Q8 3rd batch or the same as 2nd?
45 posts / 0 new
leftfordead
Has anyone received a q8 from the latest batch yet? Just wondered if there were any new improvements or differences from the 2nd batch,Or is it’s the same as the batch 2 q8.? Thanks
Edited by: leftfordead on 12/03/2017 - 05:51
Andrew_Debbie
Last seen: 45 sec ago
Mine is on the way. I’m not sure how much longer I will have to wait.
2017-12-02 12:00:00 Arrived In Hongkong, Waiting To Fly Away.
2017-12-01 21:30:00 Leaving The Shenzhen Operations Center.
2017-12-01 13:29:30 Shenzhen Operations Center Processing Package Information.
patmurris
patmurris's picture
Last seen: 3 days 13 hours ago
I’m not sure what the ‘third batch’ would be… AFAIU there has been a first batch of 500 with a few issues that where corrected for the second batch beyond the first 500. The first two i got where from that second batch and i latter ordered a third one which was probably close to #2000 in the ‘preorder’ count on BG. I received it a couple weeks ago and it was exactly as the first two. Don’t know if that answers your question though.
KawiBoy1428
KawiBoy1428's picture
Last seen: 4 hours 34 min ago
What was to be improved? I have a second batch Q8 and there are no problems with it. I just received another (my second) Q8 this Friday and it’s about as perfect as you can get too and so far no issues.
My first Q8 had a AR lens, the new one a Clear lens, only thing I see different?
KB1428 “Live Life WOT”
kiriba-ru
kiriba-ru's picture
Last seen: 36 min 27 sec ago
I think all Q8 should have clear lenses…
Need a vlogger for machine accessories reviews
leftfordead
my shipping status is the same as yours
leftfordead
ive never owned one so no idea what could be improved,i read peoplke change the screws over alot to brass
patmurris
patmurris's picture
Springs!
A bypass yields 1000 more lumens!
Not mentioning the light can turn off when bumped on the tail…
The springs used in the D4 would have been great.
leftfordead
its probly more orders of the second batch then, all i know is i got a email friday saying they have shipped my q8 as it was on back order
leftfordead
patmurris wrote:
Springs!
have u done the spring bypass? i was thinking to do it but im a newb with little experience
djozz
djozz's picture
Last seen: 1 hour 6 min ago
patmurris wrote:
Springs!
When it was clear during developement of the Q8 that the goal of 4000 lumen would easily be met even with steel springs without bypass, I pleaded not to aim for better conductive springs (like copper alloy ones) or for a factory-bypass, to keep the safety feature that a steel spring forms when inserting the battery the wrong way. I’m still strongly in favor to keep it that way.
We did put a lot of effort in getting Thorfire to use longer stiffer springs, resulting in that they used a somewhat better spring than was used in the latest prototype, but we never got the exact spring we wanted
The springs in the D4 (Be-Cu alloy) are of low mechanical quality and have very little travel, that is why the D4 can only accomodate a very specific battery length (the standard size that unprotected cells have). It is unsuitable for the Q8 that has the dimensions to accomodate a variety of battery sizes. Only if the battery tube is shortened these springs will work, but anything longer than a standard unprotected 18650 will not fit.
link to djozz tests
“I used to think that top environmental problems were biodiversity loss, ecosystem collapse and climate change. I thought that thirty years of good science could address these problems. I was wrong. The top environmental problems are selfishness, greed and apathy, and to deal with these we need a cultural and spiritual transformation. And we scientists don’t know how to do that.”   (Gus Speth)
leftfordead
djozz wrote:
patmurris wrote:
Springs!
so for someone like me , the best torch i had is a 2 aa battery led torch, so as standard it would be more than bright enough
patmurris
patmurris's picture
leftfordead wrote:
djozz wrote:
patmurris wrote:
Springs!
@djozz: Thanks for the explanations, it all makes sense. Someone recently posted a pict of he’s Q8 tail board after he inserted one cell the wrong way and this ‘safety feature’ did work.
@leftfordead: Would the Q8 be more than bright compared to a 2xAA…? Be prepared to be flown away! Lol Evil
Flashy Mike
Flashy Mike's picture
Last seen: 6 min 33 sec ago
The D4 has two springs, the Q8 only one per cell. 2 springs are always better to prevent power interrupts caused by bumps. Easiest and cheapest improvement would still be an additional buffer cap.
joechina
Last seen: 1 hour 3 min ago
Thorfire planded to release Q8 with NarsilM v1.2 (but nobody knows when this will happen)
And they said they will use uncoated lens only.
So I suggested to name this lamps batch 3.
Maybe the december 2017 lamps are batch 3?
Infos whats new in NarsilM under http://bit.ly/narsilthread
An updated cheatsheet is under http://bit.ly/narsil-cs
leftfordead
patmurris wrote:
leftfordead wrote:
djozz wrote:
patmurris wrote:
Springs!
so i think ill leave the springs alone then , my current torch is running 1 aa battery and 1 small led ,so i think the q8 will be a slight upgrade, so how do the steel springs help with saftey?
leftfordead
i noticed on a few vidoes that some of the q8s were not branded ;blfq8: was that with the early ones?
patmurris
patmurris's picture
Springs act as fuse – more or less. Under high current and heat they sort of retract and the cell lose contact. They have to be replaced though.
