Astrolux C8
37 posts / 0 new
-X3-
-X3-'s picture
Last seen: 40 min 7 sec ago
Astrolux C8
So, I saw that this morning on Reddit, it seems that Banggood decided to make its own batch of the classic C8 :
They claim 1300lms and 152kCd and I don’t trust that at all… what do you think ?
"Hey -X3-, do you have a flashlight ?"   "-X3-, can I borrow one of your flashlights ?"
My Flashlight public album (mods, emitter swaps, eye candy)
My reviews channel (French language, Olight, Thorfire, Sofirn, Lumintop : 60+ lights tested)
My personal channel (including Olight SR mini, S1, S2, S1A and S-mini disassembly)
M4DM4X blog, saves you $$$
Edited by: -X3- on 10/30/2017 - 08:27
Agro
Last seen: 3 min 8 sec ago
I believe the numbers may be OK.
You just need to focus 2 (3?) flashlights at the lux meter.
AdrianWA
AdrianWA's picture
Last seen: 19 hours 34 min ago
Looks like a Convoy C8 rebadge.
AgentSteel
AgentSteel's picture
Last seen: 1 hour 2 min ago
with BLF A6 driver, and a bit pricier
Quidquid latine dictum sit, altum sonatur
desmondkun
desmondkun's picture
Last seen: 1 hour 24 min ago
I want a triple LED C8 like Sofirn did too.
Take care of your flashlight and your flashlight will take care of you.
-X3-
-X3-'s picture
BTW, what’s the best throw one can achieve with an XP-L HI and a FET driver in a C8 ? Like 100kCd ? less ?
g_sintornillos
g_sintornillos's picture
Last seen: 1 month 4 days ago
They could mount it with XP-L HI and Bistro or even better with Narsil
Sorry for my bad English (gogole transtorla)
djozz
djozz's picture
Last seen: 1 hour 35 min ago
125kcd must be possible, perhaps not 150. My clear Convoy C8 (AR-coated lens, good reflector, direct driver, dedomed XP-G2 S4 2B) does 180kcd.
link to djozz tests
“I used to think that top environmental problems were biodiversity loss, ecosystem collapse and climate change. I thought that thirty years of good science could address these problems. I was wrong. The top environmental problems are selfishness, greed and apathy, and to deal with these we need a cultural and spiritual transformation. And we scientists don’t know how to do that.”   (Gus Speth)
legofaith
legofaith's picture
Last seen: 8 months 1 week ago
it will be great if u colud make ur own design and then buy it, nobody do that, what a pity Shocked
giorgoskok
giorgoskok's picture
Last seen: 11 hours 56 min ago
120-125kcd is possible with xp-l hi & fet driver
Delta_V
Last seen: 18 hours 38 min ago
Even that seems a tad high. Apparently the Emisar D1S was tested at around 1300 lumens and 120 kcd (TK’s review reported less, but it seems her testing equipment always runs lower than most), and that is with a larger reflector. Hard to believe a C8-sized reflector would be able to match that, much less beat it.
The Convoy C8 with XPL-Hi and smooth reflector seems to clock in at around 1000 lumens and 70 kcd. So I would guess this thing, with an extra 30% more lumens, will clock in somewhere around the 100 kcd mark.
Bo4ka
Last seen: 5 months 5 days ago
My C8 with xpl-hi, blf a6 driver, spring bypass and ar coated lens does about 87k lux.
Build the same one, but with xp-g2 (dedomed in gasolin) and unfortunately it had around half lumen, 2/3 throw and 3000k tint afterwards Sad
giorgoskok
I thought D1S had a C8 sized reflector , are there it’s dimensions in any post ?
Delta_V
Haven’t seen a teardown to confirm reflector size, but the head diameter of the C8 is about 44mm, compared with 50mm for the D1S.
Pok
Pok's picture
My measurement.
