Reasonably priced LED yard light ('wow')..any others out there?
105 posts / 0 new
Freedom
Freedom's picture
Last seen: 1 year 3 weeks ago
I was looking for something in the 150 watt (max.) range to compliment a 175 watt standard metal halide used every night. This one would be plenty high (yet sheltered by a flying gable) and require the same expensive lift rental to install/maintain so the goal was obvious..never go up there again.
I priced matched an online company (MegaDepot?) with Amazon (delivery unacceptable) and ended up with this at 18,000 some odd (supposed) lumens supported by (supposed) brand name LEDs:
http://www.morrisproducts.com/pc_product_detail.asp?p_key=232196892B534F...
So far/so good.
The 4000K is a little hard to judge yet it is easy on the eyes in my opinion and ‘probably’ not the standard 5000k also offered. Coverage and beam pattern are pretty much off the charts at 28 some odd feet (looks left to a lesser elevation and right to a larger). The few adjustment holes provided are not as ‘micro adjustable’ as I would have liked yet this could be tackled with the proper time/skills (I overlooked this fact until the rental clock was running and I was bucket bound/30 feet in the air). Dislike also overlooked: the cord provided is not very long so I dealt with it and didn’t check the attachment point for a fix.
Conclusion? For under $200 shipped and after being quoted approx. $700 for 50% less lumens elsewhere..I’m in for the experiment. Much lesser lumen models were about the same price from this domestic importer and a 4000K wasn’t easy to find elsewhere without going brand name/big bucks.
Would love to hear from others who have found similar deals elsewhere on dimmable outdoor rated products at 100,000 lumens plus or minus.
Daylight savings time? I win. (it is literally ‘day’ everywhere that I need it to be) Wink
Domari Nolo “I Refuse to be Subjugated” (1st Pennsylvania Regiment Flag) https://www.1stcontinentalregiment.org/blank
(Flagguys.com):..and man o man did they ever refuse to be subjugated. These guys were everywhere. They were important in Washington’s siege of Boston. They stayed behind and were the last to leave after covering the main army’s dangerous nick of time retreat from Long Island. They crossed the Delaware with Washington. They were “..at Brandywine, Germantown, Monmouth, and every major skirmish, and battle all the way to Yorktown..” where they fought “the most important part of the siege” according to General Steuben. These guys saw action in every one of the original 13 colonies.
Edited by: Freedom on 11/18/2017 - 06:50
dchomak
You and I are alike.
I have always had an interest in lighting, waaaay before there was a BLF or such a thing as high power LED’s
Up until recently this is the brightest outdoor lighting mod I had done……more than 20 years ago.
In 1996 I bought this commercial building that housed a social club on the second floor. The social club had installed a number of exterior electrical boxes, each housing 2 ordinary E27 Halogen flood lights to light up the parking lot.
When I got the building I wanted more light, much more light. I got ahold of some high pressure sodium light fixtures that were used and came from a parking garage.
I installed them above the second story windows to get them further away for the ground. I installed a total of 7 of them, running at 250W each. That’s about all a 20A circuit can deliver. Each fixture puts out 16,000 lumen with new bulbs. They were already used when I installed them and after over 20 years of occasional use none have failed.
There are 5 of the fixtures along the top and 2 more on the back side of the building. After they are lit AND warm up the parking lot is, like yours, lit up like daylight. Except that Sodium lamps are quite warm in color.
In the lower right of the picture are 2 arrows, one Red and one Blue. They point to 2 light fixtures with regular LED bulbs, one RED and the other Green. They are connected to a bilge pump in the basement sump hole. In this picture the Red bulb is lit, proving there is power to the pump (piece of mind at a glance). The other fixture contains the Green LED bulb and is not lit because it only lights up when the bilge pump is actually running. Because I sometimes make work into fun I also connected a runtime meter to keep track of how many hours the bilge pump has run. In 21 years it has thankfully only run for a total of 2.6 hours.
Someday I will strip out the innards of the Sodium lights and install some LED’s
Freedom
Freedom's picture
Yep..birds of a feather. Wink We’ve both been blessed to have had the opportunity to buy decent quality (used or not) when that quality existed without breaking the bank. Now we’re amazed (at least I am) that we can buy an entire outdoor rated fixture of ??? quality for near the price of what they want for a single high lumen replacement bulb at (much) > than 100,000L/4000K/(and at least now)150W consumed.
