Tale switch found, what should i build with it?
Got my hands on an exellent tail switch, and i was wondering what should i mod with it….its kinda big for a C8 you know
P.S
If someone is wondering, thats a 2MW wind turbine main power breaker
We swapped them with new ones and the morron owners wanted to throw those away, can you imagine? Now i will recycle them, all 35 of them :slight_smile:
Switch is under powered anyway, so forget about it…
At minimum a 10K gen set
How big are your pockets?
Gonna have to bypass those holes in the bars
A good one!
Yet, i have a 50 000w Police branded flashlight, it has a crap tail switch too- and i think thats the reason i cant see those 50kw!
However that switch isnt made in China/Shenzhen so it aint original
I don’t think I would be able to use this in one of my flashlight builds :slight_smile:
Finally a switch that can handle direct drive 219c!
Got any abandoned factory stacks you could mod into tube lights?
You should install that switch in an Eagletac D25C :+1:
Actually 500kVA genst rated at 800A.
Terasaki is Japan manufacturer. Trade comany is based in Scotland.
As long as it aint made in China it aint original
We swapped them with new ones and the morron owners wanted to throw those away, can you imagine? Now i will recycle them, all 35 of them :smiley:
I 'll suggest to attach each of them to the lanyards of cheap flash lights , and sell them together , as a Kit... The customers has to figure out how to use...DIY contest !
Aaaa 2 MW turbines, that be the small ones then.
We Danes are tearing down all the small ones on land and putting up 8 MW ones out to sea.
