The NEW Sofirn C8F Triple XP-L W2 w/side e-switch
287 posts / 0 new
DB Custom
DB Custom's picture
Last seen: 1 hour 50 min ago
Hey everybody, Dale here with another (yes I know) look at the new Sofirn C8F Triple. Tracy at Sofirn contacted me about this new revision and I bought the light at a discount on Amazon HERE
They are offering a 25% Discount to BLF users with the coupon code N6LKSTK9. With the battery charger and a really good cell, this comes out to around $34. A pretty nice deal I think.
They have upgraded the C8F to use a side e-switch and have several groups in the driver firmware that are easily selected by the end user.
Specification:
√CCT Range:5350K-5700K, Neutral White(NW)
√Four light Groups:
Group1:Low2(85LM)>Medium(650LM)>High2(1330LM)
Group2:Low1(37LM)>Low2(150LM)>Medium(790LM)>High2(1330LM)
Group3:Low1(22LM)>Low2(80LM)>Medium(630lm)>High1(990LM)>High2(1540LM)
Group4(Muggle/Kids Group)Low1(20LM)>Low2(70LM)>Medium(150LM)
Turbo:2580 Lumen.(2800mah unprotected 18650 battery used in test) In any mode (except lock-out and Kids group), Double-click to go to Turbo
√Light Cup: smooth reflector
√Thermoelectric separated MCPCB
√Reverse polarity protection, to protect from improper battery installation. The light is off if battery install improper.
The original groups is group 1 and it always cycle from Low to High
1. Memory Function: from OFF, hold 0.5 seconds to go to the previous used mode
2. In any mode, hold 1 second to go to Moonlight/ML
Mode Set Operation
1, From ON, 4-click to go to another Light Group.
2, Group 4 /Kids Group: In any mode (except lock-out), hold&press 10 seconds to go to Kids Group
3, To Lock-Out the light, from OFF, 4 fast clicks
4, Battery level Indicator: From on, 3 fast clicks to go to Battery level indicator
5, Low Battery Indicator
Package:
C8F Lampe; 18650 battery; USB charger; 2 of O-rings; lanyard; Manual
They also took heed and made changes to the emitter selection and MCPCB, we now have XP-L emitters that I believe are W2 and in the 3A or 3B tint range. Tint is just slightly cooler than a 3D, power level is very capable and well received by yours truly! Big Smile
Now, Barkuti has a nice review with a lot of good pics and run times and all that, so I don’t aim to bore ya to death with another albeit less qualified review like his. He might not have had the triple, or the new side switch version. So I’ll show ya some pics and then we’ll go inside and see what makes it tick! Smile (and then what makes it tick FASTER!)
They’ve made a very nice triple reflector, used a Direct Thermal Path MCPCB (confirmed) and have what I believe to be the W2 power level of the XP-L. I say this because the emitter has a small flat on the side, not the usual large full coverage flat that won’t fit under a Carclo optic. I’ve only seen these once before and I found them to do over 2000 lumens in a full direct drive light.
Look at the emitters on the board and see the one I’m holding to the right, a normal XP-L V6 emitter…
They even supplied a charger and a cell, this time an unprotected cell (I know, the label says it’s protected but testing and questions to Tracy proved out they made an error with the printing on this label) I unwrapped it and it appears to be a Samsung 30Q, but it does better than the 30Q’s I have. Bested only by Sony in the form of the VTC4 and VTC5A in my tests.
This might also be a good time to point out that Sofirn has already done the spring bypasses for us! Yes, 22ga wire bypasses already installed at the factory! Nice touch!
Tests? Yep, I tested the light with their cell and with a couple of others to see where they all stood…
……………Sofirn …………………………..30Q………………………..Sony VTC4
1. 0.552 Lumens…………………0.552 Lumens………………0.587 Lumens
2. 37.50 Lumens…………………22.29 Lumens………………22.81 Lumens
3. 83.15 Lumens…………………..82.8 Lumens………………84.53 Lumens
4. 890 Lumens………………….872.85 Lumens………………931.5 Lumens
5. 1338.6 Lumens……………1314.45 Lumens…………….1400.7 Lumens
6. 3015.3 Lumens……………3018.75 Lumens…………….3125.7 Lumens
…..2756.66 at 30 sec…………….2691 at 30 sec
So as you can see, their driver is really working quite well! It appears to be an FET+1 design of their own, albeit with a bit more sane FET than I typically use.
