot iron of around 40 Watts.
Wet the tip with rosin core solder, put it on the flattop.
Add rosin core solder kind of between tip and top.
Add more when it starts to flow.
Move the tip over the surface of the top while adding more solder.
When it’s all flowed on the top (and you have put enough solder there), retract the soldering iron.
The solder will solidify in a nice dome shape.
This all should take no more than 4 or 5 seconds !
Maybe you can practice on tired old laptop pulls.
2Q19
teacher
teacher's picture
Good info Jerommel, thank you for posting it. Thumbs Up
My goal is to make mine look as perfect as yours do in your pics up in post #4. Smile
jf_smm
Other – I prefer to go from house to house and explain the peril their little battery souls are in if they don’t convert to button top ism Wink
Tjhosan
Tjhosan's picture
I use piece of solid core wire and bend it into a ring and give it a tap with a hammer to flatten it some. Then i just solder that to the battery.
teacher
teacher's picture
Nice one ‘Tjhosan’. Smile I never thought of that, thanks for sharing.
Tjhosan
Tjhosan's picture
Thumbs Up
stephenk
stephenk's picture
Thanks for the instructions!
bella-headlight
Last seen: 3 months 3 days ago
Have you tried doing tail cap amp readings with & without magnets ?
I used to use magnets but after finding that on an S70 on turbo running 2 x Liitokala 26650“s with magnets I was losing nearly 0.5A.
It may be of course that the magnets I was using had pretty high resistance but because of that I quickly over came my fear of solder blobbing cells & now solder blob if I need to turn a flat top cell in to a button top Thumbs Up
Ian
Boaz
Boaz's picture
Last seen: 2 days 6 hours ago
I’ve seen magnets dent my cells .
not a fan of magnets
Solder blobs are simple …Add flux first then load up your iron till the solder is almost dropping off …it takes about a second to do . Kicked myself for waiting so long to do it . Seems like I was always hunting for a longer cell for lights that didn’t have a spring ..messing with magnets or buying protected cellsbecause they were longer was just dumb .
Anyone interested in Dc-Fix pm me.
teacher
teacher's picture
not a fan of magnets Solder blobs are simple …Add flux first then load up your iron till the solder is almost dropping off …it takes about a second to do . Kicked myself for waiting so long to do it . Seems like I was always hunting for a longer cell for lights that didn’t have a spring ..messing with magnets or buying protected cellsbecause they were longer was just dumb .
+1……. I was in the same boat as you Boaz until not too long ago. I detest magnets…. Wink
ARsee
ARsee's picture
While I just received 10 flat tops, I was in need of a solution.
A quick search of the forum, and here I found some nice ways of getting the task accomplished.
Excellent topic, ALL. Several great solutions!!
Thanks to all who chimed in.
Update:
I just did all of mine. Works as explained.
Dave.
Dave.'s picture
Last seen: 2 weeks 7 hours ago
I used to use solder and a washer of the right size, put the washer in place and then solder into the hole in the middle, it gives more strength than just solder,
Now I just buy the correct batteries with buttons Wink .
mrheosuper
Not many people use spacer, i dont know why
There is battery store at my place. And they have service convert from flat head to button head, 1$ for every 5 batteries
The result is good(at least to me)
Forgot my pen
chrisc
Last seen: 1 week 1 day ago
I use some magnets and a little bit of glue to stop them sliding to the side.
Zebretta
Last seen: 3 weeks 10 hours ago
Made a couple of these.
I just drop one in between the flat tops. Usually 2 batteries and usually the first battery in doesn’t need any help, at least in my flashlights.
The disc keeps it centered in the flashlight tube. Solder blob in the center. These are the thicker ones. I use the thinner ones most often.
Not a good solution for everyone but works for me. YMMV.
These are for 26650 sized cells Smile
papaslightsaber
papaslightsaber's picture
Last seen: 1 year 1 month ago
teacher wrote:
Jerommel wrote:
Solder blob.
+1 Agreed. I’m inspired looking at these guys solder pics.
papaslightsaber
I love this thread. As soon as 18650’s stop driving me crazy, they start driving me crazy again. Magnets are ok for me, but never anything more than just ok. Obviously they are not always a viable solution. In any of the 4p twist top configurations, they are definitely NOT ok.
I see a nice path to several solutions here and really just appreciate this thread and the activity here. I’ve always thought of doing the solder blobs as cumbersome and having an ugly appearance. However, with the given soldering tips and the posted pics, I can clearly see that it’s just the opposite.
Barkuti
Barkuti's picture
Last seen: 1 hour 53 min ago
Sorry, but:
With regards to decreased discharge performance, magnets resistance is not the real issue. The issue is in part related to the increase in contact resistance, as you are creating another non-stationary surfaces solid to solid contact. Increase contact surface, get wider magnets and or solder the stuff.
No, I'm not buying shitty button tops. That @#$% is an aftermarket add-on, very cheaply made. Crappy steel sheet spot welded with a puny nickel strip. Dreadful.
If I were to be handed button top cells without any real use for these ignominious stuff to be there, I'd probably grab my multitool and remove them (Oh! Already done in the past).
This may sound a bit dramatic to some of you, but not to me. I'm happy with it. If in need for protruding contact surfaces, I build my own to my standards.
Party
Sofirn C8T and C8F reviews of mine
PMme for a tip Wink thanks
delete
Last seen: 3 days 23 hours ago
!{width:30%}http://i182.photobucket.com/albums/x231/mistypotato/26650Spacer_2_120170...!
how to build it? can you advice me?
Ronin42
Ronin42's picture
Last seen: 2 months 4 days ago
I stumbled on a great way to make flat tops the same size and protected cells (sometimes your light just needs long cells)
Driver springs, or more specifically a stiff driver spring that RMM has in his shop. tin the spring first then a quick dab of solder once on the cell and bingo a flexible sized cell that fits protected and button top sized lights.
(“It’s good that most people can’t remember their previous lives. Otherwise
things would be a lot more complicated than they already are.”
Ajaan Lee Dhammadharo)
Lexel
Lexel's picture
I found those on Aliexpress which might a nice option for soldering
Definately cheaper than the brass buttons from Fasttech or Kaidomain
https://www.aliexpress.com/item/50pcs-lot-4-5-6-7-8-10m-Yellow-Copper-Ro...
https://www.aliexpress.com/item/50pcs-lot-5×2-5mm-Vintage-Original-Bras...
Even gold plated ones
https://www.aliexpress.com/item/100PCS-24K-Gold-Color-Plated-Brass-Wheel...
