[Review] KDLITKER E6 (1 / 2 x 18650, XP-L Hi) ~ A quality P60 flashlight
21 posts / 0 new
bilakos10
bilakos10's picture
Last seen: 4 min 41 sec ago
I will be reviewing the KDLITKER E6, the new P60 style flashlight sold by Kaidomain.com
Here's the product's page: KDLITKER E6
Let's start with the packaging.
The flashlight comes in a simple cardboard box with a clear front cover.
Apart from the flashlight itself, you also get an extension tube (the light can be used either with 1 or 2 18650s), a nice adjustable lanyard,
two rubber cigar grips, 4 spare o-rings, a cleaning cloth (which I forgot to include in the picture) and a GITD switch cover.
As seen, the light is actually a P60 host, which means that it accepts regular drop ins.
The whole light is covered in diamond cut grooves for better grip, while the cigar grip attachment also helps in keeping the light from rolling.
Its surface is coated by a nice coarse, black, matte anodization that gives it a stealthy look.
And here's the light on its full length, with the extra 18650 tube installed.
Being a P60 host, the light can be easily disassembled into its basic pieces.
Both threads of the body are anodized, which allows for mechanically locking out the light by slightly twisting the tailcap.
Despite being triangular, the threads are cleanly cut and arrived well lubricated.
The head houses the AR coated lens which is held in place by the smooth bezel.
Here's the P60 pill that came with the light.
Kaidomain offers a wide selection of pills, but I went with an XP-L Hi 6500K with smooth reflector and 3 modes.
The pill has a larger brass core and its overall quality is right on point.
The emitter is perfectly aligned with the help of the centering ring.
Thanks to the switch's deep positioning, the light can tailstand with ease.
The tail of the light can be easily taken apart by loosening the retaining ring.
The reverse clickie switch is quite stiff and tactile and is seated inside a white spacer.
The switch's spring is quite soft in contradiction to the pill's spring that's a bit thicker and stronger.
And here's the E6 with the Glow in the Dark switch cover installed.
User Interface
The drop in that I chose has a very simple UI and that's the primary reason why I went for it.
It has 3 modes Lo (5%) -> Mid (35%) -> High (100%) which can be cycled by a half press of the switch.
Of course mode memory is existent as well as LVP which completely shuts off power at 2.6V
Additionally, Kaidomain refers to a function called 'Smart Thermal Management' that is used to monitor the pill's temperature and regulate the current
going into the LED accordingly.
Performance
In order to measure the current draw of the flashlight I used a clamp meter and a Samsung 25R 18650 cell.
The cell configuration doesn't impact performance. The driver will pull half the current when it runs on 2 x 18650.
My measurements are for the 1 x 18650 configuration.
Mode - Current (A)
Lo - 0.05
Mid - 0.45
High - 1.52
Lastly, here are a few beamshots to help you understand the mode spacing.
Low
Mid
High
Overall, the flashlight is keeping it nice and simple.
It doesn't have any bleeding edge technology into it, but everything that it packs should be more than enough for one's needs.
My daily deals thread: ☢ [Gearbest.com Special Deals]
If you need any coupon code, just leave a reply on the thread.
DENGOH
DENGOH's picture
Last seen: 2 months 3 days ago
Nice dark and simple light.
May i know will the lvp still works with 2× 18650?
cool i'll see you when you get there
SubSailorVet
SubSailorVet's picture
Last seen: 1 month 1 week ago
I like it. Lights like this serve me a cool purpose cause I have tons of drop ins. I could use with an infrared light with night vision goggles. Or a green, red,,blue drop in, ultraviolet, etc, etc, etc. The build looks very solid and the anodizing is spot on. And the decent price of just $22.00 bucks ain’t bad. Thanks for posting Bill. You always give us great stuff!
Best regards,
Matthew
BanL
Last seen: 1 week 1 day ago
Hi bilakos10
Thank you for your reviewing.
Enjoy Big Smile
Ban
kaidomain.com KD - LED Flashlights, DIY Parts and Accessories
Inquiry for KD, please feel free to contact me.
MRsDNF
MRsDNF's picture
Last seen: 5 days 20 hours ago
Thanks for the review bilakos10.
bilakos10
bilakos10's picture
You are welcome guys!
Since you have some dropins available, you can even go for the host-only option that goes for around half the price.
Kodachrome40
Kodachrome40's picture
Last seen: 1 year 9 months ago
Nice review!!
I’m a big fan of p60 lights and a few drop-ins without hosts. This could be nice addition to my lights.
Frankly I didn’t think anyone manufactured new p60 hosts anymore. This is a nice surprise.
SubSailorVet
Cool! Nice to know there is a host only version for sale.
Best regards,
Matthew
Funner
Last seen: 7 months 2 weeks ago
Thanks for the review. I ordered one a few weeks back. I also picked up the KF8 Xhp50.2 that should be sweet. But they are still in transit. Thanks
beam0
beam0's picture
Last seen: 1 year 6 months ago
Thanks for this review! Just came across this “new” P60 flashlight in KD and found your review. I’m considering the host version.
The first thing I thought of when I saw this, was if it’s an upgrade to the Solarforce as far as thermal transfer. For as long as I can remember the issue with the Solarforce and clones was there was some open space inside surrounding the drop-in. It was a common mod to fill the space with strips of a soda can or copper, aluminum tape, etc.
I always thought why doesn’t someone just make a host that fits the drop-ins tightly without the gap? But maybe that’s not possible?
If it is I hope KD thought of that when this was designed.
