Test/review of Sofirn AAA 900mAh (Black-Blue)
3 posts / 0 new
HKJ
HKJ's picture
Last seen: 1 hour 55 min ago
DSC_0982
Official specifications:
  • Capacity: 900mAh
  • Voltage: 1.2V
  • Chemistry: Ni-MH
  • Rechargeable: Yes
  • PCB Protected Board: No
Sofirn%20AAA%20900mAh%20(Black-Blue)-info
Maximum temperature raise at different discharge currents: 1A:+2,2°C, 2A:+5,4°C, 3A:+8,4°C, 5A:+12,3°C
In my test Sofirn AAA batteries this is the lowest capacity cells (The other are 1100mAh and 1800mAh), can this battery live up to its specifications?
DSC_0981
DSC_0983 DSC_0984
DSC_0985
DSC_0986
DSC_0987
Sofirn%20AAA%20900mAh%20(Black-Blue)-Capacity
The discharge curves looks fine with a very good match between the cells and capacity is close to 900mAh.
Sofirn%20AAA%20900mAh%20(Black-Blue)-CapacityTime
Sofirn%20AAA%20900mAh%20(Black-Blue)-CapacityTimeHours
Sofirn%20AAA%20900mAh%20(Black-Blue)-Energy
Sofirn%20AAA%20900mAh%20(Black-Blue)-PowerLoadTime
Sofirn%20AAA%20900mAh%20(Black-Blue)-CurrentTest
Sofirn%20AAA%20900mAh%20(Black-Blue)-Charge
Conclusion
These cells has about the same capacity as the 1100mAh & 1800mAh and that is about 900mAh.
The discharge curves looks fine.
Notes and links
Compare to other AA/AAA batteries: Alkaline/NiMH/Lithium
Pete7874
Pete7874's picture
Last seen: 3 hours 19 min ago
LOL! So they are all basically the same cells inside, just different labels and price points. Facepalm
Thanks for the review, HKJ.
Barkuti
Barkuti's picture
Last seen: 1 hour 4 min ago
Not too bad, really. This product is obviously geared for the knowledgeable people, and it is a good product. The cells labeled 1100 and 1800 are for the crowds of foolish and philistines, still being good cells if mislabeled. Can't say the same with certain other brands…
Cheers
The Light Innocent I am
Deleting a post and redoing it causes the forum thread answer notifications to become invalid. Thus, if you need to change your just published post, edit it. Thanks.
Please avoid quoting lenghty posts, namely with nested quotes. Trim the quote down to the essential. Helps with forum neatness and legibility. Thanks.
Localized AliExpress links mess up with the language setting of whoever clicks or taps on them. While this is a fault of the AliExpress system, turning localized links into global links helps and is easy; just change the locale letters in the url for www. Example:
https://es.aliexpress.com/item/bla-bla-bla.html turns into https://www.aliexpress.com/item/bla-bla-bla.html. Thumbs Up
