Which flashlight is the best combination of FLOODER-THROWER?
33 posts / 0 new
bariscan90
Last seen: 1 year 5 days ago
Edit 1: Does anybody own ACEBEAM K60? Do you mind sharing your experience with it? How far does it illuminate in metres? Have you ever tested it? And lastly how is the flooding? Thank you.
Hello everyone,
I want to buy my very first flashlight. What I am looking for is a flashlight that has the best combination of flooder and thrower. But what is the best? Perhaps everyone will have their “best” regarding to their preferences. So the more opinions I get the better I can decide.
Here are my preferences:
1) A flashlight that can illuminate up to 1000 metres,
2) A flashlight that is also a good flooder so that I can also see near objects clearly up to 100 metres,
3) A flashlight company with a good customer support and technical support.
During my research I have found some flashlights.
I have read that;
ACEBEAM K70 has a design problem that results in short circuit,
ThruNite TN40S/TN42 has a bug while switching from normal modes to turbo.
ACEBEAM K60 seems like a good candidate but I am not sure about the throw. I have seen ThruNite TN40S is a really good combination but the bug while switching through modes made me thinking.
I am open to any suggestions.
Cheers.
Edited by: bariscan90 on 01/12/2018 - 06:12
bariscan90
Throw me in to darkness wrote:
You want 1000m throw, and a flood beam? Well….. that may be difficult.
No, no you understood me wrong. Up to 1000 metres. So it can be a flashlight that is a decent flooder with 500 metres throwing. I meant to give max limit for the throwing.
Cheers.
Agro
Last seen: 4 min ago
Maybe some zoomie?
puglife2
Last seen: 20 hours 27 min ago
fenix rc40?
koyotee
koyotee's picture
Last seen: 2 months 4 weeks ago
Fenix tk75 is somewhere in between flood and throw.
Finaly, proud owner of a Powerex Maha mh c-9000 for my Eneloops:)
bariscan90
So basically you want maximum flood at 500m?
Sure it can be anything within the limit. I just wanted to put sone numbers in. I have seen ThruNite TN40S can illuminate 750 metres pretty good and is average-good flooder as well.
Lexel
Lexel's picture
Last seen: 8 hours 18 min ago
simple answer there is no floody 1000m thrower for a single reflector light
for real 1000m you need about 70mm active diameter of the reflector with XHP35
a real deal would be Astrolux MF01 and MF02 in one light together
bariscan90
Agro wrote:
Maybe some zoomie?
I am sorry, what is a Zoomie?
bariscan90
puglife2 wrote:
fenix rc40?
Thank you I will look into it.
bariscan90
Thank you I will definetely look into this one as well.
bariscan90
!{width:100%}http://www.metronixlaser.de/bilder/flashlight/Astrolux_MF02/IMG_4734.jpg!
Wow! That could be the coolest looking flashlight I have ever seen. I will definitely look at Astrolux.
bariscan90
Ok I’m officially confused. Shocked
I am lost as to your needs. Is it long range throw, combined with mid range flood?
Or is it maximum flood at a decent range?
Haha, I am really sorry about confusing you. English is not my native language. Let me try to explain again.
I would like to have a flashlight that is not a like laser, only illuminates the far distance but also one that has a very nice beam profile so the light smootly lights up the near objects and as well as the distance. Hopefully this helps. Cheers.
Zulumoose
Zulumoose's picture
Last seen: 21 min 27 sec ago
Convoy L6?
I don’t have one yet, but from what I have seen they appear to offer great throw and flood, and couldn’t be much better in terms of build quality, support, and reputation.
Beam me up!
Agro
bariscan90 wrote:
Agro wrote:
Maybe some zoomie?
Zoomie is a light with an action called zooming – you adjust the beam width from wide and moderately bright to narrow and very intense.
They tend to be superb throwers (no spill to distract your eye, good throw-to-size) and superb flooders (very smooth beam) in the same package, but not without drawbacks:
  • the common zoomies are very inefficient in the throw mode – the beam is bright but narrower than that of a reflector light
  • unlike with reflector, you can have flood or throw, but never both at the same time. If you look far, you won’t see what’s under your feet.
  • often they have worse cooling than similarly sized reflector lights
  • typically you’re limited to using a single LED, so they won’t get close to the output of mega-flooders. No multi-led zoomie I’m aware of is good enough.
There are less common types that are better or worse in one way or another, I won’t elaborate on them now because I don’t see one that would work well for you.
Well, I don’t see a stock zoomie that would match the description, so if you want that route, you’re limited to modded lights. I’d suggest UniqueFire UF-1508 T75 with (dedomed?) XHP70.2.
bariscan90
Ok,
Any high power, huge head multi-emitter will do.