"Over 2000000 hours (about 200 years) standby time"  (DQG Tiny 4th)
"27,157 results for zoomable flashlight" (ebay)
Funner
I received my E6 host. I definitely like it. The amount of space around a drop in inside the head is probably approximately 0.5mm (so 0.25mm on each side). About as tight as it could get and still accomadate all drop ins.
I have a lot of drop in modules and Kaidomain Kdlitker’s are by far the best and brightest for under $30 and these cost $10 which can’t be beat.
The XPLHD SMO and op are brighter for flood and throw than any drop in I have, brighter than my S2+ and as bright as my XHP50.2. I am extreamly pleased with their drop ins.
http://www.kaidomain.com/p/S026671.KDLITKER-P6-XPLHD-Cree-XP-L-HD-White-1000-Lumens-3V-9V-2-Groups-of-3-to-5-Mode-SMO-P60-Drop-in
I am swapping all of my drop ins to Kdlitker’s. No I don’t work for them. Just a flashlight guy, Dad, husband, and hunter that lives in the woods.
beam0
beam0's picture
Thanks for the info, so I guess their has to be some gap/space on these hosts to be able to accommodate different drop ins. Yes .25mm around is a very small gap, but a gap is a gap so no heat transfer there. Are you wrapping your drop-in’s for the E6?
Also where to get the E6 host for $10? (I’m seeing $13.99) does KD offer a BLF discount?
Thanks for your feedback on the KD XPL HD dropins, that’s exactly the one I decided on last night, only the 5000K NW version. I’m also curious for the XP-L HI version, I’ll probably get the XP-L in OP and a HI in SMO.
I wonder if KD will come out with an XHP35 / XHP50 drop-in too.
Funner
Many of Kaidomain’s Kdlitker P60 modules are $10. Their P60 host, the E6 for 1×18650 only, is $13.99 and their E6 host that comes with the extension that can be used with the tube for the 2×18650 use or without the tube for 1×18650 is $15.99.
I am not wrapping my modules. The light does a great job with transferring heat. They really stay cool. Now my S2+ XPL hi gets hot in under 5 minutes.
I’m happy with it.
beam0
beam0's picture
Funner wrote:
Many of Kaidomain’s Kdlitker P60 modules are $10. Their P60 host, the E6 for 1×18650 only, is $13.99 and their E6 host that comes with the extension that can be used with the tube for the 2×18650 use or without the tube for 1×18650 is $15.99. .
Thanks Funner, OK I see, I thought you wrote the E6 cost $10, now I see it was the dropins, sorry, my eyes were deceiving me from sleep deprivation!
I did find a discount code for KD, kd5off for 5% off, its not much but better than nothing.
EDIT: The code only works on items that aren’t already discounted, so it won’t work on the E6 hosts because those prices are showing as a “Discount price”
Same goes for the XP-L and Nichia drop-ins.
beam0
beam0's picture
When a flashlight gets hot, in one way its a good thing… means the heat is transferring away from the LED and into the body, making the body a heat sink to take heat away from the LED.
No offense meant, but this is pretty much a contradiction of terms. If it did a great job with transferring heat, it wouldn’t stay really cool.
For the P60 lights the body won’t get hot because the heat stays in the dropin (poor heat transfer to the body due to the air gap) that’s why people wrap those dropins. For the most part I think it’s not necessary with low current “off the shelf” dropins, but if you build your own hot-rodded dropins they’ll need wrapped.
beam0
beam0's picture
I wish KD made an 18350 or 18500 tube for the it.
I wonder if the E6 will lego with Solarforce, anyone know?
beam0
beam0's picture
Just noticed KD’s newer drop-ins are upgraded with large brass pill for better heat dissipation, nice!
http://www.kaidomain.com/Search/SearchResult.New%20KDLITKER%20P6
Funner
I just turned it on for a couple of minutes until it warmed up. The heat transfer throughout the upper half of the body vs my S2+ which the heat is in one spot. Which makes it more difficult to notice.
After it was on I then pulled out the drop in and the heat was the same as the flashlight body.
I will put the drop in in another light to feel the heat transfer.
The E6 host seems to spread the heat out through the whole end of the light.
Every time I use it it has been outdoors where the temp is 20-40 F so that helps to keep it cool and that is why I noticed almost no heat.
Funner
One thing I have noticed with the E6 is if. You jar, shake it, tap it hard, or tap it hard on the counter it will change modes.
I would think stiffer springs would resolve this. With 2. Batteries it is more likely, I think because the more moving weight of those 2 vs 1 battery.
I will see if I have some stiffer springs or make a double spring setup. I did try stretching the springs a bit and it seemed to help, stretching a bit more would probably help. Or adding a copper spacer with nylon outside would tighten the tension on the springs helping this.
Still like the light though.
beam0
beam0's picture
Great, thanks for the testing, sounds good!
Are you using a flat-top/short/unprotected cell, or a longer button-top protected one?
Maybe blob some solder on the end of one spring?
Or a magnet on the cell?
Also do you have any Solarforce lights/host to see if the tubes/threads lego with the E6?
Hairy_Steve
Last seen: 2 months 4 days ago
Pretty sure they don’t LEGO
Tried the solarforce ring guard tail cap and it doesn’t work.
There’s a gap of almost a cm when you screw the head on the front end too – the light still works but the kdlitker when on a solarforce body the p60 globe moves around.
It might be amusing to try one of the silly solarforce attack bezel rings on the front – I will maybe give it a try later today after I wake up if I remember.
