Test/review of Vapcell INR21700 3100mAh (Purple)
3 posts / 0 new
HKJ
HKJ's picture
Last seen: 1 hour 26 min ago
DSC_2060
Official specifications:
  • Model: NCR21700
  • Size: 21.0*70.2mm
  • Nominal voltage: 3.6V
  • End-of-charge voltage: 4.20V
  • End-of-discharge Voltage: 2.50V
  • Typical Capacity: 3100mAh (0.2C discharge)
  • Min capacity: 3000mAh (0.2C discharge)
  • Weight: Max:68g
  • Internal resistance: Max:8mOhm
  • Standard Charge: 2000mA,CCCV 100mA cut-off
  • Charging Time: 3hours(standard charge)
  • Quick Charge Current: 4000mA
  • Max Continuous Discharge Current: 35000mA
  • Operating Temperature: Charging: 0°C ~ 45°C, Discharging: -20°C~70°C
  • Storage: Temperature -5°C~35°C, Humidity
  • Standard environmental condition: Temperature: 23±5°C
  • Humidity: 45-75%RH
Vapcell%20INR21700%203100mAh%20(Purple)-info
One of the new slightly larger batteries, this one with fairly low capacity, but very high current capability.
DSC_2057DSC_2058DSC_2059
DSC_2061DSC_2062
DSC_2063
DSC_2064
DSC_2065
Vapcell%20INR21700%203100mAh%20(Purple)-Capacity
Good tracking, expect a small capacity difference. The batteries has nearly constant capacity op to 30A and the 35A rating looks very realistic.
Vapcell%20INR21700%203100mAh%20(Purple)-Temp-15.0
Vapcell%20INR21700%203100mAh%20(Purple)-Temp-20.0
Vapcell%20INR21700%203100mAh%20(Purple)-Temp-30.0
The cells do not get too warm at 30A discharge current.
Vapcell%20INR21700%203100mAh%20(Purple)-CapacityTimeHours
Vapcell%20INR21700%203100mAh%20(Purple)-Energy
Vapcell%20INR21700%203100mAh%20(Purple)-PowerLoadTime
Vapcell%20INR21700%203100mAh%20(Purple)-TripCurrent
Vapcell%20INR21700%203100mAh%20(Purple)-Charge
Conclusion
This is a good high current battery.
Notes and links
The batteries was supplied by Vapcell for review.
Compare to 18650 and other batteries
DavidEF
DavidEF's picture
Last seen: 3 hours 36 min ago
Thanks. Being able to actually sustain 30A+ continuous draw might be worth the trade-off of low capacity for some people.
Reason is not automatic. Those who deny it cannot be conquered by it. Do not count on them. Leave them alone.
-Ayn Rand
Agro
Last seen: 10 min 3 sec ago
Looks nearly identical to 30T…Possibly a cherry-picked 30T, which would explain slightly higher capacity.
