How do you store your batteries?
58 posts / 0 new
Enderman
Enderman's picture
Last seen: 11 hours 34 min ago
I store them depleted or very low
2% (2 votes)
I use a charger with a lithium battery storage mode to put them at ~50%
8% (9 votes)
I use flashlight brightness or a voltmeter to guesstimate ~50% and store it like that
10% (12 votes)
I store them at ~50% AND put them in a fridge
4% (5 votes)
I store them near 100% so they are ready to go
76% (88 votes)
Total votes: 116
Enderman
Enderman's picture
Just curious, I would like to know how people store their cells.
I mostly use LiPOs (the pouch batteries, not cylindrical) and one of my cells expanded after being left fully charged for a few weeks.
Interestingly, one of my other cells (different size and brand of battery) was not visually affected after being fully charged for months.
From now on though I try to use my charger to put my new LiPOs at storage charge.
Does the “expanding” or “ballooning” happen to cylindrical cells too when left charged or is that just a LiPO pouch battery problem?
Lazy-R-us
Last seen: 1 week 1 day ago
How accurate is your crystal ball?
My theory is that things go pear shaped without notice, I want as many amp hours available as I can. If I DO get a warning, for instance, an oncoming storm, I can get the bin out and refresh as many cells as I have time for.
Lazy-R-us
Enderman
Enderman's picture
This doesn’t sounds like what someone named “lazy-r-us” would do…
Big Smile
Lazy-R-us
Big Smile
Au contraire, my friend! Way easier to do it this way than constantly remember to keep track of the cells!
Lazy-R-us
Lightbringer
Lightbringer's picture
Last seen: 4 hours 7 min ago
I try to only use cells “actively”, in lights that I actively use for one reason or another. So I keep very few “extra” cells on-hand.
All the rest, those aforementioned “extra” cells, I leave untouched from the factory. I’m presuming that they’re properly charged to ~40% or so.
It’s also why I don’t hoard Li cells. By the time I use up these in “active rotation”, the others would likely be moribund anyway.
Oh yeah, so it’s guesswork and presuming they’re properly charged to 40% or so.
Yokiamy
Yokiamy's picture
Last seen: 2 min 45 sec ago
F —> they vary in charge when stored Wink
I usually know which batteries are charged and which arent, i keep them in different boxes to distinguish the charged from the uncharged.
i have charged 4 30q bt’s which i purchased for the Q8, just to try my new Li500.
another set flattops which i solder blobbed/boobed are still never charged, they contain their original charge.
for the rest, as i said, i keep them in different boxes to distinct the charged from the uncharged
Thijsco19 wrote:
a regular symptom of flasholism Big Smile
“Flasholism is the most severe form of flashlight use and involves the inability to manage your flashlight use habits. It is also commonly referred to as flashlight use disorder. Flashlight use disorder is organized into three categories: mild, moderate and severe. Each category has various symptoms and can cause harmful side effects. If left untreated, any type of flashlight use can spiral out of control.”
Jerommel
Jerommel's picture
Last seen: 1 month 4 weeks ago
I charge a bunch of them and put them in plastic 4× 18650 boxes
And when they’re discharged (usually around 3.3 Volts) i put them upside down in the battery boxes.
Then when they’re all used up, or just before they’re all used up, i charge a bunch of them again.
I keep in mind not to let them sit in a box fully charged for too long.
..waiting for parts..
Still looking for 5” parabolic reflector (for recoil light)
Tangra
Last seen: 13 hours 11 min ago
I am thinking to buy HPAC specially for my battery.
After that I can make colocation data center at home. Cash
Pulsar
Pulsar's picture
Last seen: 2 days 17 hours ago
I know your not supposed to, but I typically store mine charged in plastic cases designed for that size cell. If I had a charger that would do a storage charge, I would use that. I have a few cells, 18500s and 16340s, that I have nothing to use in right now.
SoCalTiger
SoCalTiger's picture
Last seen: 2 weeks 4 days ago
I “store” mine at 75%. Low enough to improve the lifespan of the cell while still allowing for a decent usable capacity if I need it right away. Room temp, which can hit 80F where I live.
Enderman
Enderman's picture
What is that?
ToyKeeper
ToyKeeper's picture
Last seen: 1 hour 24 min ago
What happens when you keep a lithium-ion battery fully-charged all the time:
This was not an isolated incident. The entire test lab had similar problems, multiple phone models from multiple manufacturers, because they were constantly plugged in and the charge kept oscillating between ~95% and 100% as the devices went through automatic top-off cycles. The pattern at the right of this graph was basically repeated nonstop whenever the devices were plugged in, which was all the time in a test lab environment:
The inflated battery shown earlier is what would happen pretty consistently after about 6 to 18 months of being plugged in, even if it was idle most of the time. At about 18 months, no devices were functional any more. However, an extra which was stored half-full with the power off … was still nearly as good as new.