They assemble this triple reflector light in the usual manner, even though it’s smaller than what we normally see done this way. This is to say, they use a screw from the middle to pull the reflector down onto the MCPCB through the emitter shelf, but they ALSO use one screw to hold the MCPCB to the reflector so it can’t twist and kill emitters. They put a recess in the emitter shelf for this screw to seat down into. Clever!
You see the two wire holes at the bottom with the recess at the top and the anchor screw in the middle…
This is all isolated with white plastic centering/isolation rings. Nicely thought out and well executed in the first C8 Triple with a metal triple cup reflector. The reflector is also well done. Wink
Threads on the battery tube are non-anodized at the head, anodized at the tail. Heavy V shaped threads are cut flat at the point to be a good compromise between the normal fine V thread and a narrow square thread, I find these to be robust and well done.
The e-switch falls readily to thumb, well placed here as well with an interruption for the switch in the finned section of the head.
Even the laser etching is well done, a place many cheaper lights suffer noticeably…
I especially enjoyed their attention to detail when it came to the reflector itself. Look at the deep pockets cut into the bottom of the reflector to clear the wires…
I had to test those out, of course, to see if larger wires fit. 18ga SuperWorm did indeed fit and clear. Big Smile
With nice threaded retaining rings and a relatively deep driver bay, the head of the light is again well done and easily accepts modification.
Something I did, indeed, embrace. Smile
So, I applaud Sofirn with the improved and upgraded C8F triple, very nicely done and a welcome addition to the C8 style lights we know and love! Well done Sofirn!
I will elaborate a bit more on the moddability here directly…..
Thanks for checking it out, you sure can’t go wrong here, they outdid themselves with this one!
Edited by: DB Custom on 12/11/2017 - 16:13
DB Custom
DB Custom's picture
Ok, so since I was inside the light, and already sitting at my bench, what was I to do? Had to find out if 18 ga wires would fit, right? Well of course I did! And while I had the driver clamped in stats and held firmly in my vice, what better time to use my hot air station to remove their MOSFET and put mine on? Big Smile So I used a Vishay SIR404DP, left everything else on the driver alone. (with 18ga leads of course)
It went together a bit more like a complex dance than before, having the larger wires and needing to screw the MCPCB to the reflector and still get the middle screw through the emitter shelf, but it was worth the effort!
I looked at output’s now, current only without taking lumens measurements.
…..Sofirn……LG HE-2…..Samsung 30Q…….Efest 3000mAh
1. 0.005A…………….0.005A……………..0.005A………………….0.005A
2. 0.06A………………..0.05A……………….0.04A……………………0.05A
3. 0.19A………………..0.18A……………….0.17A……………………0.18A
4. 2.99A………………..2.79A……………….2.92A……………………2.80A
5. 4.62A………………..4.08A……………….4.41A……………………4.41A
6. 7.25A………………..6.47A……………….7.03A……………………6.86A
7. 11.12A…………….10.26A……………..10.56A………………….10.03A
So I charged up a Sony VTC5A and got 13.57A on Turbo, with a lumens output of 4036.5 at start, 3629.4 at 30 seconds.
This afternoon I got some UCL glass AR coated lenses from flashlightlens.com, put one in and charged up another VTC5A to see what changed… I’m now seeing 4288.35 lumens at start on the VTC5A, 3519 at start on the included Sofirn cell!
As you can see, simply by swapping out the FET and using larger wires, dropping in a nice AR coated lens, this little beauty is capable of 4000 out the front lumens! Just gotta love that!
DB Custom
DB Custom's picture
I am told that these cells will also be sold on their site after the first of the year. Wink
The pink color of the wrapper inside the Sofirn labeling matched my Samsung 30Q perfectly, but the 3 legged top plate looked different. There is a button top spot welded on, but it’s still easy to see there is a difference in the top plate. There is no laser marked branding on the pink wrapper. I cut the pink wrapper off too, nothing at all on the silver body of the light. So I’m not sure what the cell is. I know it works well though, up in the top 5 if not top 3.
