Which BLF driver for Convoy C8?
14 posts / 0 new
Sledgestone
Last seen: 3 weeks 1 day ago
I’m about to put together my first light. I was wondering which driver would be best for it? Would I go for the BLF X5/X6 driver or the BLF A6 driver?
I’m going for a XP-L HI V3. I’ve read in another thread that the BLF X5/X6 driver won’t work in a C8? Something about the C8s retaining ring is made out of aluminum.
Lexel
Lexel's picture
Last seen: 11 hours 59 min ago
Bistro driver would be best
TA triple channel is one of the best options
http://budgetlightforum.com/node/48447
I am currently making some
http://budgetlightforum.com/node/53599
Sledgestone
Will your driver be a significant increase in output? Or is it strictly the firmware? If it’s just firmware I have a hard time justifying almost the double cost..
Lexel
Lexel's picture
Its one of the best driver you can get atm, the firmware is almost the same
The X6 driver is good as well
the costs just comes from the fact, that its not mass produced, so i got higher purchasing price for materials, and I need some time to make and test them
The Output is basically defined by the LEDs forward voltage, FET, leads and bypassed springs
I can solder a 1$ cheaper FET which has 6mOhms more resistance
The 7135*1+6+FET has better efficiency in middle modes
khas
Last seen: 1 day 19 hours ago
I would chose the BLF X5/X6 driver because the Bistro firmware has more options. The driver Lexel is making has better components, is more efficient and the TA version of Bistro have even more mode groups options.
The max output on all three driver are about the same, so if price is the most important just go with the BLF A6 driver.
I have a spare BLF A6 driver I could mail to you, send me a PM if you are interested.
Lexel
Lexel's picture
If he asks I make hin even a custom modegroup, just BLF service
a BLF A6 driver is cheap, the UI is OK
even the cheapest BLF driver is far better than 95% stock chineese rubbish
Sledgestone
So you’re saying that the blf x5 driver would work in a c8? Can I easily change the temperature settings and modes? Or do I have to use a computer to change the firmware?
Lexel I’ll send you PM later today!
khas
I haven’t build a Convoy C8 with a X6/X5 driver but I have build a Thorfire C8s with a MTN-20DDm also a FET+1 driver with Bistro works just fine. With Bistro you can change the settings available in the firmware just by clicking look here for more info :
http://toykeeper.net/torches/x6v2/manker/bistro.txt
Sledgestone
Ok, thanks. The reason I asked is this that I’ve read in another thread here.
“You may want to be careful about using that driver with a Convoy C8 host. The BLF X5/X6 driver from the same manufacturer does not make electrical contact with the driver retaining ring of a V3 Convoy C8 and it can’t be soldered to it since the ring is made of aluminum.”
Yokiamy
Yokiamy's picture
Last seen: 4 hours 16 min ago
Sledgestone, did you build the X5/X6 driver already in the Convoy C8?
I have exact the same question, read that post as well
Thijsco19 wrote:
a regular symptom of flasholism Big Smile
“Flasholism is the most severe form of flashlight use and involves the inability to manage your flashlight use habits. It is also commonly referred to as flashlight use disorder. Flashlight use disorder is organized into three categories: mild, moderate and severe. Each category has various symptoms and can cause harmful side effects. If left untreated, any type of flashlight use can spiral out of control.”
Sledgestone
I did and it worked perfectly! Finished another one yesterday using a A6 driver this time. Measured at around 120kcd without fine tuning the focus.
Yokiamy
Yokiamy's picture
Thanks for the info, so no problems at all?
Just unscrew the aluminium retainer ring, replace the driver, solder wires to the led, screw everything back in place?
Since i read that post that you qouted as well, and i was a bit worried Smile
Driver should be in NL according tracking info Cool
Sledgestone
Nope, no issues at all! Yeah, that’s how you do it. The retaining ring is kinda wonky both to get in and out. The holes in it are so damn small. I found it quite hard to get a satisfying solder joint on the wires to the led. But hey, it works so I’m not too bothered by it.
Yokiamy
Yokiamy's picture
Thanks again!
Opened my C8 several times, so no problem, even a steel nail will do Smile
