List of multimeter (DMM) reviews
32 posts / 0 new
HKJ
HKJ's picture
Last seen: 2 hours 2 min ago
HKJ
HKJ's picture
This list is directly from my website, i.e. any updates I make will be included here.
I am, of course, open for suggestion of meters to review, but at the current time I already have a rather long list. I hope to add one or two reviews each month, I might do it slight faster the next few months due to the many meters I have in queue.
I have two mouse overs in the above table, that hopefully makes it easier to compare the meters.
specialk
Last seen: 1 week 2 days ago
Thank you for your reviews. I have just purchased a UT-210E.
Pete7874
Pete7874's picture
Last seen: 5 min 41 sec ago
Thank you, HKJ!
How come the UNI-T UT61E is not listed in the table?
Also, I see the little Southwire DMM in your top photo… can’t wait to see your review on it. Smile
HKJ
HKJ's picture
Because it was not tested the same way. I did the 61 about 5 years ago and had planned on doing more DMM reviews, but I was not satisfied with the format.
I like my new format much better and I believe that with the mouse over popup this table is also very useful.
I have written the review of it and also for a couple more DMM’s, it is just a question about when I publish them and in what sequence.
somnambulism
Last seen: 10 months 1 week ago
I got an Amprobe AM-510 a while back, glad to see you give it a positive review.
Does your testing regimen include anything like this? Smile
HKJ
HKJ's picture
I like it, it might not be the most fancy meter around, but it has some very useful functions. I will probably test one Amprobe more (On of the more advanced models).
I sort of prefer my arb. generators, then I know exactly what is going on Smile
tempo
Last seen: 3 hours 14 min ago
Can you review Dave Jones new DMM? Has it been released
maukka
maukka's picture
Last seen: 1 hour 34 min ago
The 121GW is not available yet. The first 50 meters might come for sale soon, but they’re gonna go right away.
HKJ
HKJ's picture
I definitely want his new DMM, but it is not released yet. I will probably also do a review of it.
He has tried to get low burden voltage and has a 15 volt diode test, both are things I would like to have.
i42dk
i42dk's picture
Last seen: 3 weeks 1 day ago
Excellent work as always Thumbs Up
Alletiders Glasses
maukka
maukka's picture
One of the nice features is also the simultaneous measurement of voltage and current. The first batch of 40 121GWs were sold out pretty much instantly on Dave’s site, but there’s a Kickstarter soon.
HKJ
HKJ's picture
Measuring voltage and current is not the same as measuring watt. It can be used, but a real Watt measurement would have been better (And more expensive).
I was not in that batch, I will have to wait for the Kickstarter release.
maukka
maukka's picture
I pretty much only do DC so VA is fine.
HKJ
HKJ's picture
That was the first 10 multimeter reviews, more are coming.
I will try to publish a mix of cheap, mid range and a few expensive meters.
maukka
maukka's picture
The 121GW Kickstarter is on, but the first batch is already gone.
HKJ
HKJ's picture
And I was slightly late (About 100 orders) for first batch, but have ordered one.
HKJ
HKJ's picture
That was the first 20 multimeter reviews.
I have updated the list with a type/size column, click on header to on sort it.
Pete7874
Pete7874's picture
Thanks.
For Southwire 16040T, in the “A” column you have a partial compliance mark. Why did it not get a full mark?
Also, would you be able to provide a list of DMMs that you have that are currently awaiting to be reviewed?
HKJ
HKJ's picture
It is missing an A range, it only has the 10A range. The A range is very useful when you want to avoid the high burden voltage in the high mA range.
To get the full checkmarks is must have 6 current ranges from 10A and down without holes for both AC and DC.
No, for a couple of reasons:
1) I do not like announce about work I are planning to do (Plans may change), only about stuff I have done.
2) It might be a long time (Many months) before I publish a specific review.
With that said I can list a few where I have written the review, but not published it yet:
Keysight 34461A very expensive bench meter. This will probably be some time, I want to add a few feature checkmarks to my schema firsts.
Innova 3320, will probably be published soon.
Brymen BM235, same as the old EEV blog meter
Amprobe AM-570
Some Aneng and cheap DT-XXX meters
More meters with environment
Other.
I have a large pile of meters I have not written reviews for yet.
Pete7874
Pete7874's picture
Thank you!
HKJ
HKJ's picture
I added more indexes to the multimeter table, now it is possible to select from a specific price category or a index of all meters with full current measurements (i.e. from uA to A in AC and DC with no missing ranges).
I am open for other index criteria (It is fairly easy to implements).
Remember it is possible to sort the index on any column.
SubLGT
Last seen: 3 days 10 hours ago
HKJ, I often see in your DMM reviews the comment: “burden voltage is too high”. Please explain what “burden voltage” is, and what the consequences are when it is too high. Thanks.
HKJ
HKJ's picture
Burden voltage is how many volts you loose across the meter when measuring current. Some meters can have up to 2V, this means if you have a 6V supply feeding a circuit, the circuit would only get 4 volt when you add the ammeter. This basically makes the measurement useless.
It is always the high mA range that is most problematic, especially on 6000 count meters.
The way around it is to use the A range instead and accept the lower resolution.
HKJ
HKJ's picture
10 multimeters more in about two months, now I have 30 multimeters in the list and I have more in queue.
bogdanr
Last seen: 2 years 3 months ago
Awesome list! Thanks!
Pete7874
Pete7874's picture
Came across this not too expensive DMM with Bluetooth connectivity:
OWON B35T
Gearbest seems to be out of stock at the moment, but you can find them on AliExpress as well.
Looking through some youtube videos, the mobile phone app seems nicer and more useful than my Southwire one.
HKJ, I know you have plenty of DMMs waiting to be reviewed already, but if you ever need one more…. Smile
Skylight
Skylight's picture
Last seen: 17 hours 3 min ago
I need a clamp meter for measuring tailcap current. Is the UNI-T UT210D or the Mustool X1 better?
Which other brands are recommended for cheap but good clamp meters?
My Youtube channel: Alllightson Reviews
My 7th Old lumens contest build: Matainvoy ML18SBuilt video
My reviews: Sofirn SP31 V2.0Nightwatch NI40 StalkerSofirn C8F 21700Brinyte WT01 ApolloSofirn SD05
My Youtube video-reviews: Brinyte WT01 Apollo, Sofirn SD05
HKJ
HKJ's picture
A very common meter for this is the UT210E
Andrew_Debbie
Would you like to review the odd Aneng AN888s Bench DMM+BlueTooth speaker +Alaram Clock? It is on CNY sale at Bangood for $62.
HKJ
HKJ's picture
I have looked at it a couple of times and could not really decide if I wanted to review it.
