Battery ?
296 posts / 0 new
Pete7874
Pete7874's picture
Last seen: 53 min 20 sec ago
Venom wrote:
Pete7874 wrote:
Wow, that’s impressive.
I have an Etekcity/Uni-T one, and it reads a little low, but nothing major.
Was it the Uni-t ut61e?
No. I wish it was UT61E, because that one is pretty easy to calibrate.
What I have is Etekcity MSR-U1000 which is a rebranded Uni-T UT61A. This one has multiple potentiometers that could potentially be used for calibration, but so far I have not been able to figure out which one does what and how they interact together, and because the error is pretty small, I decided not to mess with it. Plus, I’m not 100% sure that my voltage reference boards are dead-on accurate either.
Pete7874
Pete7874's picture
FYI, according to my KKMOON rig (based on AD584LH board), the above Etekcity DMM reads low by about 0.22% give or take, so again, not a big deal for me.
teacher
teacher's picture
Last seen: 10 min 19 sec ago
Venom wrote:
@ teacher It’s good to know how accurate the Innova is and how its been holding up all these years. Its seems like a reliable DMM.
Yeah it is Venom, to be honest I was quite pleasantly surprised. Shocked
This one has not been babied at all, I’ve used it on cars, boats, lawn mowers, you name it… plus it has been dropped and mishandled numerous times thru the years. Facepalm
So yes…. I was pleasantly surprised. Wink
teacher
teacher's picture
Wow, if I am counting correctly I see five (5) potentiometers. ShockedFacepalm
You would have to be an electrical engineer to figure that out…… Big Smile
Pete7874
Pete7874's picture
Yup. Someone gave me a link to a technical doc on this DMM, but it was way over my head, so I decided that if it ain’t broke (too badly), don’t fix it. Smile
teacher
teacher's picture
Yeah that is pretty small Pete, 6/1000th’s. Close enough for ‘gooberment work’……. Wink
I like that “case” your VRM is in too…….. Thumbs Up
Now, if you don’t mind; I have a question for you about you picture below…….
Below the Voltage readout & below where it says “Autorange” there is a group of short vertical lines numbered 0 to 40. It appears as a “horizontal graph” (for lack of a better description) that is reading “38”.
What does that represent or tell you/us????
The VC99 is the first DMM I have ever owned that had those.
I have no earthly idea what they represent & if it tells in the “manual”… I can’t find it.
Pete7874
Pete7874's picture
Yes, it is certainly within the accuracy range quoted by the manufacturer (+/- 0.5%).
Good question. The owner’s manual does not go into detail about this bar graph. I think it is meant to graphically represent where within the currently chosen measuring range your reading falls. So for example, in that photo, the DMM is in the 4V range, and since the reading is 3.832V, the bar graph illustrates that you are near the upper limit of this range. If your reading was to go above 4V, say 4.1V, the DMM would shift to the next available range (up to 40V), and the bar graph would then illustrate that you are at the lower end of that range.
But those 0, 10, 20, 30, 40 numbers on the bar graph scale are static, regardless of which range you are in, so that is kind of confusing.
Pete7874
Pete7874's picture
gauss163 wrote:
That’s a bar-graph representation of the reading. Typically it updates much faster than the digital display, e.g. 30/s vs. 3/s, so it is more helpful for visualizing fast-changing numbers. Usually better quality meters have quicker updates.
Thanks for explaining this. I haven’t really paid attention to how quickly the bar graph updates. I typically check battery voltages with it, where there isn’t much if any rapid fluctuation.
teacher
teacher's picture
gauss163 wrote:
teacher wrote:
[…] Below the Voltage readout & below where it says “Autorange” there is a group of short vertical lines numbered 0 to 40. It appears as a “horizontal graph” (for lack of a better description) that is reading “38”. What does that represent or tell you/us????
That’s a bar-graph representation of the reading. Typically it updates much faster than the digital display, e.g. 30/s vs. 3/s, so it is more helpful for visualizing fast-changing numbers. Usually better quality meters have quicker update speed (this is one of many parameters used to evaluate DMM quality, e.g. see reviews on eevblog.com).
OK, thank you gauss! I appreciate the info and link. Smile
Here are clickable links to the site gauss referred to. It looks like a ton of good info is there. Smile
eevblog
Calibration & Standards
Good effort Pete!!! Big Smile Thank you. Thumbs Up
Pete7874
Pete7874's picture
FYI, this is what it looks like…
teacher
teacher's picture
Your pictures are much better than mine Pete!! Thumbs Up But hopefully it can be seen. On my VC99 the numbers go from 0 to 60.
I am gonna do more reading on the eevblog site gauss linked to and get this figured out in my little ole’ mind. Smile
……I hope. Wink
Pete7874
Pete7874's picture
That’s because your DMM is 6,000 count, I presume, which means you get 3 decimal points resolution all the way up to 6V.
In comparison, mine is only 4,000 count. So I only get 3 decimal points resolution up to 4V. Once the measured value is above 4V, mine drops to 2 decimal points, as you can see in the last photo I posted.
BTW, your photos are perfectly fine. Smile
teacher
teacher's picture
OH…. OK….. I understand that. Thumbs Up
That is why mine drops to two decimal places on the 7.50 Volt reading. I had been wondering about that.
Thanks for explaining that Pete. Smile
Very gracious of you Pete…….. Wink ..,. Thank you. Smile
Venom
Venom's picture
Last seen: 3 days 14 hours ago
@ Pete7874 The picture of the meter in post 153. Are the glass tube looking fuse the same one that are used in automotive, if not are they hard to come by?
