WTT: Reflector of H03 wanted. Trade for TIR
33 posts / 0 new
LightRider
LightRider's picture
Last seen: 3 months 3 days ago
Hello friends. I have two H03 headlights with the TIR optic. I would rather have the reflector. Anyone out there want to trade their reflectors for my TIRs?
Jerommel
Jerommel's picture
Last seen: 2 months 5 days ago
I happen to have 2 spare Skilhunt headlamp reflectors, i replaced them with TIR optics.
But i’m not sure if it’ll be worth the shipping costs from EU to USA.
You’ll need the 2 glass lenses too, but i think i have used them in other lights.
If you want i will check later, gotta do some other things now.
..waiting for parts..
Still looking for 5” parabolic reflector (for recoil light)
LightRider
Ok thanks friend! The lens should be easier to source than the reflector. Any idea on shipping cost? If you pm your address I can check.
Jerommel
Jerommel's picture
When i can keep it under 20 grams it’s €1.33 to USA.
Up to 50 grams it’s twice that.
Much less than i expected.
I’ll see what i can find in my box of glass lenses.
But if you have the exact sizes for the lenses you need (because i’m not sure which exact lens is from a Skilhunt), and you can source them easily i’d rather keep the one i have left (but i may have equivalents without AR coating).
Just let me know what you want (to know).
giorgoskok
giorgoskok's picture
Last seen: 1 week 2 days ago
I was thinking the same thing , swapping H03’s optic with H03R’s reflector Big Smile
Jerommel
Jerommel's picture
I have a H02R and i recently put a non-Skilhunt TIR in it, and i put the black bezel of a H03F on it (without the hinge part, i cut that off and filed it flat) and also removed the stainless steel switch bezel and replaced the switch boot with a larger black one to fill the cavity.
Looks really cool now, and of course no more tint shift.
And i have a H03F on which i put the stainless steel bezel of the H02R and a Skilhunt TIR, which can be bought here from 20 to 60°:
https://www.aliexpress.com/item/CREE-XML-lens-T5-T6-U2-Lens-Diameter-17m...
They’re identical to the Skilhunt TIRs.
Yeah, the stock H03F looks cool i.m.o., but the ‘door’ was always rattling and not held in position properly.
It also scatters the light to the sides (and often i the eyes of the user), which is just annoying
So no more F version for me.
@ LightRider:
I found the reflectors.
They weigh 0.6 grams each. Big Smile
So shipping cost will be €1.33
Jerommel
Jerommel's picture
O, wait, if forgot to mention one important thing:
Centring gaskets !
They need to be 0.6 to 0.7mm thick and fit the 7mm hole of the reflector.
I have one of them left i my parts box, i used the other one already.
But it’s the last one i have of that type, so i’d rather keep it myself…
I did recently order some of these though:
https://www.fasttech.com/p/4512104
But i don’t know how thick they are (they’re not in yet, haven’t even been shipped yet).
Maybe as an alternative idea to increase throw you could try these:
https://www.aliexpress.com/item/CREE-XML-LED-Lens-Diameter-17mm-60-degre...
Smooth surface, the 20° version (unfortunately no 10 or 15° version available).
Same form factor as the Skilhunt TIR, easy swap.
LightRider
Thanks for the tir link! I may try one or two of those?
PM sent to discuss the reflectors. Smile
Lexel
Lexel's picture
Last seen: 10 hours 16 min ago
the lens from Jetbeam Jet-1 MK fits perfectly in the H03
the 14mm lens from kaidomain is a bit thicker but should fit as well
LightRider
Lexel wrote:
the lens from Jetbeam Jet-1 MK fits perfectly in the H03 the 14mm lens from kaidomain is a bit thicker but should fit as well
The lens or the reflector? I was thinking the lens is greater than 14mm. No? I’ll measure it when I get a chance
Lexel
Lexel's picture
err 17mm lens, the reflector inner diameter was 14mm
the Jetbeam reflector is deeper
this one should fit
http://www.kaidomain.com/p/S023866.16_9mm-x-1_0mm-Double-Multilayer-Coat...
Jerommel
Jerommel's picture
Jerommel
Jerommel's picture
A thicker lens will probably prevent the bezel from screwing down to the head all the way.
I would suggest to search for a lens with the exact same thickness as the Skilhunt lens.
Lexel
Lexel's picture
the 16.9×1mm fits perfectly, I remembered it thicker
LightRider
Jerommel, are you still willing to sell me the reflectors or I can send you the tirs they replace?
giorgoskok
I would be interested in the reflector’s diameter & height so i can buy one .
Thanks
Jerommel
Jerommel's picture
Yes, we’re gonna do an exchange (see PM).
Jerommel
Jerommel's picture
Thanks
It’s 15mm diameter and 17.3mm 7.3mm high.
giorgoskok
Thanks ! It’ll be tough finding one .
Jerommel
Jerommel's picture
MISTAKE!
it’s 7.3mm high.
Sorry..
treoneo
I thought the same. I want the H03R but take too long to get here. I can get an H03 on Amazon in two days.
Where can I purchase the reflector and lens that will fit from? Prefer USA.
finges
Last seen: 22 hours 59 min ago
What about this reflector? http://www.kaidomain.com/p/S021651.15_8-D-x-8_8mm-H-OP-Aluminum-Reflector
Maybe it can be reduced in length…
Jerommel
Jerommel's picture
Brands should sell spare parts i.m.o.
In this case, a headlamp reflector set = gasket, reflector, lens.
For TIR replacements they can simply refer to Yajiamei on AliExpress.
Pavlo
Last seen: 1 month 1 day ago
Hi guys,
I have emailed Skilhunt twice about TIR and Reflector parts and never got a reply.
Has anybody had any luck finding a 3rd party reflector that fits and works?
Thank you!
giorgoskok
Me too
No…
LightRider
I ordered one to try. It’s been delivered but I can’t find it. If I do I’ll let you know…
Lexel
Lexel's picture
a downside of the reflector one is the hotspot of the NW is pretty yellow
I may consider a change, with the new AR lens, but it has its price to get a reflector H03 compared to the coupon TIR
Pavlo
Please keep us posted! Thanks
Jerommel
Jerommel's picture
Lexel wrote:
a downside of the reflector one is the hotspot of the NW is pretty yellow.
Yeah, typical small reflector hotspot, with a somewhat cooler white rim around the warmer circle of light.
I hate that.
It’s why i replaced the small reflectors of many of my lights with TIR optics.
Pavlo
Jerommel wrote:
Yeah, typical small reflector hotspot, with a somewhat cooler white rim around the warmer circle of light. I hate that. It’s why i replaced the small reflectors of many of my lights with TIR optics.
What do you think the stock TIR resemble most in terms of angle? 30 degrees?
What TIR angles do you like most for your H03 or other lights?
I find the stock TIR is nice up close, but as soon as you want to use it to see further away, it diffuses and spreads the light too much.
Lexel
Lexel's picture
yeah reflector has its advantages outside
but walking on snow with the NW Emitter looks yellow hotspot and white corona
