KronoReview: Carnival Tritium 8638G Watch (Special Price $68.99 Link Added)
36 posts / 0 new
kronological
kronological's picture
Last seen: 6 months 1 week ago
(EDIT)
Get it for $68.99 here.
4 different colors to choose from.
Thanks,
krono
Hello, and thank you for checking out my latest watch review! I was fortunate enough to take this watch with me on a trip to Banff National Park in the gorgeous Canadian Rocky Mountains (pics below).
In this review, I will be looking at the Carnival 8638G Day/Date Quartz Watch with Tritium accents . This watch was provided gratis by lightinthebox.com, and regularly retails on their website for $91.99.
FYI…this Carnival watch is available in 4 color combinations:
White Dial/Blue Trits (reviewed)
Black Dial/Blue Trits
White Dial/Green Trits
Black Dial/Green Trits
And a larger manufacturer pic of the version up for review:
^ Lightinthebox listing Pic Love ^
The specs as they appeared, verbatim, from the lightinthebox listing :
Specifications:
Gender: Men, Men’s
Movement Type: Quartz
Display: Analog
Type: Wrist watch, Fashion Watch
Case Material: Stainless Steel
Case Diameter Approx: 4cm / 1.57 Inches
Case Thickness Approx: 1.1cm / 0.43 Inches
Band Length Approx: 22cm / 8.66 Inches
Band Width Approx: 2cm / 0.8 Inches
Dial Color: White
Band Color: White
Band Material: Stainless Steel
Water Resistance Depth: 30M
What’s in the box: 1 x Gift Box, 1 x Watch, 1 x Watch Band Tool, 1 x Watch Instructions Manual
Listing Date:04/27/2017
KronoReview:
I have been enamored with the Carnival Tritium watch after seeing it online. Even more so because of the positive response BLF member JohnnyMac had when he bought one some time ago. Well…I finally received one for review. I guess the pictures featuring those delectable Tritium vials were calling my name. Maybe…just maybe because I am a flashaholic and love lumens?
Anyhow, this Carnival M/N 8638G is a field-watch style, and very versatile with casual or semi-formal attire.
The Carnival watch came in a padded/bubble-wrap envelope, wrapped securely and very protected, and sealed inside a styrofoam shipping box. Inside the shipping box was an outer retail box, with a nicer inner-box, sizing tool, warranty card, booklet etc…it really makes you feel as though a quality product awaits inside. So…Is that the case (pun intended)? Let’s see…
CASE/CROWN/CASEBACK/LUGS: The Stainless Steel case measures a width of 40mm (43.5mm w/crown), and the overall height is 12mm high…a good size for this type of watch. Lug-to-lug measurement is 49mm. The nicely curved sides and top of the case have a very workmanlike, brushed finish. The relatively thin, angled bezel is fixed and un-marked, as well as highly polished. The Stainless Steel case extends under the crystal to an attractive, stepped rehaut that butts up to the chapter ring. The pull-out crown is a nice size, properly knurled and easy to manipulate. There is a raised Carnival logo on the side of the polished crown. The screw-down case-back utilizes a standard, six-indention design for a 2 or 3 point removal tool. Upon removal, there is a single black internal O-ring seal between case and back. The watch has a 3ATM water-resistance rating. Therefore, I won’t be using this while swimming, but it has been fine for dish duty.
^ A TON of pics of this watch amongst the Rocky Mountains in beautiful Banff National Park, Canada. Sorry there are so many…I just couldn’t help myself. Big Smile
BRACELET/CLASP: The solid link, 20mm Stainless Steel bracelet has a modified, oyster-style look. The outside links are brushed on the top/bottom, and polished on the sides. The center links are also brushed, but have a smaller polished end piece on each side. These pieces match well with the polished bezel, providing a nice contrast to the mostly brushed surfaces on the rest of the watch. There are six removable links for adjustment, held together by standard split-pins (split-pin removal tool included). The double-pushbutton, butterfly clasp is nice and secure, and has “Carnival” & “1986” on the middle attachment links, and “Stainless Steel” etched on the inside. The butterfly closure does not allow for micro-adjustment for wrist size, so it might fit a little snug or loose, depending on what you are more comfortable with. Not a huge negative, but could be an annoyance if your wrist size is somewhere in-between.