I picked up a 130,000L/4000K mogul based Satco bulb that I never price shopped for that same project which was well over $100 https://www.satco.com/s9676.html
At the same time, I lucked in to knowing somebody who recently installed (12) of these in their church parking lot so we’ll see what they’re all about over time. They are dimensionally pretty big and I believe need 9-10 inches all around. I’m hoping to ceiling bounce mine as a single source light in a tall garage with open ceilings/rafters until I find a simple (used) mogul base that will work/reflect properly. My hope is to get it far enough up there so that it doesn’t blind me yet I’m not sure if that is possible. These 360 degree corncobs, even the $50 ones from Menards, are bright. It would be nice if others would chime in here to get a good grip on the replacement bulb market considering the physical size limitations for existing fixtures. My local Lowes and Home Depot want nothing to do with this market segment (apparently) so one wonders if they’re all junk (now) to begin with.
I’ve always been surprised that more don’t use lights/run time meters as you did with your pump for peace of mind. They’re used all around us for the same purpose and it’s not rocket science/cheap. Ditto with water sensors/kill switches/temperature alarms in our homes. Worse is the culture of refusing to install gauges of any sort in initial industrial/commercial installations or (heaven forbid) the simplest recordings of baseline data for troubleshooting purposes later.
Then again, why does your neighbor cloak his place in complete darkness believing that you’ll be able to watch out for him too..from a distance?
Freedom
Freedom's picture
…nobody out there bypassing high output (outdoor) ballasts and simply installing LEDs?
dchomak
Gutting 4- 8 foot HO florescent fixtures and replacing them with 32,000 lumens of LED’s each
128,000 lumen total, in the garage!
Here is another
I got a number of these brand new high quality commercial fixtures for $3 each. They had proprietary CFL sockets, the reason I got them so cheap. The idea is to strip out the ballasts and sockets and replace them with LED’s
Here are 4 E27 sockets installed with 4 – 1600 lumen LED bulbs installed for a total of 6400 lumen
BUT, I think these are a much better option.
That aluminum base plate is pretty thick.
They cost less than $2 each and have a self contained 110VAC driver. They come in 20, 30 and 50W versions
LOTS of lumens. 4 of those in that fixture should be about 16,000 lumen.
Freedom
Freedom's picture
dchomak,
I believe that you have just inspired many of us out here to look at our present fixtures ‘in a whole new light’ Wink Thank you for taking the time to share.
Quick question(s) please:
Is there much field experience out there with the last 110V driven LEDs shown?..
Can you pay more than $2 ea. to receive better quality LEDs from different manufacturers (or receive varying Kelvin ratings)?
…and are you referring to the thickness of the metal that they would somehow be attached to as the minimum heatsink needed for say a 50W module?
If I could somehow simply install ‘x’ number of those in an old fluorescent tube fixture by simply laying a long piece of metal/heatsink in there to attach them to (while still saving the reflector)…what’s not to like?
Lightbringer
Lightbringer's picture
Last seen: 1 min 15 sec ago
dchomak
Freedom wrote:
dchomak,
I think the thick aluminum would help conduct heat away from a 50W module into the rest of the base.
I just learned of those modules from this thread How to light a two car garage for under $30
DoubleA posted links to these in post #20 of that thread.
Big Clive posted some tear downs of these modules. Very interesting and informative. He seems to think that the quality is good, even though the price is very cheap.
Vegas LED Fan
Last seen: 3 weeks 5 days ago
You will not find any long term experience with the IC 110V COBs because they just became widely available in the last few months. I first spotted them in June on eBay while looking for small COB chips for a daytime DIY bike light project and bought my first one. The idea of being able to avoid using a 12V LED driver seemed like a real advance. It also reminded me how hot small high-powered COBs will get and that you need to mount them on metal. The biggest surprise was the low cost though I had already bought small 12V 10W COBs without the IC for a dollar each. Don’t worry about losing the reflector base on a fluorescent lamp retrofit because all of the light from the chip shines in about 120 degrees from the COB. A fluorescent lamp shines 360 degrees so much of the light shines toward the fixture. That’s exactly why my 7 bar light LED garage lighting system works so well. It’s much more efficient than using LED light bulbs because all of the light shines down from the ceiling.