Cylindrical cells don’t tend to balloon like that, due to the outer shell being strong, but they still lose capacity and build up pressure.
Keeping li-ion cells full in storage, and topping them off frequently, is one of the most effective ways to kill them faster.
Enderman
Enderman's picture
Thumbs Up thanks Smile
bfksc
bfksc's picture
Last seen: 10 months 4 weeks ago
Same here…I don’t have any extra LiIon cells. When I’m going hiking, boating, camping, whatever for a while, regular light gets a top up so it’s good to go for the “event”, and it gets used a fair bit. I have 2 × 18650 cells for flashlights and one is always in the truck, and one is at home by the bed – both get used regularly and I swap the batteries around when charging as the one in the truck is used a bit more frequently. This helps to keep the cells at similar capacities. If one fails, I’d just order another protected 18650 cell.
For NiMH which can be stored fully charged, I have a lots of spares and I rotate them through remotes, clocks, small flashlights for backup and around the house activities, etc. These I top up and store in a room temperature drawer till they get swapped out, which is fairly often for remotes. I make sure to rotate them when charging too.
I didn’t vote in the poll as there is no option for “I don’t store them, I use them”. Big Smile
Enderman
Enderman's picture
I had two nimh packs which I left charged (without using) for a year or two, they died completely.
Won’t hold any capacity, and produce very little voltage.
Sad rip
Should have cycled them every few months I guess.
And yeah you’re right, if you just use batteries without storing then the poll doesn’t really apply to you Silly
Speed4goal
Last seen: 2 weeks 2 days ago
+ 1 in my opinion. Being through the east eye wall of Katrina. I’ve gotten to wear I horde batteries now. All the pulls I can find. Usually anything 1200+ Ill keep and fully charged. Just for hurricane preparedness. Like you said if there’s warning I’ll top them all off for whatever self discjarge occoured. Used and free not really concerned if they loose some life at full charge.
Edit, my good cells I use in my flashlights get rotated about every 4-6 weeks. I’ll put them in a powerbank and use them. But all the extra free pulls over the last 6 months of recycle bin pulling stay fully charged. But my opus only charged to 4.13 so I guess its not really maxed topped off. Usually settle to around 4.1
2/9 Fox Co (2009-2015) Semper Fi 0311/0331 Rifleman/Machine Gunner
Blf has changed a lot since I've been here. Lots of snow flakes and easily offended over nothing. When the forum use to be great and people joked around and could take a joke. It's a forum it's not that serious. Let's make BLF great again!
feralcomprehension
Fully charged, boxed and in the fridge.
Lightbringer
I stopped using protected cells because there’s always a small parasitic drain from the protection circuit. The only cells I had actually croke dead from disuse were protected. I still have the 2 original protected panny-Bs, but I keep them in my regular-use lights (EDC and headlamp).
The other lights are more or less special-purpose, but still somewhat regular use. C8 for yard-snooping, VG10 for non-EDC general-purpose use, etc. The other unprotected panny-Bs and 30Qs, and some powerbank pulls, I keep shelved at less-than-topped-up levels.
Only in case of a big storm coming, high winds, etc., will I grab all the in-light cells and top them off. Worst case, I can always top up cells when needed from inside the car.
ToyKeeper
ToyKeeper's picture
Enderman wrote:
I had two nimh packs … they died completely.
Old NiMH batteries tend to die anyway. They basically had to be re-conditioned on a regular and frequent schedule.
Newer “LSD” NiMH is much better at remaining useful for years and years, and doesn’t require much maintenance or special care. It’s still a good idea to fully charge and fully discharge them though.
Li-ion is different than either of the above, since it doesn’t like being fully charged and really doesn’t like being fully discharged. It’s happiest right in the middle.
Enderman
Enderman's picture
LSD like the drug? Silly
I mean I didn’t expect them to die so fast, some of my other nimh RC battery packs were perfectly fine sitting fully charged for long periods of time.
They must have been lower quality cells or something.
sbslider
sbslider's picture
Last seen: 4 hours 59 min ago
I use eneloops, so I voted for fully charged. The poll did not specify what chemistry . . .
I have some experience with 10 year old nimh non eneloops I came across recently. Roughly 50% were toast, the other 50% I was able to charge and discharge a few times and now they deliver near capacity. I don’t have a accurate way of measuring the capacity, but they last for 5 hours at 75 lumens in my TN Archer 1AV3. This is how long Thrunite claims they will run at 75 lumens, but does not specify a battery type. So these old cells can still be usedful. Mine were a mixture of Energizer 2500s and duracell 2650s. I will say the duracells had a much higher recovery rate than the energizers. Like 7-8 duracells and 2-8 energizers. I think the energizers had seen a few quick (15 min) charge cycles in their life though.
Tangra
What is that?
HPAC: High Precision Air Conditioning.
