This is a triple-emitter light that has a lot going for it, but a couple design flaws that Sofirn says will be corrected in the next version. Assuming the light is supposed to be a high performance light, the flaws are an inadequate emitter thermal path in the MCPCB and a low output cell. Other than that, the light has all the ingredients needed for high performance general purpose light. I received this light steeply discounted from Sofirn to review. Here is the link that I used to purchase the light. I don't know if it's one of those affiliate links or anything, but if it is, I have nothing to do with it. The kit I received included the a protected cell and battery charger.
Also has a 5 mode group that is accessed by 3 quick complete clicks. The last mode from this group will be memorized, but the light returns to the 3 mode group after the light is turned off. So you can have Strobe available from off, but if you change modes after turn on, you will have to reselect the 5 mode group.
LVP at 2.8 volts (I haven't tested this yet)
Retainer rings for both the Driver and Tail Switch
Tail stands.
Has passages to prevent lanyard from interfering with tail standing.
Spring electrical by-passes
2800mAh protected cell. Trips over 6 amps (measured 2779mAh at 500mA on Lii-500, 38mR)
Cons:
Indirect thermal aluminum MCPCB.
Protected cell that trips on high when fully charged.
This helps protect the XP-G3's
No Moon level mode
Pictures:
Arrived in big box from Amazon fulfillment. The tightly packed product box appears to provide adequate protection of the contents. Baggie has lanyard and spare o-rings.
The cell measured well in capacity tests. It trips above 6amps of current.
Both springs are bypassed by __ gauge wire. Nice square cut threads that arrived well lubed.
Square-cut threads also on the top end of the battery tube:
Passages to keep lanyard out of way for tail standing.
Driver Pics and Testing Results:
Beam Shots
Low, Medium, High modes:
Low and Medium. High was too saturated this close.
Conclusion:
Other than the thermal path flaw, I really like this light. I've been using it as is and find it nice for real world usage. I would only recommend this version of the light to experienced users due the risks associated with DD lights. Users need to be willing to use healthy, low output cells as is or be willing to modify the light if they want high performance.
Sofirn tells me they will by using a DTP copper MCPCB with XP-L emitters in the next version. Based on that upcoming change and what was done right in this version, the new version should be a winner.
Last I heard from Tracy, the WW version was scuttled.
Lotta people who are used to Angry Blue™ light from those 3×AAA multi-LED lights and the like, are wonderfully surprised when they see something that looks like “real light”.
Damn, that ain’t bad, <12bux for it! Think I’ll get another one, in case mine “walks off” somewhere…
Hi bikenber73. If you receive the new version (don't know if it is available yet), you should be fine with unprotected cells. If you receive the first version (like reviewed in this thread), you will need protected to avoid frying the emitters.
It's recently came out. I've been putting it though its paces and it's sweet. It's a litte beefier and has a side switch. It's similar to the hot rods we build here, but tamed down to be safer for the masses. It's rated at 2540 lumens (IIRC), but I measured 3K at startup and 2900 at 30 seconds with the stock cell (8.8 amps at the tail). It's DD. So performance will depend on the cell. Sofirn tamed it down by using XPL emitters (high Vf), protected cell, and FW.
The heat sinking on the light is top notch. Carries the heat from the head to the tail efficiently. The whole light warms up as you use it. Very nice. I should be posting a review in the next few days.
A 30Q would probably toast the old version (one reviewed in this thread) quite handily. I'm planning to mod mine by drilling a hole through the thermal pads and emitter shelf and then pounding in a copper wire. Then I'll probably reflow in some Nichia 219C's or something.
Does your light have a side switch or a tail switch?
Just the tail switch, I read the review but decided it would be a great idea to see if I could kill it with the 30q. I have to say that it was pretty impressive with the battery that it came with for the less than one minute I used it before I said, “lets put a new battery in that is fully charged”! That lasted about a millisecond after I hit the power switch but was a very bright flash…