I used a couple of the 7W 76 LED COBs that I bought from Banggood in my whole-house LED retrofit. They’ve been in use for about two years now without a single failure. I always mounted them on metal fixtures or metal plates if used without a fixture. They get warm but not hot and certainly never anywhere near as hot as an incandescent bulb.
Lightbringer
The only problem with 120V LED fixtures, COB or discrete, is the nasty nasty flicker. Most I’ve seen are just LEDs and distributed resistance so that the total RMS power doesn’t pop the LEDs, but there’s still lots of off-time that has the LEDs completely dark for a big chunk of the AC cycle. Think of LED Christmas-lights. Rather high peak power, but lots of dark-time. Like little stabbing spikes of light…
I’ve got a nightlight that’s got that hideous 120Hz flicker. I’ve never ever complained about a flashlight’s PWM, as most times I don’t even notice it, but this nightlight just grates on me.
If they have at least a bridge-rectifier and capacitor to smooth the current and thus light output, great, but cheap fixtures probably don’t have that. And caps will always be the weak link in any toasty circuit, so…
dchomak
Yes.
Big Clive did another video demonstrating that.
Freedom
Freedom's picture
I’d like to know whether taking the time to tackle these projects is worth the effort as well.
After receiving over 18,000+ (4000K) dimmable lumens for under $200 shipped (twice; first to the mainland distributor) in an outdoor rated fixture; it just doesn’t seem possible that you cannot receive a reasonable amount of directed or undirected light at a reasonable tint in umpteen different lesser powered models.
I’ve got two oversized 5000K/4000K corncob lights now just sitting in their boxes which will probably be used for emergency lighting of some sort due to the hassle of finding something that they will fit in to properly reflect them. I would switch everything over to these comparably low wattage dimmable outdoor rated flood type lights yet I’m still baffled as to why so few seem to be using them…(so far/so good for me).
Freedom
Freedom's picture
http://www.morrisproducts.com/pc_product_detail.asp?p_key=F52A8A1CBA914F...
$146 shipped (Amazon)
10,033 lumens/80 watts/4000K
What is a heavy duty HPS/MH(etc.) yard light running these days and how much have we been/are we paying for a 10,000+ lumen flashlight?
Two 10,000+ models located (high) next to the front/back of a house (on a switch based over-ridable type motion) and (hopefully) never touch them again.
“It’s like night and day” pretty much describes the 18,000 lumen version in terms of experiencing your property at pitch dark versus previously (yard light or not; sorry don’t do pics).
dchomak
Last summer on our anniversary we went to Niagara Falls.
While my wife was shooting pictures of the Falls, I was doing what any normal flashaholic would do.
Checking out the lighting system. Innocent
As you can see we are quite a ways up on this observation deck. That’s water and trees straight down below. This is a picture of the only flood light on that side of the deck.
I knew when I shot this picture that I could blow up the information stamped on the fixture and check it out later.
It’s an “ECOMOD 450”, a 450W LED flood light.
It’s “only” 40,000 lumen. I say that because my brother and I put 128,000 lumen in his garage. LOL
Here is a short video on that ECOMOD 450
dchomak
Today I received a couple of those modules.
First off, they are a big disappointment. They are not very bright and they consume a LOT of power.
My estimation is that they are about as bright as a 7W LED bulb (about 800 lumen) but consume probably in excess of 30W.
The ones I ordered should have been rated at 50W with 4 driver chips on the right. I got 2
Here is one held up against a 15W, 1600 lumen “dedomed” LED light bulb.
This photo was taken during the middle of the day, hard to tell how much light is output. For this shot I placed identical domes over each light, and also took a shot of the ceiling over both lights running at the same time.
Freedom
Freedom's picture
Thanks a bunch for the update on those lights and for the pics (the 450 watt LED pics as well).
I guess that I’m back to scrounging for flea market/garage sale priced antique light fixtures/shielding in both standard and mogul bases for (indoor rated) corncobs… Sad
$150 for 10,000+ and $200 for 18,000+ (lower Kelvin) lumens sporting an outdoor rating (to boot) might be far less of a headache at this time.
SubSailorVet
SubSailorVet's picture
If you’re gonna do it, do it right. I got these from eBay. Good price, lots of light, super easy to install. My backyard is about 180’ × 100’ and these light it up like daytime. Check it out. Good luck.