Designed specially to cool temperature heating from equipment. On the other site are comfort air conditioner designed for home application.
Tinderbox UK
Tinderbox UK's picture
I keep them at 100%, battery are cheap enough to not worry about replacing them, But in an emergency every % point may count.
Any of my device with built in li-ion battery`s phone/tablet are charged to 80% and never drop below 20% apart from an 12 month recalibration charge.
John.
SkyRC MC3000 – Maha C9000 – LaCrosse BC-900 – Floureon BT-C3100 V2.2 – Accumanger 10 and 20 -Thunder AC6 LiitoKala Lii-100 – Cozypony 24W Solar Panel – Soshine H4 – Soshine T2 – Soshine E4S
Suncoaster
Suncoaster's picture
Last seen: 2 weeks 6 days ago
Location: Where the girls are green and the grass is pretty.
I keep hundreds of 18650 laptop pulls in original condition, some still in battery packs; and
old RC li-pos and assorted other potentially toxic or energy dense dangers, in tin boxes in a shed away from the house.
Lots of fully charged Li-ions are kept in torches all over the place, and a bunch of depleted cells waiting to be charged are kept piled in plastic boxes on a desk.
"In the land of the blond the one eyed man is king."
*This message is protected with ROT26 encryption.Old Lumens
southland
southland's picture
Last seen: 2 days 11 hours ago
No special voltage for storage, some fully charged, some fully depleted. Have a couple of hundred lithium ion batteries and in 8 years or so have only had 2 or 3 batteries go bad, this is including 8 year old batteries. Storage voltage level is overrated.
Jarder28
John.
I agree on this, I keep extra batteries for emergencies. Whenever I would need it I know its fully charged. That’s the reason I bought a lot of 18650 for power outage in an inevitable time.
dchomak
Last seen: 2 weeks 1 day ago
I try to keep mine stored at 3.6V to 3.7V. Of course the few I use, I fully charge. I recently found a Panasonic 18650B in a light that used to have 3300mAh when I first got it. It now only has a capacity of around 2800mAh. It was sitting fully charged for about 2 years. BTW, as a fully charged cell self discharges, the stress on the cell is relieved somewhat as the voltage declines. Even though, it harms the cell. Imagine how much more harm is done when cells are left constantly charging in laptops that are plugged in. Those cells see tremendous stress as they are constantly topped off and receive more stress with no relief.
Then think of the even more stress that GPS units receive stuck to the windshield of a car in the hot sun. In fact that combined with the black case many of them have, leads to an early death. The only GPS units I have that still have working cells are the ones with white cases.
I was greatly encouraged when I opened up a brand new, unused GPS receiver that I had purchased in 2006. Before I turned it on I opened it up and checked the voltage on the included Li-ion cell. Even though it was 10 years old, it was sitting at around 3.5V. I charged it up and did a capacity check with my OPUS. I don’t remember the exact number but it tested out to around 95% of capacity. Also the GPS had a run time of about 3 hours, it’s stated runtime, and that too confirmed that Li-ion cells do very well stored at half capacity, even the ones manufactured 10 years ago. I can only assume they are even better now.
patmurris
patmurris's picture
Last seen: 2 hours 4 min ago
I don’t really “store” cells… even though i have a small metal suit case with between one and half dozen spare of each size – probably more 18650 though, in appropriate plastic cases. Those are ‘new’ or not yet used except for a few i happen to use in a rotation – but i usually don’t put them in this ‘bin’; i tend to keep them close to the device they are used in.
The big chunk of my cells are ‘stored’ in flashlights (totally lost count since i joined BLF), hopefully fully charged. Most i don’t use much, and when i happen to use one, i usually top off the cell right away before putting the light back in it’s place.
I understand that Li-ion batteries will last longer if treated just right… but i’d rather have cells ready to use that will decline faster then cells i can’t use right away if i need them, but that will last longer. During the past four years i’ve used them, li-ion cells have evolved faster then their obsolescence rate so that you probably want to renew them for increased capacity and/or amps.
atbglenn
atbglenn's picture
Last seen: 5 hours 46 min ago
I store half of my LiIon cells at 3.7 volts. The rest are fully charged. My shelf queens have no batteries installed. But the rest, 20 plus, have fully charged batteries installed and ready to go. In an emergency, I have 5 portable USB chargers, plus 4 UPS’s with USB outputs, and a generator if things get really bad.
We need ICE to keep our country safe.
SteveMidwest
SteveMidwest's picture
A great comment ToyKeeper, and very good advice. I long ago, quit plugging in my cell phones overnight to charge, for just this reason. When doing so, and if the phone is left on. The charger will bump the battery back up to 100%, about 5 times a night. Not good at all, for long term battery life.
I tracked and charted this, via an App on my phone at the time.
I tell people this, and many of them think I’m crazy. Oh well, I tell myself . . . They will live and learn. Hopefully. Cool
