Haikelite MT07S Current Consumption
8 posts / 0 new
DENGOH
DENGOH's picture
Last seen: 1 month 3 days ago
I measured mine with parasitic drain of 337.5uA. Moonlight mode consumes 7.85mA.
Battery voltage was 15.12 v. Assuming 3400mAh batteries, 3400/7.85/24=18days, far from spec of 45days for moonlight mode.
Didn’t measure higher output mode cause higher current will need better contact to have full performance.
Anyone has measured his MT07S and care to share here?
cool i'll see you when you get there
DENGOH
DENGOH's picture
Retest again just now with freshly charged HG2, battery voltage 16.3v while in standby mode, current 337.5uA
Freshly charged battery has about 4.16v each, total voltage should be 16.64v, somehow standby mode pull the voltage down and stabilize to 16.3v within about 20s.
DENGOH
DENGOH's picture
Last night the red led on button blink a few seconds and light output dropped from Turbo to low. Took the unprotected HG2 out and all measured around 3.03v. Should be still usable for low output, but what’s the fun. So i reloaded with fresh HG2.
hIKARInoob
hIKARInoob's picture
Last seen: 4 hours 9 min ago
~320 μA for both my MT07S 70.s version.
d_t_a
Last seen: 15 hours 49 min ago
I have a question, how does one measure parasitic drain?
(so far, I only know how to measure tailcap current with a DMM)
hIKARInoob
Look under current consumption. You want to measure current consumption when the light is off; this is standby/parasitic drain.
http://www.lygte-info.dk/info/Measurement%20UK.html
Rusty Joe
Rusty Joe's picture
Last seen: 4 hours 27 min ago
Does your MT07S blink rapidly and not turn off when the batteries get low? Mine just went into strobe twice after briefly flashing and then stayed in strobe until it just went off.
Eat Once a Day - Lose Weight - Feel Great!
www.omad.info
DENGOH
DENGOH's picture
Mine blinks a few times when battery is low, and output automatically drop to low and there is no more blinking. I didn’t wait until it turn off, so i am not sure it will turn itself off or not.