Led floodlight
Best regards,
Matthew
blueb8llz
Last seen: 2 hours 57 min ago
Led floodlight
Thanks, I may try one of these someday. Too bad they don’t come in warm white tint. Or do they?
dchomak
It’s dark outside now so I did a further test to show just how bad these modules are. It’s too bad, I had high hopes for them and as bad as they are, they are much better than the ones I ordered previously about a year ago.
On the left is a 1600 lumen, 15W LED light bulb. To the right is a module with an identical dome covering it I cut off another bulb.
It’s pretty apparent from this picture that the bulb on the left is much brighter than the module on the right
Next I held a box up halfway between the 2 lights. I adjusted the height so that the shadows are directly over each light.
At first this may be counter intuitive, but the lighter shadow on the left is over the brighter of the 2 lights, the 1600W LED bulb. It is important to realize that that shadow is cast by the module. The shadow on the right is cast by the bulb.
The darkness of the 2 shadows show the relative brightness of each light And from this picture it is obvious the bulb beats the module by a large margin!
Next I measured the wattage of each light. Believe it or not, the brighter of the 2 used half the watts! Further proof these modules SUCK.
LED bulb on left, module on right.
Asbestos
Asbestos's picture
Last seen: 4 weeks 1 day ago
https://www.amazon.com/Richday-Outdoor-Lighting-Waterproof-Security/dp/B01KHFC7H6/ref=sr_1_fkmr0_1?ie=UTF8&qid=1512182116&sr=8-1-fkmr0&keywords=richday+led+flood+light
I got a pair of these a few weeks ago. At first I was a little disappointed in the output. It did not seem 9 times as bright as the 11w "100 watt equivalent" indoor bulbs I had. I have not tested either but these are quite a bit brighter. I got the warm white ones 2700K and it seems to be spot on it is quite a warm white, whereas the bulbs were bright white, which I find kind of obnoxious. But I reevaluated it after I got it hooked up to a proper cord and could move it around. It has two LED chips and the drivers are in the lower box. LEDs are stuck with gunk right onto the back of the case. The really nice thing is there is no flicker, between that and the nice color it is quite a civilized light.
I point to others in this group to justify how many flashlights I have.
Freedom
Freedom's picture
…is that ‘about’ where LED bulb technology is at right now when considering a reasonable price range for multiple bulbs in a retrofitted fixture ..1600 lumens/15 watts/5000K or so?
I ask due to a person armed with some fixture and/or socket pricing possibly being able to glean some kind of initial project direction from what has been offered up here to date.
(Obvious warning: Bypass the ballast when using many of these bulbs on certain applications)
Freedom
Freedom's picture
https://d114hh0cykhyb0.cloudfront.net/images/uploads/warehouse-corn-ligh...
This is the basic type of indoor fixture (or even more enclosed) that I’ve been looking at for these corncob bulb options.
The problem seems to be that any 10,000 lumen+ (usually 175 watt max. rated) converted LED fixture needs to be near ‘free’ or these bulbs don’t make sense (price-wise) even with a decent Kelvin rating.
Freedom
Freedom's picture
….18,000+ lumen Chinese origin light in post #1 still going strong in near zero temps. and sub zero wind chills (price went up at least $10 or so on Amazon). Still looking for a better value out there down to 10,000 lumens(+) at 4000 Kelvin or less.
An outdoor rated light capable of illuminating half a football field (or more) shipped halfway around the world then (re)shipped/handled yet again from right here in the U.S. for less than $200…how does one compete with that?
Freedom
Freedom's picture
“…Still looking for a better value down to 10,000 lumens(+) at 4000 Kelvin or less….”
$165 for 10,000L @ 4000K (outdoor rated/adjustable/dimmable):
https://www.amazon.com/Morris-71831-Panel-Trunnion-Bronze/dp/B0758286XD/...
Nothing else?
Freedom
Freedom's picture
Thought that I’d check back in after a few months of nightly use in fairly cold temps.
Still…‘wow’.
I saw a house out in the country today with a std. yard light mounted up on an old tower where a windmill used to be located.
Mine is tucked way back under a flying gable maybe 4 feet.
