LG 18650 HA1 1300mAh (Green)
Official specifications:
- Nominal capacity: 1300mAh
- Ninimum capacity: 1200mAh
- Standard charge: 650mA, 4.2V, 50mA
- Fast charge: 4000mA, 4.2V, 100mA
- Max. charge voltage: 4.2V
- Max. charge current: 4000mA
- Standard discharge: 260mA
- Fast discharge: 10000mA
- Max. discharge current: 20000mA
- End voltage (Cut off): 2.5V
- Operating temperature: charge: 0°C ~ 50°C, discharge: -20°C ~ 75°C
- Storage temperature: 1 month: -20°C ~ 60°C, 3 months: -20°C ~ 45°C, 1 year: -20°C ~ 20°C
- Initial AC impedance:
- Cycle life: 400 cycle to 60% with fast charge/discharge.
/LG%2018650%20HA1%201300mAh%20(Green)-info.png)
This battery is a high current battery of a fairly old type.
/DSC_3071.jpg)
/DSC_3073.jpg)
/DSC_3074.jpg)
/DSC_3075.jpg)
/DSC_3076.jpg)
/LG%2018650%20HA1%201300mAh%20(Green)-Capacity.png)
The battery has fairly constant capacity up to 15A.
/LG%2018650%20HA1%201300mAh%20(Green)-Temp-15.0.png)
Due to the fairly low capacity, the battery keeps a moderate temperature.
/LG%2018650%20HA1%201300mAh%20(Green)-Temp-20.0.png)
/LG%2018650%20HA1%201300mAh%20(Green)-CapacityTimeHours.png)
/LG%2018650%20HA1%201300mAh%20(Green)-CapacityTime.png)
/LG%2018650%20HA1%201300mAh%20(Green)-Energy.png)
/LG%2018650%20HA1%201300mAh%20(Green)-PowerLoadTime.png)
/LG%2018650%20HA1%201300mAh%20(Green)-TripCurrent.png)
I used the capacity while doing these measurements.
/LG%2018650%20HA1%201300mAh%20(Green)-Charge.png)
Conclusion
The battery is orginally from 2006 or 2007 and was probably designed for use in electric tools.
Notes and links
Vapcell told me that I was missing some cells in my comparator and they would be happy to supply them.
Compare to 18650 and other batteries
Over the next couple of months I expect to publish more reviews of older cell, there will also be some never cells that I am missing.
These test is done when I do not have newer batteries to test.
10 year, same current discharge, 2.5 higher capacity
technology has gone far
Forgot my pen