CRYSTAL/DIAL/HANDS/INDICES: The white dial has traditional field watch looks, with ample, easy-to-read Arabic numbers next to the Tritium indices. Just inward of those numbers are smaller, 24 hr. Arabic numbers, from 13-23. Each indice extends into a notch on the white chapter ring. Each hour indice is marked with a T25 ice-blue Tritium vial, with the exception of an orange trit at 12 O’clock. A day/date window, outlined in black, sits between the 3 O’clock indice and the center of the watch. The white date wheel matches the dial well, with black Arabic numerals and abbreviated day indicator (except, of course, a red Sunday “SUN”). The hour and second hands are a pointed baton/radium style, with ice-blue T25 Tritium vials in the middle. The rectangular paddle-style second hand also has a small ice-blue trit in the center. The Tritium vials are remarkably visible in the dark! I originally thought that I would want much brighter T100 trits on a watch, but I’m beginning to think they might be too bright. With a total of 15 trits, this watch, IMHO, is PLENTY bright! So much so that it freaks my wife out if she wakes up and catches a view of it as I move my hand (I’m quite the restless sleeper). The sapphire crystal is awesome and very scratch resistant. It also has an excellent anti-reflective (AR) coating, and does a phenomenal job of making the crystal disappear when looking directly at the watch. The AR coating, along with the large numbers, makes this a very easy to read, legible watch. If I had to change anything, I would use a different color trit on the hands for increased nighttime legibility.
MOVEMENT: Ronda Powertech (Series 500) 517 1 jewel, analog quartz movement with Hour/Minute/Second and Day/Date functions. “Swiss Parts” is printed on the movement, so I am assuming that they are assembled somewhere outside Switzerland. The watch came equipped with a Renata 571 battery.
^ Ronda website pic of 517, 1 jewel quartz day/date movement. ^
PROS:
Tritium, Tritium and more Tritium!
Swiss Parts 1 jewel Ronda quartz movement with Renata battery.
Excellent night-time legibility with the 15 trits on indices and hands.
Top-notch daytime legibility with white dial, large contrasting black Arabic numbers/hands and an excellent crystal.
All Stainless design with very good fit and finish.
Attractive, field-watch aesthetic.
Screw-down, stainless case back.
Grippy pull-out crown.
Nice brushed case and solid link bracelet with appropriate polished accents.
Day/Date functions.
Flat Sapphire crystal with excellent AR coating.
Nice retail box and attractive inner box with warranty card, manual and sizing tool.
4 color combos to choose from.
CONS:
No contrasting Tritium vial colors on hands.
No micro-adjustment on clasp.
3ATM water depth rating.
DIMENSIONS:
Width: 43.5mm (including crown).
Case Diameter: 40mm.
Lug to lug: 49mm.
Bracelet width: 20mm.
Crystal: 34.5mm.
Overall Height (top of crystal to case back): 12mm.
Weight: 132gms.
RATING:
Cost: 5
Looks: 5
Durability: 5
Function: 5
Comfort: 4
Average: 4.8/5
CONCLUSION: I like this watch. OK…I REALLY like this watch…maybe even love it. Keep in mind that I am an automatic/mechanical watch kinda guy, so it is a bit surprising to me that I’m so smitten with a quartz watch. This is just such a handsome looking, highly legible, nice feeling timepiece! And I cannot find a decent (nor a crappy one, for that matter) Tritium watch out there that comes remotely close to competing with Carnival at this price point. When I considered all the positive attributes of this watch, it made it easy to proclaim this an exceptional deal. Are you looking for a Tritium watch? Get it!
Thanks,
krono
No one, after lighting a lamp, puts it away in a cellar nor under a basket, but on the lampstand, so that those who enter may see the light.
My Reviews: Ma
Edited by: kronological on 09/25/2017 - 18:47
MRsDNF
MRsDNF's picture
Last seen: 8 hours 30 min ago
Thanks for the review krono. I agree with your thoughts on that this is a good looking watch.
My current and or voltage measurements are only relevent to anything that I measure.
Budget light hobby proudly sponsored by my Mastercard and unknowingly paid for by a hard working wife.
djozz said "it came with chinese lettering that is chinese to me".
mattlward
mattlward's picture
Last seen: 1 hour 10 min ago
I am a sucker for electro-mechanical watches. Big Timex Expedition fan. But have killed 2 this year, something has changed with them. I really like this watch, but because of wrist injuries I would have to have a leather band. This has caught my eye since it came out, now I may have to pull the lever on it.
Thanks
EDC rotation:
Convoy S2+, 6*7135, XM-L2 3D, 10 degree TIR, PilotDog lighted tailcap.
Convoy S2+, H17F, XM-L2 4C, lighted tailcap
Zebralight SC52w-L2
Olight S1A
Olight S1R
kronological
Thanks
I don’t think you’ll be disappointed.
My Reviews: Ma
kronological
If this is a watch that you are interested in, you might want to wait a few days to pull the trigger. The vendor is working on a pretty decent discount for those that are interested.
I’ll post the details when received…probably 2-3 days.
My Reviews: Ma
MRsDNF
MRsDNF's picture
Sounds good.
kronological
My Reviews: Ma
Gunga
Gunga's picture
Last seen: 32 min 27 sec ago
Wow. Excellent! Please let us know. I want one!
