The 7730000000000000000 lumen laser.
9 posts / 0 new
zerodish
Last seen: 1 day 6 hours ago
The folks over at the Rutherford Appleton laboratory have created a laser to research gamma ray bursts. They claim it has the power of the entire sunlight on the earth focused down to a few mircrons. The insolation of the earth is 164 watts per square meter. The luminous efficacy of sunlight is 93 lumens per watt and surface of the earth is 507000000000000 square meters. Be sure to check my math. Some one should be able to calculate the candlepower from this. Of course in a few years you will able to buy one of these on Alibaba. Perhaps powered by an antimater battery. https://phys.org/news/2018-01-mini-gamma-ray-lab.html
264
264's picture
Last seen: 1 day 14 hours ago
Interesting post and link. Thank you.
niraya
niraya's picture
Interesting, even though I am not sure why would I EVER buy such thing in Alibaba or anywhere else Hat
FPV
FPV's picture
Last seen: 3 weeks 2 days ago
cool link, thanks for sharing. very interesting application
Enderman
Enderman's picture
Last seen: 42 min 55 sec ago
Sunlight on the earth only hits half. So you don’t take the surface area of the earth as a sphere, you take it as a flat disk.
It’s also not possible to calculate candlepower without knowing the beam divergence or intensity either.
mustig
mustig's picture
Last seen: 3 months 5 days ago
I read the article. The beam was 200 TW! Crazy!
Regarding your math, you used the entire surface of the earth when sunlight only reaches the projected area. Also, I believe your insolation number must be a yearly average over the entire planet surface including nights. Changing these should anyhow only result in a difference of 1-2 orders of magnitude…
mustig
mustig's picture
And they focused it on a spot 27 µm in diameter, that’s 3.5 × 10^23 W/m2.
Kourtinoksylo
Last seen: 1 hour 49 min ago
Maybe a resistor mod? And bypass the springs for a bit more output? Big Smile
-Air cooled 4x XHP50.2: http://budgetlightforum.com/node/56829
-SkyRay King 4x XPL HI, TN40 clone: http://budgetlightforum.com/node/55195
-XHP70.2 Maglite 2D: http://budgetlightforum.com/node/54791
-SkyRay King 7x XML2, TIR, 8x 18650: http://budgetlightforum.com/node/54886
djozz
djozz's picture
Last seen: 36 min 41 sec ago
a tiny message from aliens, brought to you from within our lab! Big Smile
