Test/review of Efest PRO C4 Charger 2017
3 posts / 0 new
HKJ's picture
Last seen: 7 min 5 sec ago
This is a simple quad cell mains and 12V powered LiIon charger without any settings.
DSC_0203 DSC_0204 DSC_0205 DSC_0206
It arrived in a small cardboard box with specifications on it.
The box included the charger, a mains cable, a warranty card and the instruction sheet.
The charger has a mains socket with universal power (100-240VAC 50/60Hz) and a 12V DC connector.
The only user interface is a led light for each channel, it is red when charging and green at other times.
Specifications are on the bottom, but not very easy to read.
The slots uses the classical slider construction and it works fine.
The slots can work from 30.5 mm to 71mm. This means that it will handle nearly all 18650/26650 batteries.
The charger can handle 71 mm long batteries including flat top cells.
The charger current is on the high side for regular small cells, but acceptable for IMR batteries
  • When not connected to power it will discharges with less than 0.1mA.
  • Below 0.6V the charger will not detect a battery
  • Between 0.6V and 3.0V the charger will charge with about 70mA to 130mA
  • Above 3.0V the charger will use regular charging.
  • Charger will restart when voltage drops slightly.
  • It will restart charging on reinsertion of the battery or power cycling.
  • Current will automatic change from 0.5A to 1A when batteries are full or removed.
  • Power consumptions when idle without battery is 0.35 watt
  • From 12V it need 18mA when idle without battery.
The charger do a CC/CV charge curve, but has trouble terminating. The charge voltage is on the low side.
Sometimes it terminated perfectly, sometimes not.
Lower capacity is faster to charge, but again the charger gets into the on/off cycle at the end of charging.
Here the on/off cycle is slow.
With this old cell it is no surprise that the charger has problems terminating.
It is the same with smaller cells, but the charger is not really designed for this type of cells (They need to be high current types).
With 3 or 4 cells the charger uses 0.5A charge current
Running it from a 12V supply it can be seen that it needs about 0.8A for charging four cells.
M1: 41,5°C, M2: 46,1°C, M3: 46,4°C, M4: 42,9°C, M5: 50,5°C, M6: 57,9°C, HS1: 67,2°C
M1: 37,1°C, M2: 41,8°C, M3: 41,6°C, M4: 37,8°C, M5: 54,0°C, HS1: 63,8°C
Sweeping the battery voltage from zero to 4.25 shows charge current at the different charge levels.
I did also add a curve to show how much heat is generated in the charger, most of the time the voltage will be between 3.5V and 4V, i.e. a bit above 2 watt with one cell.
The charger needs about 3 second to start.
Testing the charger with 2830 volt and 4242 volt between mains and low volt side, did not show any safety problems.
For new and IMR (High current) batteries this charger is fairly good, but with older cells it has termination problems.
The charger was supplied by Efest for review.
Nice to see “simple” chargers without LCD screens or a lot of LEDs to show status… It sould be not very expensive
Pity the problem with termination.
Thanks for your hard work giving us such a detailed and exhaustive reviews/tests
The most ugly place in the world! Surprised
MRsDNF's picture
Last seen: 1 hour 16 min ago
Thanks HKJ. Another very useful review. Thumbs Up
My current and or voltage measurements are only relevent to anything that I measure.
Budget light hobby proudly sponsored by my Mastercard and unknowingly paid for by a hard working wife.
djozz said "it came with chinese lettering that is chinese to me".