Venom
Venom's picture
@ teacher Is there any way to test these voltage boards? For the battery operated voltage boards, when the battery voltage drops will affect the voltage board accuracy?
Pete7874
Pete7874's picture
I don’t believe they are the same as automotive ones. They can be found on ebay and many online electronics stores.
http://www.ebay.com/itm/Ceramic-Domestic-Fuse-Bussmann-6×25mm-BS1362-3A...
Pete7874
Pete7874's picture
I know this was for teacher, but I’ll chime in with what I know.
You basically take a measurement with a known calibrated highly accurate DMM, and write down the result. That is the actual voltage being put out, and you can then see how your own DMM compares. That is why the one I posted above has that little sticker with actual measured values from an Agilent DMM written down. Granted, you put your trust in that someone actually did these measurements on your board and not just copied the same sticker and plastered it on hundreds of these boards without actually measuring. These things are cheap, so you never know, unless you have another perfectly calibrated DMM sitting around to verify. That is why I wrote earlier that I don’t trust it 100%, but all my other cheap/free DMMs seem to indicate it’s correct.
As for the battery, most of these voltage boards have some kind of voltage regulation circuitry to keep output voltage the same, just as long as the battery voltage is above a certain level.
teacher
teacher's picture
  • I’m sure there is a way to test them, but honestly; that is getting above my “pay grade”. Big Smile .. (In more simple words… beats me how though. Big Smile . )
  • I think as long as the battery voltage is above the voltage you are referencing allis well. The one I have is designed for input voltage of 5 – 30V DC. So I just plugged in a 12V power supply I had and powered it that way. Mine takes a 5.5 × 2.5mm barrel plug.
Pete7874
Pete7874's picture
gauss163 wrote:
Worth emphasis: budget DMMs with higher precision (e.g. UNI-T UT61E) will often have large temperature and long-term drift (e.g. there are many complaints about such for the UT61E on eevblog). Likely the same will be true for your VC99.
What would be your personal recommendation for a budget DMM?
Pete7874
Pete7874's picture
gauss163 wrote:
There are many threads on that topic on eevblog.com. When you peruse them you will see the answer depends on your needs, budget, etc.
I did that some time ago, and it seems that UT61E is often being recommended. But since you pointed out some flaws with it, I was just wondering if there was something better in that price range.
Venom
Venom's picture
While I was at Home depot I was looking at DMM. Has anyone heard of Klein Tools DMM and if you did are they any good?
teacher
teacher's picture
Not sure which model you looked at Venom, but as a general rule Klein makes quality items… tools & otherwise.
Some seem kinda pricey, but most all are quality.
Smile
Venom
Venom's picture
@ teacher The model number is MM 600 and the MM 700.
teacher
teacher's picture
I am sure they are good meters Venom. But hopefully someone who really knows about meters will have some advice on them.
The ones I have are just mainly used by me in this hobby, ocassional mechanic work, & things like that. Mostly pretty low voltage & current DC. They all seem to work fine for my limited needs.
I have some I would feel comfortable checking AC things around the house ocassionally…… but I would never go above household current or voltage with any I own.
In other words….. I ain’t much help to you on this one besides the ones I have that serve “my uses” just fine. Smile
teacher
teacher's picture
@Venom …… When I wrote post number #179 above last night I was on my phone trying to look at this stuff. I am on my computer now and am able to find & see pictures much better. Wink
The MM600 seems to be $66.97 at Home Depot
The MM700 seems to be $99.57 at Home Depot
AGAIN…. hopefully some who really knows about DMM’s will chime in here. But here are my “semi-uneducated” observations. Better make that “mostly-uneducated” observations. Big Smile
  • They are both Auto Ranging… that is good
  • They both appear to be well made
  • They both appear to have ceramic fuses… not glass. Very good
  • Both are rated….. Safety rating is CAT IV 600-Volt, CAT III 1000-Volt, class 2, double insulation
  • MM700 is True RMS
    …….. I don’t even pretend to understand this, it’s significance, or how important it is in a meter…. Facepalm
Heck, I’ll just stop there. I pretty much think these are both good meters.
If you are just going to occasionally check battery voltages and do some tail cap readings they are probably both overkill.
But on the other hand if you want a good all around meter that you could use with confidence and not worry about getting fried if you decided to use it for AC electrical measurements around the house or higher DC voltages…..probably a good way to go.
But, don’t take this for the gospel. These are simply my observations. Smile
Speed4goal
Ya its over kill for checking batteries and amp readings. For that the free ones from harbor freight are perfect and more then accurate for. And they have that little screw inside if needed. I have a $5 one shipped from gearbest. I wouldn’t go do commercial work with it. But perfect for checking charging voltages and laptop pulls and such
2/9 Fox Co (2009-2015) Semper Fi 0311/0331 Rifleman/Machine Gunner
Blf has changed a lot since I've been here. Lots of snow flakes and easily offended over nothing. When the forum use to be great and people joked around and could take a joke. It's a forum it's not that serious. Let's make BLF great again!
Pete7874
Pete7874's picture
Klein is a reputable brand, but like others mentioned, it may be overkill, depending on your application. For a little over $20 you can get an autoranging Innova 3320 from Amazon.
teacher
teacher's picture
Thumbs Up
Venom
Venom's picture
I was looking for a DMM, and not sure which. The UNI-T UT61E or Klein MM600. It seems like the UNI-T has some issue and the Klein I can’t find much on it. The UNI-T has a extra digit when compare to the Klein. Don’t know if that matters. I’m just looking for a dependable and accurate DMM and one cheaper one probably the Innova.
teacher
teacher's picture
@Venom
If you want two, you could always get the Innova 3320 (cheaper initial cost) and then take your time picking the more expensive one. Smile