NikolaS
NikolaS's picture
Last seen: 1 month 2 days ago
Thanks for beautiful pictures Dale, what a great way to upgrade legendary C8, nicely done Sofirn !
desmondkun
desmondkun's picture
Last seen: 2 hours 14 min ago
Wow!! Looks great.
Thanks for review. Will there be any beamshot later?
Take care of your flashlight and your flashlight will take care of you.
264
264's picture
Last seen: 2 weeks 19 hours ago
Hey Dale,
How is the side spill for the light? We talking Olight Javalot or Convoy S3? Innocent
NikolaS
NikolaS's picture
264 wrote:
Hey Dale, How is the side spill for the light? We talking Olight Javalot or Convoy S3? Innocent
None of those, more like Q8, defined hotspot and nice spill
DB Custom
DB Custom's picture
Right, a largish hot spot with a nice amount of spill, great all around general purpose light with some kick. Smile
Think about it, with a better mosfet and heavier wires it’s almost making from 3 XP-L emitters what the Q8 is doing on 4. Wink
I plan on getting some beamshots, we had a nasty cold spell run through here and I do NOT do well with 25º!
Gebe
Last seen: 20 hours 54 min ago
Boy, you do good work Dale!
264
264's picture
Then it is a very useful flashlight.
264
264's picture
Nice review Dale. Thanks for the answer.
DB Custom
DB Custom's picture
I’ll say it again, I’m really impressed with Sofirn. I got the first C8F to review and it had XP-G3 emitters on aluminum, a protected cell came with it and there were issues with the emitters wanting more than the cell could provide. When I put a high drain cell in, fried an emitter! So I recommended they go to a DTP copper MCPCB with XP-L emitters and I rebuilt my sample in this way to show them what it would do… they listened! And promptly came out with a side switch with multiple groups and the required copper and emitter combination. It’s a real beauty, doesn’t need modification but lends itself well to a few tweaks. Smile
For what it’s worth, my first sample the reflector fitted beautifully over an 32mm Noctigon, made for an easy upgrade. Wink
DB Custom
DB Custom's picture
Now, y’all know the XP-L2 is out, right? Imagine this triple C8 loaded with XP-L2’s…..:D
Not kidding, I’ve seen the XP-L2 break 2300 lumens in a single emitter single cell application. So what would 3 of them do here? Interesting, very interesting….
gchart
gchart's picture
Last seen: 17 min 56 sec ago
Nice review, Dale. I’ve reviewed the Sofirn SF36 and have a C8 host in transit. I swear, I’m more and more impressed with Sofirn each day.
And you can’t even build this stuff for the prices they’re charging. Assuming you could get the triple reflector… C8 host: $10. 32mm MCPCB with 3 high-binned XP-L emitters: $25. Driver: $12. Battery: $5. Charger: $5. Total: $57. Pre-bypassed wires even. They’re going to put lesser modders out of business! Wink
DB Custom
DB Custom's picture
Thanks, I know there are some folks that really work wonders with charting and graphing and CRI rendering scopes and X-Ray machines and maybe some Martian help with the beam or something, so I don’t try to go all Einstein on anybody. Other’s are better at it, so I just like to show how it’s made, what makes it good (or bad) and how it can be made better. Sometimes, lately, a mfgr just get’s it so right I don’t even mod it! Shocked I know, I said it. Sad sad times at modder’s high. Silly
DB Custom
DB Custom's picture
BTW, I have the 36 and like it a lot. It compares very favorably to the Lumintop SD26, albeit maybe not as sleek. Lights like those, drop in an SST-40 and you’re good to go! Big Smile
contigo
Last seen: 1 week 2 days ago
whats the stock throw on the light?
im curious how it would stack against astrolux c8…
DB Custom
DB Custom's picture
Remember that this is a triple reflector light, like the Q8 is a quad reflector or like the BTU Shocker is a triple, only much smaller than that here in the C8 format. So, it’s better than building a C8 with a Ledil CUTE-3 Optic but of course less, much less, than a built C8 with throw in mind….