I can’t imagine it uninhibited by shielding or simply glaring down from on top of a high pole.
Wish that someone else used these to confirm that this light’s current performance isn’t indeed a fluke…
Freedom
Freedom's picture
https://www.amazon.com/gp/product/B01CF3IT52/ref=ox_sc_act_title_1?smid=...
2900 lumens; 3000K for $73 shipped (or less?)…who else is offering these?
I’m still holding back on their 4000K/100watt/12000+ lumen version as I (still) can’t believe that they’re the only ones out there dominating the lower Kelvin scale market…
dchomak
For the past 13 years I have been nursing this old lamp post fixture along. Although not a yard light, I had it rigged up to throw a lot of lumens. Originally it contained a single E27 socketed bulb. I at first upgraded that to 4. Here it is some years ago with 4 – 800 lumen LED bulbs. Over the years it developed “body rot” and I kept trying to shore it up and keep it from leaking. I really love this fixture, but I just couldn’t keep it going. It needs a complete rebuild. A friend has offered to help by first sand blasting it, much of it is painted copper.
Here it is with 4 bulbs, then lately with 5.
A couple of years ago I found a commercial fixture at a ReStore for only $10, probably a $300 fixture originally
It was meant to run a 275 low pressure Sodium bulb. I stripped out the socket and ballast to make room for the 5 socket E27 setup I had installed in the old fixture above.
I didn’t get any in between pictures during the conversion but here is a picture of the installed light. This time I used 5 – 1600 lumen FEIT 100W equivalents at 3000K for a total of 8000 lumen. I tell myself this fixture is just a temporary fix until I can get the original rebuilt. We’ll see…………..
(Don’t worry about the neighbors, we are set well back off the road. Silly
Lightbringer
Good God… that thing could attract Mothra! Big Smile
Freedom
Freedom's picture
Trunion mount version still working. Looking to install another unit (pole mount) on the rear of the house in conjunction with a HD antenna (I’m looking for a 26’ – 30’ pole of 4×6” lumber or laminated which I can’t seem to easily find). This quote came from MegaDepot today:
Morris Products, 71853 FlatPanel Series Pole Mount Lamp, 150W, 18,486 Lumens, 4000K Bronze
Net Ex-Works: $192.60
Shipping / UPS Ground: $17.92
Shipping Adjustment Discount*: -$17.92
Total FOB : $192.60
My next pipe dream is an easily adjustable shade or ‘tack on’ pieces which would block some of the 180 degree you-have-to-see-it-to-believe-it lumens from certain vantage points.
I wish that I had this light a long time ago yet I obviously couldn’t have afforded to buy one or operate it in the first place.
Freedom
Freedom's picture
…btw, dchomak…love that original light fixture. I can see why you babied it along as you’ll probably never find another (its replacement is sharp as well). It’s no wonder that they get so much for the old fixtures nowadays.
dchomak
I just noticed our neighbor has a smaller version of that same styled light.
I asked him where he got it and he told me found two of them in the basement when he bought the house!
He rebuilt his back then and it’s been find ever since. I noticed he had a “filament” LED in his, looks real nice.
I know all of this is sort of off topic, but at least it is a bump for the thread Wink
Our replacement fixture is definitely commercial and it is wonderfully made. All pieces are cast aluminum and the top is even hinged for easy access.
Here is a peak inside looking down on 5 – 1600 lumen bulbs
The old fixture at our front door bit the dust too. Solid brass, someday I will strip it of paint and polish it up. The socket went bad along with the wiring. To the right, the old post light.
Awhile back I caught an awesome deal at Lowes for a light fixture of the same style as our original post light and I grabbed them all. I used 1 to replace our old front door fixture. I think they went on clearance because they took candelabra style bulbs and nobody wanted them. I know I didn’t back then. My intention was to convert them over to E27 sockets.
That all changed when the new “filament” style LED bulbs came out and I was able to get some at Costco in candelabra style. Here is a cheap Lowes fixture with 2 LED’s at our front door. Same style as the post light. I was even able to get a matching style light for the alcove. It can be seen hiding in the corner of the picture.
Anybody that knows me, also knows that I have the tendency to over buy when I come across a deal. Out in the garage I have a stack of 3 more of those fixtures. The arrow on the right pointsto the price I paid, $5, no wonder I bought all 4 they had.
