Review: Olight PL2 Weaponlight
8 posts / 0 new
Budda
Budda's picture
Last seen: 20 hours 8 min ago
Due to severe time limitations, this review is published with a reduced amount of writing, pics, data.
I received the PL2 from Olight for the review.
The PL2 is the new weaponlight from Olight. It features their traditional double sided switch, an XHP 35 emitter and works with 2 CR123 cells for increased output and runtime.
Unboxing
Inside the box: the light (with the 2 cells inside), manual, screws, rod to be installed on the weapon slide.
The PL2 has a larger design compared to the PL1 because it holds 2 CR123 Cells. As far as I can tell, everything is made out of metal, except the 2 protruding switches that are made of plastic.
Accessing the battery compartment is done by pulling this metal lever.
Here a detail of the lever mechanism.
Plastic spacer makes accidental activation impossible inside the box.
The hinges are made out of metal.
How about the front optic with the powerful XHP35 emitter?
The light can be slided on and off the rail by pulling this side lever
The UI is very simple:
There are only 2 modes, a constant and a strobe one.
- Pressing either one of the side switches at once, will turn the light on. Another press will turn it off.
- A long press of either of the side switches will activate the momentary on (the PL2 will turn off as soon as you depress the switch)
- Pressing the 2 switches at the same time will activate the fast strobe.
Beamshots, at 0.5 meters from the wall.
Output and runtime
Testing done with 2 Olight CR123 Cells.
My thoughts
The light is well built and finished.
The design and the UI seems smart and practical for the tactical application, intended for the PL2. It is consistent with the one of the PL1. The 2 switches design allows operation also for lefties (or your weak hand).
Beam, regulation and runtime are adequate for a handgun, which should operate within short distances. I like how the runtime remains flat after the stepdown for 1 and half hours, then slowly stepping down to let you know you need to replace cells.
I’d like to see a NW version of this light.
Thanks to: AntoLed for the camera instructions and the luxmeter; M87 for the shooting.
More beamshot to come.
All my reviews, in italian and english, here: Lumenreviews.com
Edited by: sb56637 on 09/02/2017 - 12:02
Lexel
Lexel's picture
Last seen: 11 hours 7 min ago
No pictures!
RobertB
RobertB's picture
Last seen: 1 hour 25 min ago
Lets see it mounted to your weapon
Turningbluechips
Turningbluechips's picture
Last seen: 21 hours 17 min ago
+1
I’d like to see if it’s compact enough to work with my Glock or if it’s more suited to a rifle or shotgun.
Enderman
Enderman's picture
Last seen: 7 hours 13 min ago
Why do all the beamshots have “Nitecore NU10” on them?
I thought this was an Olight PL2 review?
Budda
Budda's picture
No weapon owned = No weapon pics
I’ll fix the writing in the Beamshots, thanks for noticing.
Budda
Budda's picture
pics fixed.
Budda
Budda's picture