Early prototypes had no branding.
patmurris
patmurris's picture
Do you have those lights?
My D4 has one spring and the Q8 two for each cell.
I agree an extra capacity is the best cure for short power interruptions… Still a bit tricky when you’re not used to solder those tiny components. Don’t ask how i know. Facepalm
xCentrino
xCentrino's picture
patmurris wrote:
Do you have those lights? My D4 has one spring and the Q8 two for each cell. I agree an extra capacity is the best cure for short power interruptions… Still a bit tricky when you’re not used to solder those tiny components. Don’t ask how i know. Facepalm
Do you have these light?
The D4 Has a spring on both end of the battery.
patmurris
patmurris's picture
OK i get it. I was only counting the one at the tail.
The Q8 has two springs nonetheless… but on the same side.
klrman
klrman's picture
Last seen: 10 hours 48 min ago
I ordered my Q8 from Banggood a few days ago and they had two shipping options, either to ship from China or from US warehouse so I chose US warehouse as the China one was sold out.  The US one was $20 cheaper so does that mean I am going to get an inferior Q8 and not the latest version?  Just read about if you bump the Q8 it turns off because of the weaker springs on earlier versions.
djozz
djozz's picture
‘Inferior’ is extremely relative here, even the lights from the first batch were top-performers, it was just that some (less than 10% if I remember well) had issues with switch-leds not working well (mine were fine), and only if you are into modding it makes sense to replace the low quality screws that were used for attaching the taiulboard and driver board.
But I doubt that any first batch Q8 is still for sale, from the second batch on the screws are better and there’s no switch-led problems reported.
It can be expected though that a certain moment a batch of Q8’s appears that is built cheaper, with cheaper components, it was always that way in chinese budget lights. But they have not been found as yet.
link to djozz tests
klrman
klrman's picture
I would say "inferior" was the wrong choice of words!  Would there be any tell tale signs that I got a Q8 from batch number 3 or  would batch 3 be the same as batch 2?
djozz
djozz's picture
klrman wrote:
I would say “inferior” was the wrong choice of words!  Would there be any tell tale signs that I got a Q8 from batch number 3 or  would batch 3 be the same as batch 2?
Well, if there is any place where you would find the answer on that it would be this very thread, with just 24 posts it is doable. You would find that there was no complaining about batch 2 and so any alteration for a ‘batch 3’ would be Thorfire’s initiative, not from the Q8 team, and there’s no report from anyone yet finding differences. All I can find on alterations is that the Q8 may get new firmware at some point. Not that NarsilM 1.2 will be noticably different though..
From this thread:
link to djozz tests
klrman
klrman's picture
djozz wrote:
Well, if there is any place where you would find the answer on that it would be this very thread, with just 24 posts it is doable. You would find that there was no complaining about batch 2 and so any alteration for a 'batch 3' would be Thorfire's initiative, not from the Q8 team, and there's no report from anyone yet finding differences. All I can find on alterations is that the Q8 may get new firmware at some point. Not that NarsilM 1.2 will be noticably different though..
Thanks.  Obviously nothing to be worried about then even if I get Batch #1 as I don't mod my flashlights.
RobertB
RobertB's picture
Last seen: 2 hours 22 min ago
Both of mine from the 1st sell are excellent.
Newlumen
Newlumen's picture
Last seen: 32 min 20 sec ago
Hey robert, can you find out if my blf q8 is from 1st batch?? I ordered it on september, 7 and got the light on october, 16.., thanks
patmurris
patmurris's picture
If i remember well a lot of people ordered their Q8(s) on that day. Maybe a thousand orders went through i believe. What made the difference between batch #1 and #2 was the ‘order count’ on the Banggood Q8 page. Mine was #674 and i got a batch 2 (over 500).
That said, the main symptoms of a batch 1 Q8 where:
- uneven switch leds – that went faulty for some lights
- damaged screw heads all over the place (driver, tail pcb, reflector…)
- driver retaining screws too large for the driver holes, that would thread into both the driver and the head shelf
The last point was sometime having the driver not completely sit flat against the shelf and making less then optimal contact with the battery tube (carrying the negative part of the electric flow) resulting in slightly reduced performance.
After a ‘pause’ in production, all those issues (and possibly others i don’t remember) have been addressed and implemented in batch #2.
I’ve never heard of a batch 3 Q8.
RobertB
RobertB's picture
Mine came in perfect, no problems at all and was within the first 50 shipped. So did the majority.
Keisari
Last seen: 6 months 1 day ago
The switch leds were not just uneven, but would fail within an hour or two. Initially the actual cause seemed mysterious and a myth about operating LEDs below data sheet currents became widespread. It seems the actual cause were bad solder joints. Majority never reported, but it can’t be “rare” and unlikely to be minority.
Screw heads were ruined all over, true.
Driver screws were forcibly screwed into aluminum. When replacing, new screws of the larger type will probably do just fine.
Tilted driver is present on batch 2. Otherwise, my batch 2 example was flawless as far as BLF GB standards go. Threads were more dirty and squaky than with b#1, but that’s to be expected. Switch led works after quite a bit of use and had the correct screws all over, none damaged.
Will be available eventually. Could be from a totally different source, and it’s the same thing that went on with the SRK clones. Someone is going to decide some features are unnecessary and the light “works” without them.
