[Modding] Astrolux MF01 --> OSH park NarsilM
97 posts / 0 new
Lexel
Lexel's picture
Last seen: 54 min 51 sec ago
JIGHEADWORM wrote:
Looks a mess but got all leds working.
I got today also a light from Canada v2, so modding the MCPCB as well
I connected it the was it lights up with central connection, but I will place the main current cables to the spots where the resistance is optimized
JIGHEADWORM
Last seen: 1 month 1 week ago
!{width:50%}http://www.metronixlaser.de/bilder/flashlight/IMG_4638.jpg!
What size wire did you use ? I used 20 awg . I bypassed all te springs on the driver and carrier and got 19100 lumens on startup, it stepped down before 30s with a 60c temp setting.
Lexel
Lexel's picture
I wired the briges up to connect 2 leads for V+ and V-
I used 0.35mm² for the small bridge wires, as they only carry one 2S LED pair
so if I get this straight not reducing the mm² to the driver I would need 9×0.35mm€ so 3mm²
The leads to the driver I can go with 2×2 1.0mm² or barely fit 1.5mm² leads, so 2-3mm² each combined wire
Lexel
Lexel's picture
I have now his light fully modded
leads are soldered to spots to get lowest resistance
Theodore41
Last seen: 3 hours 20 min ago
Have you measured it please?How many Lumens-Candelas I mean?
JIGHEADWORM
I’m interested to see what output you get i ran mine last night and got 17800 lumens stepped down before 30s.I got 19000 last week i don’t know if it was because of the colder temps in workshop or just an anomally. This is probably my favorite light right now.
JIGHEADWORM
One thing has come up since the driver change. the springs in the carrier are not up to the task.My solder blobed vtc6’s will fall out now unless you hold them in.Anybody else had this problem. Mine are bypassed.
Lexel
Lexel's picture
They should have bronze alloy springs, those usually conduct well and should not get hot especially when bridged
swap out for steel springs and 0.5mm² bypass, almost no current flow in the springs and they are a lot stiffer and more elastic than bronze springs
JIGHEADWORM
swap out for steel springs and 0.5mm² bypass, almost no current flow in the springs and they are a lot stiffer and more elastic than bronze springs[/q
I checked springs after a run on turbo and springs are not hot they have just got more compressed with use.
Ronin42
Ronin42's picture
Last seen: 6 months 3 weeks ago
Cool mod but over my head.
too bad Sad
To me it looks like spaghetti. I keep thinking there has got to be a better way.
Too bad someone (the mfg) does not make the correct mcpcb so we can plug and play two parts instead of one and spaghetti.
(“It’s good that most people can’t remember their previous lives. Otherwise
things would be a lot more complicated than they already are.”
Ajaan Lee Dhammadharo)
Ronin42
Ronin42's picture
Come to think of it this sounds like a group buy opportunity. have the mfg drop the better driver and make a new mcpcb for the emitters.
Lexel
Lexel's picture
too bad Sad
I am sure someone in the USA would make it for you, shipping to Germany would be a dealbreaker
Jtm94
Last seen: 2 weeks 3 days ago
I did the same mod and my carrier springs are also not happy, but I haven’t bypassed them yet. Likely gonna need to get new springs anyone know of a good source for new springs?
JasonWW
JasonWW's picture
Last seen: 8 hours 22 min ago
Mtn Elec might have the size you need. They are in US so shipping should be fast.
JIGHEADWORM
Bypassing the carrier springs will take care of the problem.My lumens jumped almost 2000 with carrier springs bypass.
Jtm94
Alright I’ll report back any gain from the bypass sometime today.
Would These suffice? They only have 4 springs so not a lot to choose from. Either these or the beryllium copper springs, but those are quite soft from what I hear.
Lexel
Lexel's picture
steel springs should be bypassed as they get hot
Copper alloy springs are fine not bypassed
for example
https://www.fasttech.com/products/1616/10001712/1347100-batterydriver-co...
Jtm94
I got 16,167 lumens after spring bypasses, but I didn’t top off the batteries after a few turbo runs. Ordered those springs too thanks Lexel. Always nice to have extras.
This thing is crazy now I can cook things with the amount of light it puts out.
Lexel
Lexel's picture
Also the BLF GT code offers the double click to get full power while ramping is limited to 80%
This implemented in those lights may be useful to keep heat in control
Jtm94
Fresh batteries after bypass and I got a max of 17,360 in my shoebox! It doesn’t seem my springs are getting worse since the bypasses so that’s a good thing.
Also put together a little album to document my mod with some snowy beamshots in a wide open area.
Edness
Edness's picture
Jtm94 wrote:
Fresh batteries after bypass and I got a max of 17,360 in my shoebox! It doesn’t seem my springs are getting worse since the bypasses so that’s a good thing. Also put together a little album to document my mod with some snowy beamshots in a wide open area.
What batteries are you running ?
giorgoskok
giorgoskok's picture
Last seen: 3 days 7 hours ago
For people who mod their lights , i would suggest VTC5A batteries , 30Q might have a hard time
JIGHEADWORM
True i actully got 19000 with fresh vtc5a batteries ,30q’s get around 17000 in my light .
Jtm94
I’m running Samsung 30Qs. I’m pretty happy with them and the set is already married. I have my 4 VTC5As in my Q8. The VTC5A only start to pull away from the 30Q past 7amps.
I’m quite content with the 17,000 as it’s fleeting and heats up noticeably faster on the fresh cells. The light will spend most of it’s time at less than half power. I may give it a brief run with the VTC5A just to see 19,000 pop up. Ohyeah, the VTC5A are shorter and I’m concerned about my sagged springs holding them in enough to not lose connection.
Has anyone ran this with a clamp meter to see what kind of amps it’s drawing?
JasonWW
JasonWW's picture
Not with a FET driver. Lexel modded the carrier on a stock light and measured 16 amps. Iirc.
Lexel
Lexel's picture
I modded today the light of patmurris
Added also some GITD tape
JasonWW
JasonWW's picture
^^ Cool!
It’s like a bigger version of the DQG Tiny 7X xpg2 seen below.
jdh00
jdh00's picture
Lexel, I got your driver installed. Thanks a lot for it and your documentation on the MCPCB wiring mods necessary. This thing is a monster! Smile
JEK
Lexel wrote:
new version of MF01 needs to get a MCPCB modification as well
you can ignore the cables I put in there, basically you can wire it like you want, just make sure the red circles and the black circles are connected towards each other
the cables of me are in the 3 120° sections just different approaches
you cut so that 2 LEDs are together in series, while to board had originally 6 in series, so 2 cuts per 120° section
Need to do this in v2 driver to install the Lexel driver?
jdh00
jdh00's picture
Yes, you do.