Or something with an XHP70/70.2 in a large reflector also.
All the options we have mentioned above will fit the bill.
Just make sure you don’t buy a dedicated thrower!
Thank you mate.
bariscan90
Agro wrote:
bariscan90 wrote:
Agro wrote:
Maybe some zoomie?
  • in practice you’re limited to using a single LED, so they won’t get close to the output of mega-flooders
Wow. Thank you very much Agro for getting into this hassle and giving me a perfect explanation of what it is. I really appreciate your time and effort on writing it.
I will look at what you recommended.
Cheers.
Perpetual Lumen
Last seen: 1 day 5 min ago
Any light that has a 35 to 1 lux to lumen ratio.
TN42vnCFT90, TN40Svn, K60 TX25c2vn40
bariscan90
https://www.gearbest.com/led-flashlights/pp_1236530.html
Highly recommended.
There is a 1.5km long pitch-dark area I go to really push a torches limits. From just over half way across, the Buffalo started to drop visible light on a building. I would say about 700m or just under. At the 500m mark, there is enough light to define your target. Nice range and flood.
Very nice! I will look into it. Thank you.
bariscan90
Highly recommended.
No worries. I can genuinely recommended that light as I’ve seen it in action, and although there are many that fit your needs the Buffalo really impressed me. You won’t be disappointed if you get one.
I cannot seem to find their company website to browse their products. Hmm.
patmurris
patmurris's picture
Last seen: 2 weeks 1 day ago
BLF Q8 would seem like a good starting point. Whether it will fit your needs is for you to determine, but in any case it is a very good light you’ll be happy to have.
Since you don’t have any lights, it is very unlikely that you’ll find the perfect one right away…
Perpetual Lumen
You mean like a domed C8 type thing?
35,000 lux and 1000 lumens? Not exact numbers, but is that what you meant?
Like 175k lux and 5000lm. I’m all about performance.
I own the TN40svn which does 500k lux and 9000lms which I feels very throwy. I think 35 lux to 1 lumen is a great combination. Something with just a little more throw than the Acebeam K60 would be perfect.
Andrew_Debbie
Last seen: 3 days 17 hours ago
You are asking one light to do two very different things.
Why not get two flashlights?
A BLF Q8 will do number 2 reasonably well. It isn’t perfect, but I doubt you can get a better flooder for less than $45.00
One downside is the Q8 requires 4 “married” 18650 batteries. The batteries in the Q8 shouldn’t be used elsewhere. They need to stay as a matched quad.
That leaves a lot of room in your budget for a thrower.
My light with the most throw is a Convoy L6. For 1km of throw, you are going to need a bigger light. I don’t have any suggestions. I’m new at this.
Perpetual Lumen
I had a convoy L6. Solidly built light for the price.
The_Driver
The_Driver's picture
Last seen: 7 hours 50 min ago
Acebeam X65 for larger distances and the Noctigon Meteor with some LED dedomed for shorter distances.
Andrew_Debbie
Agree. It is my 2nd favourite light.
BLF A6 is my #1. Neither of them do what the OP is asking for.
Perpetual Lumen
I own the Acebeam K60 and I can tell you they have great customer service. My lights tail PCB broke and instead of shipping it back to China Acebeam actually just sent me a new PCB with very minimal questions. The light is great. I would highly recommend it. The Acebeam K65 could be a good option for you. These light are not cheap. Remember you are paying for the quality and reassurance you will be well taken care of.
I second looking at the K65, RC40, TK75, K60, TN40S, X45, X65. Personally it’s all about that lux/lumen ratio.
55 to 1 is to much throw for a balanced light for me.
26 to 1 is not enough throw for me.
Dman7777
Dman7777's picture
Last seen: 1 week 6 days ago
I came here to suggest this as well.
You cannot beat this light for $50 if you want a combination of flood and throw.
1. Great flood and throw…Will light up a large field with ease
2. Incredible user interface with ramping to allow any light level that you desire quickly and easily
3. Great build quality
4. Support of the entire community of the people who designed, own and operate this light right here on BLF
Phenomenal value at around $50 with coupon.
bariscan90
Thank you so much for your input. I definitely love the ring on K60. So easy to switch through modes. I might really go with the K60. It is just TN40S really gets me with it’s illumination in both far and near distance.
bariscan90
Thank you. Acebeam x65 is so big to carry in my opinion.
bariscan90
Do you mind telling me a little about blf? Is it a flashlight manufactured by people on this forum? Or is it a mod? Thank you.
Lexel
Lexel's picture
This is not true the Q8 does not need married batteries they are in parallen you can use old laptop pulls and new high drain batteries at the same time, just when putting in the light their charge state should be almost identical to prevent high charge currents flowing from full to empty batteries
