Could you potentially make a variable dc power supply from a 12v battery?
The idea being it seems silly to convert DC to AC just to have an inverter convert it back.
Plus I just love to tinker.
What I’m thinking is a 12v battery along with DC-dc converter to charge batteries and run various DC electronics. I also want to hook up a few USB ports.
I want a portable way to charge a huge variety of things without bringing a ton of charging cables and an inverter.
Put it in a battery enclosure and I have mobile variable power supply I can use for pretty much anything.
This summer we are doing a lot of travel and camping. I’d love to be able charge my li-ions, lipos for RC, USB for phones,camp lighting all from a simple power pack and be inverter free.
Like I said it seems to be a huge waste to do a dc-ac-dc tapdance when a little ingenuity and solder may just work.
Would I need some kind of voltage regulator between the two? It’s my understanding that car batteries can show a great deal of variance in voltage, especially under load.
A hobby charger would be able to charge 90% of what I need it to.
Many battery chargers with 12V input can be used with a car adapter.
For chargers with usb input get a good multiport car usb charger, you can find a few in my tests: index of USB equipment
If you need other voltage, you can get busk and boost converters from ebay for cheap, they just need to be put into a box with some connections.
For ideas check you-tube Julian Ilett, he runs just about all his experiments from car batteries, power banks and a few primary batteries, using buck and boost converter to adapt the voltage.
Most hobby chargers can accept a range of voltages and work. I think my turnigy brand charger (accucel 6) will work down to around 9V. I measured it but I can’t remember now. It might be stated in the user’s manual.
Just get a dc-dc voltage power supply?
There are plenty of cheap buck/boost ones.
Just keep in mind that most batteries should not be charged by just connecting them to a power supply, they require monitoring and regulation, not just constant voltage.