28.5Kcd Lux
337.64M throw
Barkuti
Barkuti's picture
Last seen: 2 hours 2 min ago
Hi everyone else Big Smile and Dale, saw your last comments in my C8T review thread a while ago. Ya know, don't be jealous about what others do in their reviews, jealousy virtue is not. Everyone shares his/her two cents and so do you. Thumbs Up
I am also going to receive one of these C8F torches hopefully in a few days. This seems like a nice bundle, even if the chosen cell wrap seems funnily misleading.
In the meantime, my kitchen lamp's central 5730 led array got ruined and is now undergoing a prolonged downtime while I receive a new 100 pack of Osram Duris E5 CRI85 5700K 5730 emitters and bases. In about two weeks everything should be at home but damn, Christmas is just around the corner…
Cheers Smile
The Light Innocent I am
Deleting a post and redoing it causes the forum thread answer notifications to become invalid. Thus, if you need to change your just published post, edit it. Thanks.
gchart
gchart's picture
DB Custom wrote:
BTW, I have the 36 … drop in an SST-40 and you’re good to go! Big Smile
Not to de-rail your C8F thread, but what advantage would you say you gained over the stock XP-L2?
DB Custom
DB Custom's picture
I’ve seen around 40-50% increase in a light running at about 3A, so say a light has 900 lumens max… swap in an SST-40 and it’ll be in the 1400 lumens range. A bit on the blue-white side, but not bad and certainly acceptable if that increase is needed. (most of the time)
Mike C
Mike C's picture
Last seen: 1 hour 57 min ago
The idea of a triple with a reflector in the C8 format is enticing. I just might have to get me one. Do you know what the driver diameter is? Looks like 17mm in your photo. I will be replacing it with one of my own.
DB Custom
DB Custom's picture
Went outside and took a little video with my smallest camera, probably talked too much but I guess y’all are used to that by now. Silly It’s uploading to YouTube, will post it directly. (now, this is unedited so don’t expect too much)
gchart
gchart's picture
Not sure about the C8F, I’ll leave that for Dale. But I do know they sell C8 hosts in both 17 and 20mm.
DB Custom
DB Custom's picture
Driver in this one is 17mm.
Firelight2
Firelight2's picture
Last seen: 41 min 24 sec ago
Great review!
And looks like a great light. Sofirn is putting out a lot of quality offerings. Cool
John-Galt
Last seen: 9 hours 35 min ago
Another great review, Dale. Thank you!
Ordered one to add to my small collection Wink
So, a dozen lights is a good start, right?
All the best and Merry Christmas
Mike
Lightbringer
Lightbringer's picture
Last seen: 10 min 54 sec ago
<drooling uncontrollably>
DB Custom
DB Custom's picture
Merry Christmas Mike. Smile
And the rest a y’as too! Wink
JasonWW
JasonWW's picture
Last seen: 4 hours 10 min ago
Hey Dale, gave you taken a look at the switch pcb yet? I’m curious if it has pads for leds.
This looks like a good candidate for one of Lexels TA drivers.
A rear switch might be nice to avoid parasitic drain. Have you tested the drain yet? I guess the anodized rear threads mean you can give it a quarter turn to lock it out.
Concerning the stock driver, what do you think of the UI? Is it one click to turn on, press and hold to turn off? How does the memory work, do you have to press and hold 0.5 second to get it to come on in the last mode? Does a normal click on always start in low?
I hope it will be offered in CW color as well.
A 26650 version of this light would be really sweet.
Click this to go to signature links.
DB Custom
DB Custom's picture
The switch pcb already has two led’s on it with resistors for each one.
A simple 1/8 turn of the tail cap gives lock out.
The UI has 4 groups, I like group 3 with press and hold for moon from off and double click from anywhere for Turbo.
Click on, press and hold for off, yes.
A short press and hold utilizes last mode memory, a short click starts in low 1, press and hold from off for moon, which does come on in the last mode memory then shifts down to moon. Not ideal, but easily dealt with.
Pretty complex light for such a new company, nice to see they’re into it and thinking. Wink
