As the title says - what equipment do I need to start data logging voltage and current during various activities? Charging cells, discharging (at various currents), LED bench testing, etc.
Budget minded solutions are always good, but I’m not opposed to purchasing quality tools when it is appropriate and provides value.
The EBD-USB+ is pretty good for logging. Just make appropriate adapters to connect to its USB input and output. It can handle 0-21 volts and 0-4 amps and also acts as a constant current load for testing capacity. For just batteries the SkyRC MC3000 is great.
In the case of measuring current, I assume it is difficult (or at least lots of $$$:money_mouth_face: to get a device that will handle high currents/power by itself internally - I’d this where things like shunt resistors come into play? Instead of measuring actual 20A current, you instead measure the voltage across a shunt resistor of known R and calculate out the current?
Well it will has Bluetooth in it and a control software for the phone for logging data, low burden range, 15V diode test, running on AAs, compact. SD-Slot.
A solid meter with some rare features. And it’s to pricy for me too.
They come with optically isolated USB and RS-232 cables and basic PC logging software which can export the results in .txt or .csv files for post processing. Apparently other software is also compatible.
Edit: some vendors don’t include the USB cable, just the RS-232, make sure you choose one who does.
The 61E would probably be worth the extra, at list price.
I haven’t put them to use yet in a logging setup, but they seem to have the basics needed. You could even use the 10A setting for current measurement, but I think you’d be much better off using a shunt. You will get more precise readings using a shunt in any case, compared with a clamp meter.
DIY shunts are not too difficult to make, but also easily available on ebay:
Lots and lots of information about these popular meters, certainly not perfect but I find them very good as a big step up from a basic DMM.
E.g. the reviews at: (part 2 shows the logging software).
