The NEW Sofirn C8F Triple XP-L W2 w/side e-switch
287 posts / 0 new
Glow_Worm
Last seen: 3 weeks 5 days ago
I like this light a lot also, kind of like a mini-BLF-Q8. Your ceiling bounce estimates are similar to mine, and I agree that the mode spacing could be better, but it is what it is.
I’ve found the quickest way to get back to low is to just turn it off and then back on again (with a quick-press to avoid the memorized level).
Sofirn
Sofirn's picture
Last seen: 2 days 5 hours ago
wstrachan wrote:
Does anybody have a discount code that works for Amazon?
The new code is Q9ZWHJVR. And we also provide some codes in this thread.
Majoroverkill
Majoroverkill's picture
Last seen: 8 hours 33 min ago
DB Custom, would one of these work for the C8F? https://www.digikey.com/products/en?keywords=Vishay%20SIR404DP
Doug S.
DB Custom
DB Custom's picture
Last seen: 1 month 1 week ago
I use the 404 most of the time now, so I’d say yes. Wink
Majoroverkill
Thank you DB Custom Thumbs Up
Doug S.
DB Custom
DB Custom's picture
YW.
The quest is relentless, is it not? Wink
JasonWW
JasonWW's picture
Last seen: 2 hours 47 min ago
It’s interesting how certain FETs can limit output. I wonder if TA drivers can be swapped with a “lesser” FET in order to reduce max power on a small light which can’t handle big power in the first place?
L4M4
L4M4's picture
Last seen: 4 weeks 5 hours ago
Why put a FET driver in such light in the first place?
JasonWW
JasonWW's picture
The awesome UI of course.
The supfire in my sig has a TA driver with 2 × 26350 cells. It does over 7A, but I’d like to limit it to 5A or so. The extra amperage doesn’t do much except add heat and reduce run time. This is an everyday work light for me.
It would also be helpful for fet drivers using the xhp50.2 as they tend to burn up due to too much current.
Barkuti
Barkuti's picture
Last seen: 2 min 2 sec ago
I've said this before somewhere… how about setting an inductor in series with the emitters? This can reduce emitter current to some extent, while at the same time filters and increases efficiency for PWM modes.
Cheers
The Light Innocent I am
Deleting a post and redoing it causes the forum thread answer notifications to become invalid. Thus, if you need to change your just published post, edit it. Thanks.
Please avoid quoting lenghty posts, namely with nested quotes. Trim the quote down to the essential. Helps with forum neatness and legibility. Thanks.
Sharing localized AliExpress links is bad: when a user clicks or taps on a localized link their system automatically sets that locale, most often forcing the user to tap or click on the locale drop down or global site link to return to their localized site of choice or to the global site. Your carelessness is thus detrimental. I understand AliExpress should fix their site behaviour, but while this happens please be mindful and only share global website (english) links. Turning a localized link into a global link is super easy, just change the locale letters in the url for wwwExample:
https://es.aliexpress.com/item/bla-bla-bla.html turns into https://www.aliexpress.com/item/bla-bla-bla.html. Thumbs Up
teacher
teacher's picture
Last seen: 1 year 1 month ago
Just ran across this. Very nice review Dale!! Just ordered one…. your review sold me…. Wink
Picked up one of their pen lights too.
DB Custom
DB Custom's picture
Teacher, this Sofirn C8 is what Convoy shouldv’e done years ago, after all the triples I’ve built using the Ledil CUTE-3 optics this reflectored version really rocks! The side switch really steps it up as well, you DO know they’re offering hosts for like $14, right?
teacher
teacher's picture
I was impressed with your review of it Dale… that is what sold me on it. You seemed very impressed with it.
Nope… I had no idea about the hosts. Facepalm I did not see any on Amazon. Did I just miss them or are they offered elsewhere??
JasonWW
JasonWW's picture
The hosts are only on Sofirns store on Aliexpress.
http://s.aliexpress.com/ZRraeuyA
The host is here.
http://s.aliexpress.com/MRzyyaia
teacher
teacher's picture
The host is here.
Thank you Jason, I appreciate that info. Thumbs Up
Mike C
Mike C's picture
Last seen: 2 weeks 2 days ago
Here is a thread about the host only: http://budgetlightforum.com/node/57915
teacher
teacher's picture
Thank you Mike C!! I appreciate that info & link. Thumbs Up
teacher
teacher's picture
My C8F arrived today from Amazon. This is certainly an impressive light too. As was stressed in the review…. Sofirn did this right!!
Thanks again for the review Dale!! Smile
Oh yeah…. hosts ordered too, be a while before they arrive though. Wink
DB Custom
DB Custom's picture
I built up a host with 3 different colored XP-L’s, I think 1A, 3D, and 5C, and the output is fantastic! About 3800 lumens from a FET driver with TK’s ramping firmware and ramping UI. Not the simplest of builds, what with the side switch and it’s wires to get in the way, probably the MCPCB screwed to the reflector and then the reflector screwed into the head make an impact on the ease of build as well, but all in all it’s worth the effort, the supplied e-switch is on a pcb with lights already installed so if a lighted switch is one’s thing then that too should be pretty easy.
Sonofspectrum
Sonofspectrum's picture
Is there a discount code for Amazon UK?
It's moments of madness that keep us sane.
teacher
teacher's picture
Wow… that sounds pretty neat. I’m looking forward to getting my hosts, giving it a go, and see what happens… Wink
Don’t know. Have you tried any of the listed codes to see if any of them work??
Sonofspectrum
I did try and they didn’t work, I was hoping Tracy Wan might come back with something Wink
teacher
teacher's picture
/\/\/\Thumbs Up .. Wink
AnhTran
I really want to buy this light but those lines between the three reflectors look very ugly to me
beam0
beam0's picture
You mean because they’re kinda “rough” looking?
I wouldn’t let that bother ya… you shouldn’t be lookin in there anyhow Silly
You need to just buy it, this light is EPIC!
teacher
teacher's picture
Amen to that….. Thumbs Up
First time you fire it up you’ll forget “those lines” completely & never give them a second thought. Wink
LessDark
LessDark's picture
Why didn’t they use XP-L2 in this light as with the C8A?
I hope they will in the future for extra output.
Barkuti
Barkuti's picture
LessDark wrote:
Why didn't they use XP-L2 in this light as with the C8A?
After the initial fiasco with the first version of this light (without direct thermal path board LoL) they probably decided to play it safe with these higher Vf XP-L emitters, which have a nice tint btw.
Cheers Party
d_t_a
Last seen: 4 hours 30 min ago
Cheers Party
Just curious, can you elaborate about the “initial fiasco” without direct thermal path? Sorry I hadn’t read about it. So did the LEDs overheated and burned up without it?
Barkuti
Barkuti's picture
d_t_a wrote:
Just curious, can you elaborate about the "initial fiasco" without direct thermal path? Sorry I hadn't read about it. So did the LEDs overheated and burned up without it?
See here: XXX-Man's Review and disassembly: Sofirn C8F
Cheers ( ͡ᵔ ͜ʖ ͡ᵔ)
