The Sofirn C8A is one of Sofirn's new C8 18650 flashlights (which include the C8T and triple-emitter C8F). The C8A is a single 18650 "C8 style" flashlight which utilizes a domed Cree XP-L2 in a polished reflector with a throwy beam. Output is speced at a max of 1747 lumens (I measured ~2000 lumens @ 30 sec.) The C8A comes from the factory with a very pleasant warm-neutral tint of ~4800K.
I had the opportunity to evaluate the Sofirn C8A and was provided a copy for review by Sofirn (sent direct from manufacturer).
Made by 6063 aluminum alloy, CNC machines, Premium type Ⅲ hard-anodized anti-abrasive finish to get solid built body, anti-crash and better heat exchange
Toughened glass lens with AR coating, anti-crash and wearable
The water-resistant level is IPX-8, it can be used in underwater 2 meters for 30 minutes. And it is used in rainstorm.
Mode Memory: Yes. The current mode can be memorized if the flashlight turns on more than 2 seconds. Turn it on next time, it is the original mode memorized.
Low voltage protection: Yes. The light is automatically turns off when the voltage is lower than 2.8 volts. The signal is that the light slowly flashes for 1 minutes
Reverse polarity protection, to protect from improper battery installation. The light is off if battery install improper.
Battery: It powered by one 3.7V 18650 battery ( not included,suggest unprotected battery)
Packaging and Contents
Box, C8A, Manual and Lanyard. No O-rings with my copy.
Fit and Finish
The C8A has smooth black anodizing that appears somewhat matte. The anodizing was applied well and my copy did not have any notable defects in the finish. The design uses the standard C8 base style and adds some Sofirn styled touches like the ridges in the body.
The threads are extremely nice (best I have seen from Sofirn yet) and they mate with Convoy. Very smooth and the entry thread is nicely tapered. I did not add any lube. The rear thread is anodized.
Springs are bypassed from the factory!!!
Factory bypassed!
Output, Runtime and Power
Measurements were done using a freshly charged protected Panasonic NCR18650GA hot off the charger.
I estimate High is practically 2,000 lumens at 30 seconds. Peak at activation was about 2100+ lumens.
"Moon" mode was about half a lumen.
Beam Profile
Throwy. The C8A uses a domed Cree XP-L2 in a polished reflector.
Beamshots, Color Temperature and Tint
The Sofirn C8A is a very nice warm neutral white. I measured mine at ~4900K although the official specs listed it as closer to daylight 5500K. The light appears slightly warm white in practice. There is some temperature variance throughout the beam with the hotspot being the warmest point. This is a very good choice of default color temperature.
Battery Support and Fitment
The C8A is powered by 1x18650 lithium-ion (INR, IMR, ICR, etc.)
Protected Batteries Fit. The Protected Panasonic NCR18650GA fits fine length-wise and width-wise. The dual-spring design is very tolerant of a range of battery lengths.
Button vs Flat-Top: Flat-top batteries should also fit due to the dual battery springs although I did not test this.
The positive & negative contacts are both springs.
Lock-Out
You can physically lock-out the light by loosening the tail one-half turn to break the circuit.
If there is a possibility of accidental activation, you should lock-out the light.
Size Reference
Flashlight pictured next to another C8, 18650 and Q8 for reference.
Summary and Conclusion
This is a very nice "Hot Rod C8" that comes with the springs bypassed from the factory. Putting out 2,000 lumens stock, I could not ask for more from a C8. This light performs very well although at full power it can start to get warm quickly. This light also provides a very nice Moon mode which can be avoided by switching between Mode Sets. The only down-side is that the Mode Set which includes Moon also includes strobe. Fortunately for me, I rarely have a need for a Moon setting in a C8. However, it would be nice if there were 3 mode sets - 1) Normal (Low / Med / High) 2) Normal + Moon 3) Normal + Strobe
The beam profile is throwy as can be expected with a C8 although since the C8A has a domed emitter, it is not overly throwy (this is good IMO).
Interested too. Hope there are no “design” problems like the triple emitter version. I guess some people would like to know if there’s visible PWM or not?
Driver have two FET chips, one for lower current,and second bigger for direct drive.
Awesome light and it does have 3 mode option just do a 3 fast half clicks while its on and the light will blink 2 times and switch between mode groups.
19Mm copper DTP board transfer heat gorgeously and it will get very hot in just a minute, luckily there is a step down after 3 minutes. Also no pwm at any mode…
I have a C8T xpl-hi version, and after some tweaks I did yesterday it makes 1400 lumens, and 85Kcd for nearly 600 meters of throw !!
Thanks for the review, SoCal. I really like what I’ve been seeing from Sofirn. They sent me a SF36 to review (here) and I thought it was a nice light. I ordered their C8 host from their Aliexpress store about a month back, should be coming in soon. I like my Convoy C8’s, but I see a couple advantages with what I’m expecting from Sofirn’s C8:
Anodizing - sometimes I feel like Convoy’s matte is just too matte. Sofirn’s seems very nice.
AR lens - some, but not all Convoys come with AR. I like that it’s included with Sofirn’s.
Body tube - nice, something a little different than the standard gnurling
Tailcap - I like that the cap is formed into the saddle shape. I find it a bit easier to press, and it shows off a lit tailcap more when viewed from the side.
I can’t wait for my host to come in and start playing with it!
I am new here and this is my first post. Please be patient with me!
I have made following observation on the C8A:
If you power the 1700 lumens rated Sofirn C8A with the mystery cell provided by Sofirn it is a little bit dominated by a 900 lumens rated Thorfire C8S powered by a LG high drain cell. If you put the LG high drain cell into the Sofirn C8A and the Sofirn cell into the Thorfire C8S the Thorfire gets 100% destroyed by the Sofirn.
Also with the Sofirn cell the Sofirn C8A only gets lukewarm after 3min while with the LG high drain cell it can almost burn your hand after 3min. The multimeter shows that the C8A pulls more amps from a LG high train cell which translates into much more lumens and heat. With the LG cell the Sofirn C8A delivers more than 1750 lumens considering the warmer light color.
Thanks! So I am not crazy and the “Sofirn mystery cell” indeed limits the C8A. The Panasonic NCR18650GA must be a beast of a protected cell if it still manages to get the maximum out of the Sofirn C8A!
Interesting that you find Sofirn battery less powerful than LG HG2, since many here reported that under the wrap is Samsung 30Q.
Maybe they offering standard cell with C8A, and High drain only with C8F since it have triple emitter…
Btw my C8T XP-l hi after all wires changed to 20awg now pushing 1550 lumens after 30 sec and over 1600 at start !
Amazing performance with close to 100Kcd