Gunga
Gunga's picture
Btw. Is it solid or hollow end links?
zipelgas
zipelgas's picture
Last seen: 21 min 5 sec ago
I really like the look of this watch too. Found a nice price for it on aliexpress and using the mobile app and adding all sorts of coupons it now shows me $66.xx Will the mentioned lightinthebox exceptional deal be better. So I’m wondering.. should I pull the triger and is it indeed the same watch? Or are there fake copies out there.
Overkill is just about enough!
Gunga
Gunga's picture
Any updates on the deal?
atbglenn
atbglenn's picture
Last seen: 6 min 31 sec ago
I love watches. This one gets my thumbs up.
I'm a second amendment guy all the way
korpzgrinda
korpzgrinda's picture
Last seen: 4 hours 53 min ago
Location: Eastern Woodlands in the Wilderness of North America
I would be interested to know the details of the discounted promo.
It’s funny though, that in the 5th image (the huge tilted watch face) it shows a fake! Facepalm
According to the review, it’s supposed to have the brand name of “Carnival”, but the picture shows “Carnval”… Big Smile
It seems a little fishy that the merchant is using an image of a fake. If I just came across this online, without a rec from the forum, I would think to myself “hellz nah!”
No Agenda
Last seen: 4 days 18 hours ago
Good eye! I guess you really have to watch out for fakes.
zipelgas
zipelgas's picture
I think the fake picture is just bad photoshop or sad 3D render. None of them first pictures look like a real photograph (at least for me). It seems to me more and more product pictures are 3D generated anyway (watches and flashlights for that matter). Always look for real feedback/review pictures. That’s why sometimes things you order from china look like metal in pictures, but in hand feel like cheap plastic.
zipelgas
zipelgas's picture
mikeyx
Last seen: 2 hours 4 min ago
Just bought one — $69.88 plus shipping at lightinthebox.com
Mike
MRsDNF
MRsDNF's picture
Did you use a coupon? $70.00 us should be under a hundred Aussie dollars but they are showing up around $120.00.
Ronin42
Ronin42's picture
Last seen: 2 days 16 hours ago
I like KRONO
Strong feeling about watches so not a fan.
If we have to have ads for watches can we at least have them in the commercial section?
(“It’s good that most people can’t remember their previous lives. Otherwise
things would be a lot more complicated than they already are.”
Ajaan Lee Dhammadharo)
MRsDNF
MRsDNF's picture
Just checked the original link and its at $91.00.
mikeyx
Try this link…it’s still showing $68.99
http://www.lightinthebox.com/new-carnival-tritium-light-mens-watch-quart...
Mike
kronological
That is the price…$68.99!
Get it here.
Thanks,
krono
My Reviews: Ma
wotcha
Hi folks,
Excuse me dredging up this thread but I was hoping someone would know where I could get a particular version of this watch.
I’m after the blue face with blue markers and SS bezel (NOT the blue bezel). I can find pretty pictures but not a seller.
If it makes any difference I can have it posted to the UK or asia.
isti242
isti242's picture
Last seen: 34 min 40 sec ago
wotcha wrote:
Hi folks,
!https://ae01.alicdn.com/kf/HTB1SRuOnwDD8KJjy0Fdq6AjvXXah/Carnival-luxury...!
You can find it on Aliexpress here.
As I see the “Blue #39” is the version what you’re after.
It’s also available here (version “04”).
wotcha
Hi isti242,
Thanks for the steer, narrowed down and put in basket. Just having problems with AE proceesing payment so will try again tomorrow.
Cheers.
isti242
isti242's picture
You’re welcome!
Now I’m in trouble because I’ve started to contemplate to order a black one for myself too. Smile
nqcken
Last seen: 3 days 5 hours ago
that black one is really nice, if i did not already have a black luminox i would order one.
duvallite
Last seen: 2 weeks 1 day ago
I’ve always really liked this style of watch. Very similar to the 1970’s era Seiko that I still regularly wear. I’d like to get one of these, but the pricing I see is $95.99. Anyone know if that $68.99 price is available somehow?
duvallite
Ended up ordering one of these watches today from AliExpress after having it in my cart for the last couple of days. I went with white face and green tritium. Thanks to waiting until the last day of the their sale when they offered me an additional $7 discount, and also using a couple of coupons, I’m getting this great looking watch for $62.99. Big Smile
leroycp
Last seen: 2 hours 24 min ago
Just arrived today. I went with the blue face blue trits white steel. Very nice. I paid a little more but so far very satisfied.
AlexGT
AlexGT's picture
Last seen: 10 min 9 sec ago
The watch looks nice! Can you post a pic of the actual watch you received? I like the user submitted pictures better than the marketing pictures. gives me a better idea of what to expect.
Thanks!
AlexGT
