Nitecore P30 and rsw1 switch, does not work in turbo mode (VIDEO)
7 posts / 0 new
gastonpatagonico
Last seen: 3 weeks 7 hours ago
Hello, recently arrived p30 with rsw1, testing how it works, momentary switch does not work in turbo mode, if rsw1 side switch, but not in momentary pushbutton, only power up high mode, this is so ho is there any flaw? Use panasonic batteries and 30q charged butt, greetings!
I added a video the quality is not the best but toward the end you can see, as the flashlight works in turbo mode with the switch button and with the prehensile only high, greetings
Could it be the thin diameter of the cables that go towards the contact press the motive that is not operated in turbo?
Edited by: gastonpatagonico on 08/25/2017 - 20:36
Anthon
Last seen: 4 hours 50 min ago
it shouldn’t make any difference compared with the standard tailcap, it’s just a mechanical switch, if you turn off the flashlight in turbo, it should turn on in turbo mode
Does it work with the standard tailcap?
gastonpatagonico
Hi Anthon, if it works with standard tail cap and also with the button that brings in the tail the rsw1, it does not work in turbo with the prehension switch, greetings!
PS: Do not clarify this before buy two P30 and two RSW1
gastonpatagonico
Reply Nitecore, closed topic.
Quote:
Thanks so much for your video and I have understood what you said.
Please noted that this is not a product defect.
The promote reaction design is adopted on the three tail switches of RSW1, this design would cause large resistance when you turn on the turbo mode, so it unable to turn on the brightest mode when using RSW1.
If you turn on both side switch and tail switch on the RSW1, the resistance would become small, and the light would be a little bit brighter.
Hope this would help you and any further question please let me know.
Yours sincerely,
Lexel
Lexel's picture
Last seen: 10 hours 39 min ago
This is why I would prefer a remote tailswitch that has a small battery and a FET switching on and off
this would have even less than a classic mechanical switch
gastonpatagonico
Hi Lexel, sorry I do not speak English I use translator, could you put an example of a remote switch that you recommend? Greetings.
Lexel
Lexel's picture
you replace the mechanical momentary switch with a Metal Oxide Semiconductor Field Effect Transistor
to power the MOSFETransistor you need a very little current (less than 1uA) which can be provided by a small battery
a small poweerful MOSFET
https://www.digikey.de/product-detail/de/nexperia-usa-inc/PSMN2R4-30MLDX...
like this, just without the driver just the MOSFET
https://ericwblanton.wordpress.com/2017/05/29/featured-content-6/
instead a momentary button you have the cord of the remote tailswitch
