Test/review of Keeppower IMR20700 4250mAh UH2042 (Black) 2017
1 post / 0 new
HKJ
HKJ's picture
Last seen: 40 min 46 sec ago
DSC_2652
Official specifications:
  • Part No.: UH2042
  • High Drain 20700 Li-ion Rechargeable Battery
  • Minimum Capacity: 4050mAh
  • Typical Capacity: 4250mAh
  • Normal Voltage: 3.7V
  • Standard Continuous Charging Current: 1000mA
  • Maximum Continuous Charging Current: 2000mA
  • Maximum Continuous Discharging Current: 15A
  • Maximum Pulse Discharging Current: 30A
  • 4.2V full charged voltage and 2.5V discharge cut off voltage
  • High charge and discharge currents reduce cycle life
Keeppower%20IMR20700%204250mAh%20UH2042%20(Black)%202017-info
A high capacity cell in the new 20700 form factor.
DSC_2651
DSC_2653DSC_2654
DSC_2655
DSC_2656
Keeppower%20IMR20700%204250mAh%20UH2042%20(Black)%202017-Capacity
The discharge curves tracks fine, the capacity is present at low load, but at higher loads the cell has a bit less capacity.
Keeppower%20IMR20700%204250mAh%20UH2042%20(Black)%202017-Temp-10.0
Keeppower%20IMR20700%204250mAh%20UH2042%20(Black)%202017-Temp-15.0
At 15A the cell gets rather warm.
Keeppower%20IMR20700%204250mAh%20UH2042%20(Black)%202017-Temp-20.0
At 20A it gets too hot and i had to stop.
Keeppower%20IMR20700%204250mAh%20UH2042%20(Black)%202017-CapacityTimeHours
Keeppower%20IMR20700%204250mAh%20UH2042%20(Black)%202017-Energy
Keeppower%20IMR20700%204250mAh%20UH2042%20(Black)%202017-PowerLoadTime
Keeppower%20IMR20700%204250mAh%20UH2042%20(Black)%202017-TripCurrent
Keeppower%20IMR20700%204250mAh%20UH2042%20(Black)%202017-Charge
Conclusion
This looks like a very good cell with good capacity for its size.
Notes and links
The battery was supplied by Keeppower for review.
Compare to 18650 and other batteries
