Hey my friends!
banggood listed the NEW
LUMINTOP SDmini II
XP-L HI 920LM USB Rechargeable LED Flashlight With Side Light
the deal is available - but banggood needs to add a option to choose the color of the side light, so please wait with ordering!
Introduction:
SDmini II is a multifunction dual-light rechargeable flashlight. Utilizes XP-L HI LED and powered by one 18650 battery, the head light delivers a max 920 lumens output and a 320-meter far reaching beam distance. Four kinds of led colors for side light options: neutral white, red, blue and green. Dual lights can works simultaneously for ahead and underfoot illuminations. Built-in Micro USB charging with charging indicators, compact sizes, stainless steel body clip, tail standing ability and IPX-8 rated protection, SDmini II is a must in your searching, caving, hiking, camping etc activities.
Specification:
Product name: | LUMINTOP SDmini II XP-L HI 920LM LED Flashlight With Side Light |
Brand: | LUMINTOP |
Model: | SDmini II |
Emitter Type: | XP-L HI |
Material: | Aerospace aluminum alloy |
Mode: | High,Mid,Low,Moonlight + Strobe,SOS,Beacon |
Lumens: | 920LM,270LM,85LM,1LM+920LM |
Runtime: | 2h30min,6h15min,21h45min,775h+/ |
Battery Configurations: | 1*18650 / 2*CR123A battery (not included) |
Working Voltage: | 2.8-8.4V |
Switch Type: | Clicky |
Switch Location: | Body side of the flashlight |
Peak Beam Intensity: | 26082cd |
Impact Resistant | 1.5m |
Max Output: | 920lumens |
Range: | 320m |
Waterproof: | IPX-8 waterproof up to 2meters |
Color: | Black |
Weight: | 94.6g (excluding battery) |
Size: | 109*33*25.4mm (Length*head diameter*tube diameter) |
Side light: | XP-G2 R5 LED | XP-E LED |
Light Color | Neutral white | Red,Green,Blue |
Mode: | High,Low | |
Lumens | 124lumens,30lumens | |
Runtime | 13.5h,56h | |
Light Range: | 25meters | |
Peak Beam Intensity: | 142cd |
Features:
1.Front and side dual lights illuminations
2.XP-L HI LED for head-light, neutral white, red, blue and green light for side-light options, with a lifespan of 50,000 hours
3.Max 920 lumens output with a max 320 meters beam distance
4.Integrated Micro USB charging with charging indicators
5.High strength aerospace aluminum alloy construction with anti-scratching type HAIII military grade finish
6.Optimized ultra-precise aluminum alloy reflector offers a further beam distance
7.Dual-side AR coated, tempered window, maximizes 99% light transmission
8.Detachable stainless steel clip for easy carrying
9.Waterproof to IPX-8 rated classification
