Test/review of Golisi i1
2 posts / 0 new
HKJ
HKJ's picture
Last seen: 58 min 22 sec ago
Golisi i1
DSC_4090
DSC_4091DSC_4092
Golisi have got a simple one slot charger, but with a a better readout than usual.
DSC_4075 DSC_4076 DSC_4077 DSC_4078
It arrived in a black very stylish cardboard box, there is some specifications on the back.
DSC_4086
The box included a bag for the charger.
DSC_4087
The total contents of the box was the charger, the bag, a usb cable and a instruction sheet.
DSC_4093
The charger is usb powered and can use up to 2A.
DSC_4097
The user interface is a single button and a small display.
Fast presses on the button will change between Volt, mAh and time readout, it will also turn the display on when it is off.
A long press will enable current adjustment.
DSC_4512
All segment on the display.
DSC_4513DSC_4514DSC_4515
The 3 different readouts (I never got around to remove the protection foil on the display).
DSC_4098
On the bottom of the charger there are specifications.
DSC_4094DSC_4095
The slots uses the classical slider construction and it works fine.
The slots can work from 32 mm to 71.5mm. This nearly covers anything.
supportedBatteryTypes
supportedBatterySizesDSC_4533DSC_4534DSC_4535DSC_4536
DSC_4537DSC_4538DSC_4540DSC_4541DSC_4542DSC_4543DSC_4544
The charger can handle 70 mm long batteries including flat top cells.
All sized NiMH will fit in the charger, but the NiMH charge current is rather low!
As long as the D cell has a flat top it will just about fit.
Measurements
  • Idle current is about 30mA from usb
  • Discharge LiIon battery with 0.3mA when not connected to power.
  • Discharge NiMH battery with 0.03mA when not connected to power.
  • When power is connected with a full battery, it will charge with about 0.3mA.
  • Below 0.3 volt the charger will report error
  • Below 1.6V the charger will assume NiMH
  • Between 1.6V and 2.2V the charger will not charge.
  • Above 2.2V the charger will assume LiIon.
  • Below about 0.7 volt the voltmeter is not very precise.
  • Display turns off after 30 seconds.
  • Voltmeter is within 0.01V
  • Voltmeter stops updating when charging is stopped and will not show above 4.20V
  • NiMH is always charged at 0.5A
  • Charger will not restart when voltage drops.
  • It will restart charging on reinsertion of the battery or power cycling.
Charging LiIon
Charge current is 0.5A, 1A and 2A, charger always starts at 0.5A
Golisi%20i1%201A%20%28SA18650-33%29
A nice CC/CV charge curve with termination around 120mA
Display shows: 3308mAh in 3:50
Golisi%20i1%201A%20%28PA18650-31%29
This older cell also charges fine, but has large voltage drop at the end.
Display shows: 2852mAh in 3:40
Golisi%20i1%201A%20%28SA18650-26%29
The 2600mAh cell is nicely charged.
Display shows: 2643mAh in 3:21
Golisi%20i1%201A%20%28BE18650-26%29
The old cell is also nicely charged
Display shows: 2206mAh in 4:00
Golisi%20i1%200.5A%20%28KP14500-08%29
At also this smaller cell at 0.5A.
Display shows: 754mAh in 1:44
Golisi%20i1%200.5A%20%28AW18350-IMR%29
The charge also handles this very old and worn down cell nicely.
Display shows: 177mAh in 0:42
Golisi%20i1%202A%20%28SA18650-33%29
Also 2A charging works fine.
Golisi%20i1%202A%20%28SA217000-30%29
Especially with a cell that is rated for high current charging.
Display shows: 3189mAh in 1:54
Golisi%20i1%201A%200.5ohm%20%28SA18650-33%29
Adding a 0.5ohm resistor in series with the power simulated a weak usb supply or long usb cable, the charger works slower, but will charge the cell.
Display shows: 3276mAh in 4:26
Temp4873
M1: 37,3°C, M2: 39,5°C, HS1: 52,6°C
Temp4874
HS1: 53,7°C
PoweronLiIon
The charger needs about 4 seconds to initialize. Notice the pulses during charge, it looks like this charger use some sort of simulated CC/CV, this do also fit with the final charge voltage that varies slightly.
CurrentChangeLiIon
The current can be changed at any time.
Charging NiMH
Charge current is always 0.5A with NiMH
Golisi%20i1%200.5A%20%28eneloop%29
The NiMH charger current is a bit low, but it terminates fine on with a nice -dv/dt (or maybe 0dv/dt) termination.
Display shows: 2079mAh in 4:19
Golisi%20i1%200.5A%20%28eneloopPro%29
Nice charging and termination.
Display shows: 2681mAh in 5:34
Golisi%20i1%200.5A%20%28powerex%29
Again nice charging and termination.
Display shows: 3266mAh in 6:47
Golisi%20i1%200.5A%20%28eneloopAAA%29
With the AAA cell is it a -dv/dt curve.
Display shows: 800mAh in 1:39
Golisi%20i1%200.5A%20full%20%28eneloop%29
This type of termination is a bit slow to detect a full cell, there it takes nearly 20 minutes.
Display shows: 159mAh in 0:19
Golisi%20i1%200.5A%200.5ohm%20%28eneloop%29
Simulating the weak power supply do not affect NiMH charging.
Display shows: 2008mAh in 4:10
Temp4879
M1: 29,3 , HS1: 37,9
At this low current there is not much heat.
PoweronNiMH
NiMH also needs about 3 seconds to initialize.
ChargingNiMH
As usual with NiMH chargers the charging is pulsed, here the voltage is checked each 10 seconds.
Conclusion
This is a nice “little” charger, I like it has capacity and voltage display, but the digits are rather small. The current selection also means a good and not too slow charge current for most LiIon cell, but the 0.5A for NiMH is too low.
I am not that happy about the display turning off, this requires a button press to see if the charger is done or just to check how far it is in charging.
I will call this charge a good one.
Notes
The charger was supplied by Golisi for review.
My website with reviews of many chargers and batteries (More than 1000): http://lygte-info.dk/
golisi
golisi's picture
Last seen: 4 days 4 hours ago
Thank you HKJ
Regarding Golisi i1 LCD, a quick double click will keep it from running off Smile
safe and durable fast chargers and Li-on batteries
www.golisi.com
