*Edit*
Apparently, the memory is not the only thing affected. Sometimes (I say sometimes because it varies) if left off for longer than 1 minute, it will go to the next mode. Sometimes it's 5 min, sometimes 2 min, etc. IDK why it varies so much. But for sure, after 10 min it will go to the next mode when you turn it on. So don't go throwing your UF 2100's. Oh well...
*end edit*
Well, I sorta got pissed off tonight and I hurled my UF-2100 with full force (without thinking) down onto the floor (which is carpeted) and said some choice words. As soon as I realized what I had done, I said some more choice words. :)
I picked it up and immediately felt/heard something rattle. "Just great", I thought to myself. I clicked it on but nothing. Click, click...nothing.
Not too long ago, I dropped it from about 5 feet and it stopped working. I took it apart and after examing the pill, I couldn't figure out what was wrong. So I cleaned all parts that touch metal on the board (on the pill as well) and firmly re-attached the retaining ring. Bingo, that did the trick.
So this time around, I was hoping it was the same situation. I took it apart and upon inspection realized a small "part" from the board had fallen off! I remember this piece not being aligned correctly the last time I took it apart nor did it look like it was soldered very well.
In the following picture (posted by heke), it's the small, rectangular silver/brown part located at around the 2:00 position just below the semi-circle. My soldering iron's tip is like the size of the part! I don't know how I'm going to put it back on.
Well, I started praying to anyone who would listen, anxiously put the pill back together and firmly attaching the retaining ring. Screwed everything back together and clicked...
It worked! In fact it's now got a new kind of "memory". lol It now takes only 1 sec or so for the memory to kick in!!! Not the stock 4.5 seconds! I am so stoked. :)