C8 XML2 U2 + AMC7138 × 8
850+-LM 30,000+-cd
C8 silver + new firmware 12 modes
850LM+- 60,000cd+-
C8 XHP35 Hi + H2-C
1400LM+- 70,000cd+-
Nitecore P30 spec 100,000cd
my measure 1000LM 85,000cd
C8 SST40 dome + A17DD
LV7 : 2300LM+- 84,000cd
LV6 : 1400LM
LV5 : 750LM
Utorch UT02 CW
1000LM 90,000cd
C8 silver + A17DD
1400LM+- 110,000cd+- best focus
C8 XML2 U4 dedome + A17DD
1500LM+- 120,000cd+-
C8 SST-40 dedome + A17DD
2000+- LM 130,000cd+-
I have XML2 U4 50+ pcs. , XPL Hi 50+ pcs , SST-40 from KD 40+ pcs.
Some are high Vf but I choose lower Vf with my test.
stephenk
stephenk's picture
Last seen: 1 day 8 hours ago
Interesting development. Always wanted a low cost >100kcd 18650 thrower, and now there will be a choice soon!
Gea2427
Last seen: 4 weeks 1 day ago
Pok wrote:
My measurement.
850+-LM 30,000+-cd
850LM+- 60,000cd+-
C8 XHP35 Hi + H2-C
1400LM+- 70,000cd+-
LV6 : 1400LM
LV5 : 750LM
Utorch UT02 CW
1000LM 90,000cd
C8 silver + A17DD
Did you mod a c8 with a xhp35 hi?
everydaysurvivalgear
everydaysurvivalgear's picture
Last seen: 12 min 26 sec ago
I think a done up C8 with an XPL-HI would get around 90-100Kcd from my testing. My XPG2 and XPL dedomed C8s both do nearly 150Kcd i am not sure if my number are low. I have never been able to beat this number in a C8.
Delta_V
Looks like they may have updated the product page.
Now claiming 102kcd, which seems intuitively reasonable. If the Convoy C8 hits 70kcd at 1000 lumens, and the Emisar D1S hits ~120kcd at 1300 lumens with a larger reflector, 100kcd at 1300 lumens in the Astrolux C8 seems believable.
NikolaS
NikolaS's picture
Last seen: 1 month 1 week ago
My stock Sofirn C8T does 80kcd, and that is as far I know the best stock performing C8 . For 15$ you get original XPL-HI V3 (2B/3B)tint not sure , 17mm copper DTP board, and bridged springs from factory….
With full battery 4.2 Amp at tail, so that Astrolux C8 must be driven up to 5.5-6 Amp to achive 120kcd
djozz
djozz's picture
Nice! You get stock what used to be a proper mod. But 30 dollar is a bit too much for it, a Convoy C8 that basically has the same production costs, costs half of that.
link to djozz tests
stephenk
stephenk's picture
Seems more realistic. 100kcd could probably be achieved with 12×7135 instead of FET.
I’ll believe it when i see it Silly
Only the very best C8 can get 150kcd and 100kcd is more reasonable but they may still have to work to the centering ring?
mortuus
mortuus's picture
Last seen: 1 hour 41 min ago
i may be slow but what is the point in a clone of the c8 ? seems confusing….
...where Frugal meets with Flashlight!
NikolaS
NikolaS's picture
There is no clone of C8, they are all hybrids, so finding better then the best in terms of performance and quality is always fun..
This one is already modded using a BLF A6 driver and i would assume a direct thermal path MCPCB.
Barkuti
Barkuti's picture
Last seen: 14 min 6 sec ago
After reading this, I've started to believe in my Sofirn C8T smartphone lux readings. Published a little review of it here a few hours ago. The driver is pretty good.
Cheers Party
NikolaS
NikolaS's picture
1+ for Sofirn Thumbs Up
hmihaylov
Last seen: 1 month 2 hours ago
I am on the brink of buing this one (it is on sale now). What stops me is that it is stated to be with the A6 driver, which has a timed and not thermal stepdown. Does anyone know which level the light steps down to?
May the Light illumine you Wink
mortuus
mortuus's picture
a bit high price, dont see the point in this one, already have the c8 silver with xpl-hi emitter so..
bibihang
bibihang's picture
Last seen: 2 weeks 5 days ago
I believe the quality and performance are good, but it is a bit pricey at $29 to be honest.
Anybody has tried to swap the stock driver of the clear Convoy C8 XP-L HI into an FET driver? And what is the lux reading you can get?
